Forge Action Day 2018 | Saturday 8th September | Castle Combe
From non-stop track action to huge club displays and some of the biggest names in the performance scene, this is not to be missed!
Track Action / Drifting Demos / Passenger Rides / RX-8 Club Stand / Show & Shine Competition / Forge Motorsport Exhibitor Village
Tickets available in the Club shop now!
Royal Purple Max-Tuff Assembly Lube now available.
Rotary Specialist Mechanic
Essex Rotary
Forum Trader
Forum Trader
Been thanked: 18 times
Post by Essex Rotary » Tue Oct 29, 2013 6:45 pm
Essex Rotary are please to announce the arrival of Royal Purple Max-Tuff Synthetic Engine Assembly Lubricant. We have assembled several engines using this stuff now and can tell you its thick thick thick. providing amazing lubrication compared to normal engine oil when rebuilding your rotary engine.
Now made famous by those keeping up with the Aarron Cake Cosmo Sports Restoration on youtube
image for illustration purposes only
Max-Tuff is an ultra-tough, synthetic lubricant. It’s designed for engine builds and repairs, specifically crankshaft, camshaft and rod bearing assembly. Max-Tuff utilizes unique, synthetic molecules that adhere to metal surfaces to create a formidable, load-bearing physical barrier between surfaces. This minimizes the metal-to-metal contact and wear in boundary lubrication conditions, and provides excellent protection against rust and corrosion of both ferrous and nonferrous metals.
PERFORMANCE ADVANTAGES
  • Greater wear protection
  • Clean, efficient equipment
  • Extends equipment life
  • Compatible with conventional mineral and synthetic oils
  • Non-foaming
  • Outstanding rust / corrosion protection
  • High temperature service capability
Price: £24.99 per 8ox bottle
Contact us for a postage quote. (will soon be available on our website)
This should be enough to do 2-4 engines dependent on how much you gloop in during assembly.
Essex Rotary
Bringing Black Halo Racing Original Parts to the masses of Europe
Bringing you Idemitsu Racing Rotary Oils
Royal Purple Premix and Oils Stockist
Whatever you need we got it covered
Aston@EssexRotary.Co.Uk
Return to “Essex Rotary”
