Does anybody know whether these are stocked anywhere in UK? I've found a website in US which sells them, but by the time you pay for delivery etc, they cost £40-50 a pop -
To be honest if you are planning on keeping the car I find you get better touch up paint by getting a spray can made up at a local car paint factors, the paint is good quality and thinner to apply than a stick I get a 400 ml can for £11.75 it cost a bit more but you get a lot more paint.
1st Brilliant Black 190. 2nd Brilliant Black PZ. 3rd Strato Blue 230. 4th Crystal White 40th Anniversary. Rotary FX fender grills, Japspeed stainless exhaust, Cosworth Air filter, Kinetix slotted & dimpled discs, EBC Red stuff pads, Ryan Rotary MK11 coils, Magnecor leads, Stainless front & rear grills, HID main beams, LED tail lights, front side lights/front fogs.
As luck would have it, i've actually got two of the Mazda rattle cans for sparkling black! Not sure if you're able to post rattle cans, but I usually buy mine online so I assume so. If you want one or both of these and that would help out I can let them go
Some guy from oooop north | Harry | Membership Secretary 2022-2024
- My Main RX-8 R3 [MHZ 3800] thread here
- My Project Banana thread here
- My Project 3 Rotor thread here
- My engine disassembly shenanigans here
I have bought them online but the last time I did that my can of Mazda Crystal White arrived with a distinct hint of blue so I buy locally now.
Just like Velocity Red Sparkling Black fade slightly into Sparkling Slightly Greyed Black. You wont go far wrong with those cans from Harry but wioll probably require a can of clear lacquer too.
Feb 2020-May 2023 RR54 AJR VR 231 Supercharged & Modified for Track
I could get you a touch up bottle for any colour you wish.
We have an Octoral paint mixing system at work.
Be about £20 for the bottle which comes with a fine brush enlosed in the cap.
These users thanked the author thatturborx8 for the post:
Club Information Coordinator
Yellow S1 with MS Body kit 2006-2010
Blue S1 Stock with Greddy turbo 2010-2014
Red S1 2015-2017
Blue S1 2017-2018
Black R3 2018-Today
Many many others lost myself counting
Yes,i can mix any paint you wish,but bare in mind crystal white will be two stages,one paint and one pearl.
We can mix them together but it will not be %100
Red S1 2015-2017
Blue S1 2017-2018
Black R3 2018-Today
Thanks, it’s only for a very small area on the bottom of the wheel arches which had surface rust., actually now wondering if I could just use any white paint for that now…
I'd be keen on a mixed velocity red can to touch up a few tiny chips, if you can oblige Silviu? Thanks.
Again,same with VR,you will recieve two tones.
Pm me and i will get it sorted
Red S1 2015-2017
Blue S1 2017-2018
Black R3 2018-Today
Be aware the VR comes in many different shades, even from the factory and you can get a variation in shade, even from one end of the car to the other.
Back when the cars were new, we had two members with VR cars in the Essex area meets.
If they parked next to each other, one facing in, one facing out, then from one end they looked a perfect match, while from the other end, one was clearly more orange, while the other was heading towards pink.
It was their little party trick to deliberately park like that and show people.
Add a few years, with cars parked a particular way around in the sun, and who knows how many shades result.
I recall someone taking their fuel filler flap into the paint supplier for a custom matching, having replaced the driver's side front wing with a VR from another car, that was clearly not the same. After going through the paint shop, the result was worse. He really should have offered-up that filler cap to the bonnet and door, to see the difference first.
VR for the RX8 is only standard VR but the paint has a few versions that have changed depending on yearsm
For touch ins there should not be an issue.
Issue becomes obvious when multiple panels are painted and no blending techniques are used.
The 8 which i bought for myself recently has a quarter in a different shade,the front bumper in a different shade, the boot in a different shade and the car in a different shade therefore i will paint the full thing
Red S1 2015-2017
Blue S1 2017-2018
Black R3 2018-Today
