R3 Style LED Tail Lights for Your Series 1 RX8 NEW IN!
Rotary Specialist Mechanic
Has thanked: 565 times
Been thanked: 696 times
Re: R3 Style LED Tail Lights for Your Series 1 RX8 NEW IN!
Post by Shagrington » Sun Nov 27, 2016 8:23 pm
bunch1980 wrote:I want to for the safety aspect, as will look brighter and i think they react that bit quicker to, and look sharper, like the spyder 3rd led brake light is way better than stock for that. Similarly on motorbikes i have seems to make a big difference to being seen....
I was happy enough with the standard lights, but thought these do look better and more up to date. It was following Andy on the Scottish road trip last year with these fitted and comparing them to the others in the convoy with standard S1 lights that convinced me to get them. They are so much brighter and it is so much easier to see when the brakes are being applied.
former Club Treasurer 2010-18 (now finally retired - just need to get rid of hand over the bank stuff etc)
Delanor
Has thanked: 4 times
Been thanked: 64 times
Post by Delanor » Sun Nov 27, 2016 9:14 pm
Not forgetting they will last for X number of thousand hours - allegedly! [-o<
Rotary FX fender grills, Japspeed stainless exhaust, K & N filter, Kinetix slotted & dimpled discs, EBC Red stuff pads, DIY AC Delco D585 coil conversion, Magnecor leads, Stainless front & rear grills, HID main beams, LED tail lights, front side lights/front fogs.
TAILS360
Post by TAILS360 » Mon Nov 28, 2016 12:39 am
ive already had mine installed for about 3 months now
passed mot no bother... far brighter, and easy fit... even light up the side of the road bright red at night lol
Goobie
Has thanked: 20 times
Been thanked: 84 times
Post by Goobie » Mon Nov 28, 2016 3:35 am
Delanor wrote:I have already seen some OE fitted cars with a LED out in the rear light unit an Audi and a BMW - I bet those lights won`t be cheap to replace.
The same used to be said about HID's headlight bulbs, now replacements on the net cost the same as halogen bulbs at your local Halfords.
nightfire10
Has thanked: 367 times
Been thanked: 126 times
Post by nightfire10 » Sun Dec 11, 2016 5:41 pm
Essex Rotary wrote:We are pleased to announce that we now have in stock these excellent looking high quality LED tail lights to fit the Series 1 RX-8.
They are similer in style to the R3 lights everyone wants however they do not require any modification to the cars chassis (unlike the Original R3 lights) They also fit with the Series 1 Body Lines.
These high quality LED Tail Light clusters are styles to look like the Later R3 style tail lights. However unlike the R3 Lights these are designed to fit the Series 1 RX-8 chassis without need for modification.
Made to a high OEM Quality These units are a direct fit and feature ultra bright high intensity LED's for superior visibility over the standard bulbs found in the series 1 light clusters.
[youtube]https://www.youtube.com/watch?v=rOi1I6sjk5s[/youtube]
These units are a full conversion and require no modification or transfer of parts from your existing lights.
Simple to install, Just unbolt your original units and then bolt these in to place, no hassle and no fuss.
These Units come with the clear lens for superior visibility even during the day.
Priced at £249.99
These are now in stock and ready for delivery.
Quite fancy ordering these !is there any club discount ? cheers Steve
Hayward's bridgeported rebuild,595's,Tein coilovers with edfc,oil pressure and oil temp gauge pod's,lockwood front and rear grills,folding tow hook's,connect2
Nutwerlal
Post by Nutwerlal » Tue Dec 13, 2016 10:10 am
Hi All...sorry to be a bit of a numpty but I have received these lights and upon opening them I thought I get some instructions on fitting them...there wasn't any so can anyone help in terms of what I need to do in terms of connecting up please...I think the reverse and indicator bulbs on the old stock lights just slot into the new lights but not sure what to do with the 2 little connectors and the big flat one...sorry for not using the correct technical terms etc...
Many thanks
Nautam
Titanium Grey 231ps, 55 plate bought 2nd hand in Jan 2009
Running with Protek R, Blue LED interior lighting, yellow brake calipers, rotary shaped radio dial, led sidelights, new coils/leads fitted at 40k, K&N Air Filter, aero wiper blades, Refurbished powder coated super shinny silver stock alloys, uprated starter motor, LED Number Plate & Rear Lights, Alloy Petrol Cap
Delanor
Post by Delanor » Tue Dec 13, 2016 11:28 am
See here my post LED tail lights 3/4 of the way down.
bunch1980
Has thanked: 9 times
Been thanked: 16 times
Post by bunch1980 » Tue Dec 13, 2016 12:29 pm
I guess these be same, reverse and indicators are still not LED?
