Methonal injection
Project-RX8
Methonal injection
Post by Project-RX8 » Wed Jul 04, 2018 11:25 am
Does this net any gains on a RX8 or not advised?
I have a spare kit, i could install.
Goobie
Has thanked: 36 times
Been thanked: 312 times
Re: Methonal injection
Post by Goobie » Wed Jul 04, 2018 11:33 am
Only with forced induction I beleive.
Project-RX8
Post by Project-RX8 » Wed Jul 04, 2018 11:46 am
Yeah the main gain would be with FI.
A lower intake temp and a slight boost in octane would surely help all setups?
I guess the question is, would the small gain outweigh the weight of the kit with a full tank? possibly not.
Phil Bate
Been thanked: 169 times
Post by Phil Bate » Wed Jul 04, 2018 11:51 am
It would allow you to advance the ignition timing for more output however tuning the PCM for this could be tricky depending on the system you have. The benefits are outweighed by the cost and effort rather than the weight of the kit, for an NA setup.
Has thanked: 23 times
Been thanked: 141 times
Post by 350matt » Thu Jul 19, 2018 9:47 pm
anybody tried E85 in these things?
wiggles
Has thanked: 82 times
Been thanked: 89 times
Post by wiggles » Thu Jul 19, 2018 9:52 pm
E85 requires about 30-40% more fuel compared to petrol so you would be doing 100 miles to a tank probably :lol:
Been thanked: 786 times
Post by PeteH » Fri Jul 20, 2018 1:09 am
And you can't raise the compression, or easily boost, so E85 doesn't actually help a lot.
Post by 350matt » Sun Jul 22, 2018 4:13 pm
It does help increase the knock limit though
and these triangles of wonder are certainly limited by ignition timing
Has thanked: 526 times
Been thanked: 807 times
Post by 13Black » Sun Jul 22, 2018 5:51 pm
With the rich AFR requirements we already have running petrol - considering how much more E85 needs to be injected for the same power... would there be any combustion chamber volume left for oxygen :lol:
Has thanked: 457 times
Been thanked: 1837 times
Post by warpc0il » Sun Jul 22, 2018 6:45 pm
Hydraulic lock does even more damage than premature ignition
TheManc
Has thanked: 21 times
Been thanked: 129 times
Post by TheManc » Sun Jul 22, 2018 7:03 pm
If you decide to sell i might be interested . Devils Own or AEM etc
