RX-8 Axle Stand and Jacking Pads
Announcements from the Club Shopkeeper and suggestions from Club Members etc.
Ian.Mothersole
Has thanked: 45 times
Been thanked: 369 times
Post by Ian.Mothersole » Sat Jan 18, 2020 4:23 pm
RX-8 Axle Stand Pad
Axle Stand Pad adapter to avoid sill damage - slot cut designed to fit all RX-8s.
Machined from a vulcanised rubber with steel reinforcement centre.
Supplied in 'un-cut' form as per photos, and can be cut to suite different shape axle stands.
Dimensions: ~60mm diameter, 42mm height
These users thanked the author Ian.Mothersole for the post:
sKenDread (Sat Feb 15, 2020 11:27 am)
Ian.M - Keep It Simple!
Club Shopkeeper & Forum Admin Team
"Rex" 2009-16
Velocity Red 231; Hayward Rotary ported engine; Racing Beat exhaust, flywheel, air duct, anti-roll bars; Eibach lowering springs, wheel spacers; Essex Rotary mini-remap; Prodrive PZ spoiler.
"Rex 2" 2014-
Velocity Red 231; the project car.
"Blue Rex" 2015-
Winning Blue 231; RX ATE.
Ian.Mothersole
Re: RX-8 Axle Stand and Jacking Pads
RX-8 Jacking Pad
Jacking Pad adapter to avoid sill damage - slot cut designed to fit all RX-8s.
Machined from a vulcanised rubber with steel base.
Available in small and large sizes to suite different size trolley jacks.
Small: ~60mm diameter, 23mm height
Large: ~75mm diameter, 28mm height
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
Ian.Mothersole
Post by Ian.Mothersole » Sat Jan 18, 2020 4:24 pm
Axle stand adapter cut to fit:
Images thanks to bigpete :thumleft:
sKenDread (Sat Feb 15, 2020 11:28 am)
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
doobedoobedo
Been thanked: 9 times
Post by doobedoobedo » Sat Feb 01, 2020 4:32 pm
Just got and put my set of axle stand pads. Very happy with them, quality seems excellent.
Already put to use.
Thanks Ian!
Has thanked: 467 times
Been thanked: 1889 times
Post by warpc0il » Sat Feb 01, 2020 4:57 pm
Anyone want to place orders with the shop for collection at the Trackday/AGM?
sKenDread (Sun Feb 02, 2020 2:04 pm)
sKenDread
Has thanked: 226 times
Been thanked: 168 times
Post by sKenDread » Sun Feb 02, 2020 11:06 am
Which ones should I get guys? These are Halfords jack stands
75mm on the inside with a 40mm wide dip of 5mm (no idea the radius) in the middle
Just worked it out lol (42.5mm radius arc... hrmmm that doesn't sound right)
Kia-ora!
RRP Performance Ignition Coil System MKII | RRP Mini Map | RRP COFS | Powerflow Twin Exhaust
Original engine 80k
Post by warpc0il » Sun Feb 02, 2020 1:05 pm
I'd go for the large one, which should fit nicely across the flat part of that profile, providing the largest area of support for the jacking point.
The steel plate should prevent it dipping in the middle.
sKenDread (Sun Feb 02, 2020 1:58 pm)
Ainmhidh
Has thanked: 475 times
Been thanked: 397 times
Post by Ainmhidh » Sun Feb 02, 2020 1:35 pm
or you take an angle grinder to the edges of the pad base to form something like the inverse of the dip so it all sits nicely on the stand.
These users thanked the author Ainmhidh for the post:
sKenDread
Post by sKenDread » Sun Feb 02, 2020 2:05 pm
warpc0il wrote:Anyone want to place orders with the shop for collection at the Trackday/AGM?
Thanks dude,
All paid up for 2 * large ones Image
I can collect at the AGM
Kia-ora!
Original engine 80k
Ainmhidh
Post by Ainmhidh » Sun Feb 02, 2020 2:07 pm
Kenny, did you note that on the order? otherwise it'd be worth a pm to Ian.
sKenDread (Sun Feb 02, 2020 2:08 pm)
sKenDread
Post by sKenDread » Sun Feb 02, 2020 2:08 pm
Ainmhidh wrote:Kenny, did you note that on the order? otherwise it'd be worth a pm to Ian.
Whoops lol
Kia-ora!
Original engine 80k
DigitalGremlin
Been thanked: 5 times
Post by DigitalGremlin » Sun Feb 02, 2020 9:59 pm
These look cool plus useful
sKenDread
Post by sKenDread » Sat Feb 15, 2020 11:27 am
Thanks @Ian.Mothersole pads arrived today
Kia-ora!
Original engine 80k
deekhubert
Been thanked: 22 times
Post by deekhubert » Fri May 01, 2020 10:31 am
Am I able to put in an order for 4 large please?
Juey
RX-8: Import
Colour: Black Cherry
Has thanked: 21 times
Been thanked: 115 times
Post by Juey » Fri May 01, 2020 12:02 pm
^^yes, in the club shop. You need to click on 'parts', they tend not to appear on the landing page for some reason.
Black Cherry Mica
I can explain it to you, but I can't understand it for you.
Mpv2k3
Has thanked: 205 times
Been thanked: 441 times
Post by Mpv2k3 » Wed Oct 21, 2020 6:59 pm
Just out of curiosity, are these still available in the shop? I couldn't see them or the section parts as mentioned.
I'm using a phone so that could be the problem?
casey
Has thanked: 1165 times
Been thanked: 1400 times
Post by casey » Wed Oct 21, 2020 7:02 pm
Club Secretary
Seibon Carbon Fibre Bonnet
Mpv2k3
Post by Mpv2k3 » Wed Oct 21, 2020 7:14 pm
Cheers malcolm.
Didn't seem to have that option using the phone. Your link worked :thumright:
Return to “Club Shop”