Delanor
Post by Delanor » Tue Dec 13, 2016 1:05 pm
No still not LED`s the same lights from what I can see they probably didn`t include LED`s there as they are both small bulbs/lenses but I have a LED bulb in the reversing light and the OE bulb in the indicator which seems OK.
mzivtins
Been thanked: 9 times
Post by mzivtins » Tue Dec 13, 2016 4:18 pm
Delanor wrote:If LED`s have one fault its that with a series of LED`s in a light unit when one fails they will look a bit naff and you will more than likely have to replace the whole unit, I have already seen some OE fitted cars with a LED out in the rear light unit an Audi and a BMW - I bet those lights won`t be cheap to replace.
like a missing tooth when smiling. seen this too on mercs look awful.
I have these lights, the build quality is very good. the plastics dont feel as good as OEM (cheaper with less glass content i assume) but that has f##k all to do with the lights being good or bad, they look GORGEOUS.
Delanor
Post by Delanor » Tue Dec 13, 2016 5:46 pm
Has anyone fitted LED indicator bulbs in these lights?
WhelanUK
Has thanked: 8 times
Been thanked: 18 times
Post by WhelanUK » Thu Dec 15, 2016 4:01 pm
Fitted mine with some telephone advice from Aston. I absolutely love them.
• Brilliant Black PZ • D585-R Coils • Magnecor Leads • Rear LED Lights • 13Black Mini Map • GROM Unit • Piano Black Trim • Cusco Front Strut Brace • Custom Steering Wheel • 13Black Engine Mounts • 20mm Spacers • Short Shifter • R3 Interior • AEM Intake • Toyosport Decat
nightfire10
Post by nightfire10 » Thu Dec 15, 2016 5:42 pm
WhelanUK wrote:Fitted mine with some telephone advice from Aston. I absolutely love them.
Was there any club discount when you bought them?
WhelanUK
Post by WhelanUK » Thu Dec 15, 2016 5:43 pm
Wasn't aware there was any club discount?!
nightfire10
Post by nightfire10 » Thu Dec 15, 2016 6:47 pm
WhelanUK wrote:Wasn't aware there was any club discount?!
thought most traders on here offer a club discount ? was hoping so ;) as i want to order some for my 40th lol
Essex Rotary
Forum Trader
Forum Trader
Post by Essex Rotary » Wed Dec 21, 2016 12:44 pm
These are now back in stock we also have some in stock with the smoked lenses.
Price will be the same as the clear units.
Please use the drop down menu to select you color and delivery choices before adding your selection to your shopping cart.
Place Your Order Here
Essex Rotary
Bringing Black Halo Racing Original Parts to the masses of Europe
Bringing you Idemitsu Racing Rotary Oils
Royal Purple Premix and Oils Stockist
Whatever you need we got it covered
Aston@EssexRotary.Co.Uk
Dove66
Has thanked: 21 times
Been thanked: 29 times
Post by Dove66 » Sat Feb 18, 2017 4:11 pm
Does anyone have a picture of their car with the smoked lens version fitted?
001/400
Delanor
Post by Delanor » Sat Feb 18, 2017 4:20 pm
Smoked on the left - black on the right.
Dove66
Post by Dove66 » Sat Feb 18, 2017 4:37 pm
Delanor wrote:Smoked on the left - black on the right.
Thanks for that. Do you have a picture without the brake lights on?
001/400
Post by Shagrington » Sat Feb 18, 2017 6:32 pm
Here is one of mine with the lights off ...
nightfire10
Post by nightfire10 » Sat Feb 18, 2017 6:59 pm
Clear one bit misted due to change of temp
PaulAV
Been thanked: 44 times
Post by PaulAV » Sat Feb 18, 2017 7:38 pm
That's just greedy having two sets, smoked and not smoked, personally I think I prefer the smoked.
Led side lights, blue Led interior and puddle lights, custom stainless steel grills, billet front grill, 585 coils, high spec rear drop links, mini remap, HME engine rebuild at 30k Remus exhaust, racing beat revi intake
Essex Rotary
Forum Trader
Forum Trader
Post by Essex Rotary » Tue Feb 21, 2017 12:47 pm
We have smoked and clear in stock along with the smoked third brake lights arriving tomorrow all going to plan.
Essex Rotary
Return to “Essex Rotary”
