NEW Essex Rotary Sump Baffle Plate
Rotary Specialist Mechanic
Essex Rotary
Forum Trader
Forum Trader
Been thanked: 18 times
Post by Essex Rotary » Fri Jan 29, 2016 10:19 am
Designed, built and tested by Essex Rotary, this brand new product has been over 12 months in the prototype and testing stages. After extensive road and track testing on our own cars we are now happy to release this brand new part for sale.
Essex Rotary has worked hard to design a baffle plate that serves several purposes. While still retaining a simple design to allow it to be used in both OEM and aftermarket oil pans.
Key features are;
> Aids in removing micro air pockets (foaming) from oil returning to the sump from the engine.
> Helps engine cooling due to greater heat transfer from the reduced foam oil
> Helps prevent oil surge in high "G" cornering.
> Simple to install.
> Track Tested
These production plates are the next step on from our early hand built units we tested. Made from high quality Aluminium. We are offering a special introductory offer price for a limited time only of £34.99. In stock now and ready to ship.
These are in stock and ready for delivery,
Orders yours from our Web Shop at http://www.essexrotaryspecialists.com/s ... ary-parts/
Essex Rotary
Bringing Black Halo Racing Original Parts to the masses of Europe
Bringing you Idemitsu Racing Rotary Oils
Royal Purple Premix and Oils Stockist
Whatever you need we got it covered
Aston@EssexRotary.Co.Uk
Liam22
Has thanked: 22 times
Been thanked: 43 times
Re: NEW Essex Rotary Sump Baffle Plate
Post by Liam22 » Fri Jan 29, 2016 1:41 pm
Sold!
Sent from my LG-H815 using Tapatalk
Liam22
Post by Liam22 » Fri Feb 05, 2016 2:02 pm
[oops, that was meant to be a PM]
Antz41
Been thanked: 13 times
Post by Antz41 » Mon Feb 29, 2016 9:13 am
Have you got these in stock ready to ship?
Team Altima / AlphaSport's 2004 Winning Blue 231 Race Car
Building a NA 231ps for a popular Saloon Car Championship in 2016! All help and assistance welcome!
StreetDragster
Has thanked: 14 times
Been thanked: 50 times
Post by StreetDragster » Tue Apr 26, 2016 7:43 am
Hi guys,
Can you confirm that when you install this plate you are supposed to leave the OEM baffle out?
I'm fitting it onto a Greedy sump, and at the moment the OEM baffle will not fit with the plate installed, the baffle protrudes into the engine cavity.
Item 10-406A
Matt
Essex Rotary
Forum Trader
Forum Trader
Post by Essex Rotary » Tue Oct 04, 2016 10:44 am
I am sure we have answered this already not for the record and future reference yes the Large plastic OEM Baffle will need to be removed when installing our plate, In some sumps there is also a "waffle" style plate that sits on the opposite side of the sump this can be retained however the very tops of the studs my need cutting down a little.
Essex Rotary
Return to “Essex Rotary”
