RX-8 Axle Stand and Jacking Pads
Announcements from the Club Shopkeeper and suggestions from Club Members etc.
Ian.Mothersole
Has thanked: 9 times
Been thanked: 98 times
Post by Ian.Mothersole »
RX-8 Axle Stand Pad
Axle Stand Pad adapter to avoid sill damage - slot cut designed to fit all RX-8s.
Machined from a vulcanised rubber with steel reinforcement centre.
Supplied in 'un-cut' form as per photos, and can be cut to suite different shape axle stands.
Dimensions: ~60mm diameter, 42mm height
These users thanked the author Ian.Mothersole for the post:
sKenDread (Sat Feb 15, 2020 11:27 am)
Ian.M - Keep It Simple!
Club Shopkeeper & Forum Admin Team
"Rex" 2009-16
Velocity Red 231; Hayward Rotary ported engine; Racing Beat exhaust, flywheel, air duct, anti-roll bars; Eibach lowering springs, wheel spacers; Essex Rotary mini-remap; Prodrive PZ spoiler.
"Rex 2" 2014-
Velocity Red 231; the project car.
"Blue Rex" 2015-
Winning Blue 231; RX ATE.
Ian.Mothersole
Re: RX-8 Axle Stand and Jacking Pads
RX-8 Jacking Pad
Jacking Pad adapter to avoid sill damage - slot cut designed to fit all RX-8s.
Machined from a vulcanised rubber with steel base.
Available in small and large sizes to suite different size trolley jacks.
Small: ~60mm diameter, 23mm height
Large: ~75mm diameter, 28mm height
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
Ian.Mothersole
Axle stand adapter cut to fit:
Images thanks to bigpete :thumleft:
sKenDread (Sat Feb 15, 2020 11:28 am)
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
doobedoobedo
Post by doobedoobedo »
Just got and put my set of axle stand pads. Very happy with them, quality seems excellent.
Already put to use.
Thanks Ian!
Anyone want to place orders with the shop for collection at the Trackday/AGM?
sKenDread (Sun Feb 02, 2020 2:04 pm)
sKenDread
Has thanked: 112 times
Been thanked: 74 times
Post by sKenDread »
Which ones should I get guys? These are Halfords jack stands
75mm on the inside with a 40mm wide dip of 5mm (no idea the radius) in the middle
Just worked it out lol (42.5mm radius arc... hrmmm that doesn't sound right)
Kia-ora!
'09 R3 Aurora Blue Mica
I'd go for the large one, which should fit nicely across the flat part of that profile, providing the largest area of support for the jacking point.
The steel plate should prevent it dipping in the middle.
sKenDread (Sun Feb 02, 2020 1:58 pm)
Ainmhidh
Has thanked: 233 times
Been thanked: 146 times
Post by Ainmhidh »
or you take an angle grinder to the edges of the pad base to form something like the inverse of the dip so it all sits nicely on the stand.
These users thanked the author Ainmhidh for the post:
sKenDread
Post by sKenDread »
warpc0il wrote:Anyone want to place orders with the shop for collection at the Trackday/AGM?
Thanks dude,
All paid up for 2 * large ones Image
I can collect at the AGM
Kia-ora!
Ainmhidh
Post by Ainmhidh »
Kenny, did you note that on the order? otherwise it'd be worth a pm to Ian.
sKenDread (Sun Feb 02, 2020 2:08 pm)
sKenDread
Post by sKenDread »
Ainmhidh wrote:Kenny, did you note that on the order? otherwise it'd be worth a pm to Ian.
Whoops lol
Kia-ora!
DigitalGremlin
Post by DigitalGremlin »
These look cool plus useful
sKenDread
Post by sKenDread »
Thanks @Ian.Mothersole pads arrived today
Kia-ora!
deekhubert
Post by deekhubert »
Am I able to put in an order for 4 large please?
Juey
Colour: Black Cherry
Been thanked: 119 times
Post by Juey »
^^yes, in the club shop. You need to click on 'parts', they tend not to appear on the landing page for some reason.
Mpv2k3
Has thanked: 52 times
Been thanked: 31 times
Post by Mpv2k3 »
Just out of curiosity, are these still available in the shop? I couldn't see them or the section parts as mentioned.
I'm using a phone so that could be the problem?
casey
Has thanked: 507 times
Been thanked: 451 times
Post by casey »
Mpv2k3
Post by Mpv2k3 »
Cheers malcolm.
Didn't seem to have that option using the phone. Your link worked :thumright:
SuperSeagull
Has thanked: 6 times
Post by SuperSeagull »
These look good. My Halfords stands are 75mm edge to edge with a pronounced dip and around 50mm in the middle. I think they look like the orange stands in the thread - anyone know if I should go for the large or small ones? Feels like small is the better bet for them to sit within the stand rather than resting on the edges?
SuperSeagull (Tue Mar 30, 2021 8:43 am)
HarSc
Has thanked: 568 times
Been thanked: 526 times
Post by HarSc »
Hey! Bit of a resurrection, but would I be able to get a set of 4x axle stand pads and a small jacking pad for collection at JDM combe/annual meet? Let me know if that's ok 8)
Some guy from oooop north ;) | Harry | Membership Secretary | Media Team
- My Main RX-8 R3 [MHZ 3800] thread here
- My Project Banana [GL04 MXU] thread here
- My Mazda 2 DE daily thread here
- My engine disassembly shenanigans here
Ian.Mothersole
No problem at all!
Do make sure you pester me for them at some point over the weekend, otherwise I will end up going home again with them :lol:
HarSc (Mon Aug 23, 2021 6:45 pm)
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
HarSc
Post by HarSc »
Ian.Mothersole wrote:
Mon Aug 23, 2021 6:41 pm
No problem at all!
Shall do! Cheers =D> :lol:
