Blue print yir wankel
RobinPZ72
Has thanked: 67 times
Been thanked: 32 times
Post by RobinPZ72 » Thu Oct 25, 2018 9:35 am
Ok yes this is probably thought of a waste of time to some, but if done correctly the gains can be eye opening!
I've noticed the massive difference outputs std and even with the same ish tuned engines! This can mostly be due to tolerances of the spinny things being out and yes different oils, fuel, breathing and farting kits and sparky things!
Has anyone just got the engine just balanced and gas flowed?
Does anyone offer crank and rotar balancing?
I'm not saying I know anything about the rotary engines and clearly on here there's guys that do, but I can say I was ok at tuning 2 strokes and other engine's!
Robin
Dazza44
Has thanked: 156 times
Been thanked: 70 times
Re: Blue print yir wankel
Post by Dazza44 » Thu Oct 25, 2018 9:45 am
U might have trouble getting the crank balanced, or even finding it
Has thanked: 526 times
Been thanked: 807 times
Post by 13Black » Thu Oct 25, 2018 9:58 am
Speak to Rotary Revs about getting a crank etc balanced. But don't expect them to tell you who does it as there's a bit of know-how involved when it comes to doing rotaries that most engine balancing outfits would need to learn.
They used to outsource the process to the states, to give you an idea.
RobinPZ72 (Thu Oct 25, 2018 11:34 am)
Conan
Has thanked: 56 times
Been thanked: 733 times
Post by Conan » Thu Oct 25, 2018 10:03 am
U might have trouble getting the crank balanced, or even finding it ImageImage
The shaft does in fact have a couple of cranks on it
It's just that rotors are hung off the cranks rather than con rods
Conan
Post by Conan » Thu Oct 25, 2018 10:32 am
Robin
You are correct in your way of thinking
I had my engine built and blu printed by Rotary Revs and recorded 195 BHP at the hubs which equates to 228-231 at the crank (2nd highest recorded at the time)
If you want to see what that drives like look at the video at the start of the PZ suspension group buy
RobinPZ72 (Thu Oct 25, 2018 10:39 am)
RobinPZ72
Post by RobinPZ72 » Thu Oct 25, 2018 11:05 am
Bit sad, but I could watch that all day!
Robin
RobinPZ72
Post by RobinPZ72 » Thu Oct 25, 2018 11:14 am
Does yir rotors just float? Hey I know my terminology is a bit not quite PC, but I do enjoy seeing what things are call for the same thing or corrected!
Robin
Dazza44
Post by Dazza44 » Thu Oct 25, 2018 11:59 am
Robin
I was just having a giggle, ignore me, crankshaft = eccentric shaft
These users thanked the author Dazza44 for the post:
RobinPZ72 (Thu Oct 25, 2018 11:59 am)
RobinPZ72
Post by RobinPZ72 » Thu Oct 25, 2018 11:59 am
I'm wanting to eventually rebuild an engine for my car, so just seeing what's what and looking to keep it as much my own work as possible! This is a long-term thing and lots of learning to be had! 1st thing is strip and draw the engines, so remember if anything needed drawing wise for club members please ask as keen to help! Just don't ask for the rotary housing as this will take time before I'm happy with tolerances etc.
Robin
Holly poop
Has thanked: 5305 times
Been thanked: 2428 times
Post by ChrisHolmes » Thu Oct 25, 2018 7:18 pm
Robin
That must have cost a pretty penny considering the hours of labour involved measuring and the large pool of components necessary to select from in order to maximise / minimise clearances as relevant for the parts being assembled to each other.
Bridge Ported 231
MazdaSpeed skirts
Short shifter
