RX-8 Axle Stand and Jacking Pads
- Has thanked: 9 times
- Been thanked: 98 times
RX-8 Axle Stand Pad
Axle Stand Pad adapter to avoid sill damage - slot cut designed to fit all RX-8s.
Machined from a vulcanised rubber with steel reinforcement centre.
Supplied in 'un-cut' form as per photos, and can be cut to suite different shape axle stands.
Dimensions: ~60mm diameter, 42mm height
- These users thanked the author Ian.Mothersole for the post:
- sKenDread (Sat Feb 15, 2020 11:27 am)
Ian.M - Keep It Simple!
Club Shopkeeper & Forum Admin Team
"Rex" 2009-16
Velocity Red 231; Hayward Rotary ported engine; Racing Beat exhaust, flywheel, air duct, anti-roll bars; Eibach lowering springs, wheel spacers; Essex Rotary mini-remap; Prodrive PZ spoiler.
"Rex 2" 2014-
Velocity Red 231; the project car.
"Blue Rex" 2015-
Winning Blue 231; RX ATE.
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
Re: RX-8 Axle Stand and Jacking Pads
RX-8 Jacking Pad
Jacking Pad adapter to avoid sill damage - slot cut designed to fit all RX-8s.
Machined from a vulcanised rubber with steel base.
Available in small and large sizes to suite different size trolley jacks.
Small: ~60mm diameter, 23mm height
Large: ~75mm diameter, 28mm height
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
Axle stand adapter cut to fit:
Images thanks to bigpete
- sKenDread (Sat Feb 15, 2020 11:28 am)
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
- RX-8: Evolve
Just got and put my set of axle stand pads. Very happy with them, quality seems excellent.
Already put to use.
Thanks Ian!
Already put to use.
Thanks Ian!
- Been thanked: 2087 times
Anyone want to place orders with the shop for collection at the Trackday/AGM?
- sKenDread (Sun Feb 02, 2020 2:04 pm)
- Has thanked: 112 times
- Been thanked: 74 times
Which ones should I get guys? These are Halfords jack stands
75mm on the inside with a 40mm wide dip of 5mm (no idea the radius) in the middle
Just worked it out lol (42.5mm radius arc... hrmmm that doesn't sound right)
Kia-ora!
'09 R3 Aurora Blue Mica
I'd go for the large one, which should fit nicely across the flat part of that profile, providing the largest area of support for the jacking point.
The steel plate should prevent it dipping in the middle.
- sKenDread (Sun Feb 02, 2020 1:58 pm)
- Has thanked: 233 times
- Been thanked: 146 times
or you take an angle grinder to the edges of the pad base to form something like the inverse of the dip so it all sits nicely on the stand.
- These users thanked the author Ainmhidh for the post:
Thanks dude,warpc0il wrote:Anyone want to place orders with the shop for collection at the Trackday/AGM?
All paid up for 2 * large ones
I can collect at the AGM
Kia-ora!
Kenny, did you note that on the order? otherwise it'd be worth a pm to Ian.
- sKenDread (Sun Feb 02, 2020 2:08 pm)
Whoops lolAinmhidh wrote:Kenny, did you note that on the order? otherwise it'd be worth a pm to Ian.
Kia-ora!
Thanks @Ian.Mothersole pads arrived today
Kia-ora!
- RX-8: Import
- Colour: Black Cherry
- Been thanked: 119 times
^^yes, in the club shop. You need to click on 'parts', they tend not to appear on the landing page for some reason.
- Colour: Diamond Grey
- Has thanked: 52 times
- Been thanked: 31 times
Just out of curiosity, are these still available in the shop? I couldn't see them or the section parts as mentioned.
I'm using a phone so that could be the problem?
- Events Team Member
- Has thanked: 507 times
- Been thanked: 451 times
Cheers malcolm.
Didn't seem to have that option using the phone. Your link worked
- Has thanked: 6 times
These look good. My Halfords stands are 75mm edge to edge with a pronounced dip and around 50mm in the middle. I think they look like the orange stands in the thread - anyone know if I should go for the large or small ones? Feels like small is the better bet for them to sit within the stand rather than resting on the edges?
I would say "small"
https://shop.rx8oc.co.uk/RX-8_Axle_Stan ... 53825.aspx
- SuperSeagull (Tue Mar 30, 2021 8:43 am)
- Has thanked: 568 times
- Been thanked: 526 times
Hey! Bit of a resurrection, but would I be able to get a set of 4x axle stand pads and a small jacking pad for collection at JDM combe/annual meet? Let me know if that's ok
No problem at all!
Do make sure you pester me for them at some point over the weekend, otherwise I will end up going home again with them
- HarSc (Mon Aug 23, 2021 6:45 pm)
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
"Rex" 2009-16
"Rex 2" 2014-
"Blue Rex" 2015-
Shall do! CheersIan.Mothersole wrote: ↑Mon Aug 23, 2021 6:41 pmNo problem at all!
