atmospheric pressure sensor
A place for all the "WTB" adverts
nightfire10
Has thanked: 608 times
Been thanked: 247 times
Post by nightfire10 » Fri Aug 16, 2019 2:15 pm
As above i need a atmospheric pressure sensor
would not having one interfere with anything ?
Hayward's Street/bridgeported rebuild,595's,Tein coilovers with edfc,Racingbeat rear anti roll bar,oil pressure and oil temp gauge pod's,lockwood front and rear grills,Tinted windows,folding tow hook's,595s,connect2
Has thanked: 297 times
Been thanked: 1087 times
Re: atmospheric pressure sensor
Post by warpc0il » Fri Aug 16, 2019 2:21 pm
Not having the Barometric Sensor would trigger a P0107
The input from the Baro sensor is used by the PCM to adjust fuel maps.
nightfire10
Post by nightfire10 » Fri Aug 16, 2019 2:32 pm
It's still there well the electrical part was under the plastic cover for the ecu looks like it had broken off the plastic holder with small tube under it
Paul_13
Has thanked: 17 times
Been thanked: 25 times
Post by Paul_13 » Fri Aug 16, 2019 4:26 pm
It will throw a code. Boosted couldn't get his rotary rocket started without it. Depends on ecu I guess
Dentist
Has thanked: 21 times
Post by Dentist » Fri Aug 16, 2019 7:12 pm
It will throw mix codes,
unplug maf to putting car in lipmode, if it didnt change move to this sensor.
I have one.
dern
Has thanked: 40 times
Been thanked: 46 times
Post by dern » Tue Aug 20, 2019 10:42 pm
Have you got one of these yet? If not pm me with your address and I'll send you one.
Red 231 with Haywards stage 2 engine, Tein Mono Sport coilovers with EDFC2 controller, stripped out interior, sunroof delete and racing beat anti-roll bars
nightfire10
Post by nightfire10 » Wed Aug 21, 2019 6:45 am
Cheers Dern ordered one from eBay £4+post hopefully turn up this week
dern (Wed Aug 21, 2019 1:43 pm)
Return to “Buying”
