PZ exhaust - Worth anything?
Has thanked: 23 times
Been thanked: 142 times
Post by 350matt » Fri Sep 22, 2017 6:54 am
Peeps
I see that the PZ exhaust is often mentioned as being a good option for a nicer exhaust note? is it worth anything in cash and power over the stock exhaust? as I've been told that its a full Stainless system? is it any larger diameter? Is it louder than stock ( which would indicate its better flowing less back pressure)
just made up a new catted pipe from my old ghetto decat pipe and a 200 cell cat I had lying around so its now smelling much sweeter just the rest of the exhaust isn't wonderful
Been thanked: 786 times
Re: PZ exhaust - Worth anything?
Post by PeteH » Fri Sep 22, 2017 7:40 am
Is that a high temperature cat you've used? Don't expect a normal cat to last long in a rotary.....
Conan
Has thanked: 56 times
Been thanked: 733 times
Post by Conan » Fri Sep 22, 2017 7:53 am
The PZ exhaust is not what you personally will be looking for.
mrspiller
Has thanked: 159 times
Been thanked: 411 times
Post by mrspiller » Fri Sep 22, 2017 9:53 am
350matt wrote:Peeps
I have a de catted PZ and like the noise it makes , a bit more of a rasp than stock , much quieter than say a toyo or the like
zippyonline
Has thanked: 48 times
Been thanked: 84 times
Post by zippyonline » Fri Sep 22, 2017 11:29 am
The PZ exhaust I think is actually heavier than OE when I weighed it. I say think, I didn't weigh the OE for some reason, but looked that up online - and the number was smaller than the PZ exhaust I weighed.
It is stainless, but same dims as OE. It is as far as I can tell a Scorpion exhaust, but with tips that say "Prodrive" instead.
Post by 350matt » Fri Sep 22, 2017 12:16 pm
yup motorsport hi flow spec - ceramic element
Post by 350matt » Fri Sep 22, 2017 12:18 pm
I won't ? :?
V8 Power
Has thanked: 191 times
Been thanked: 410 times
Post by V8 Power » Fri Sep 22, 2017 1:14 pm
Having had a PZ I would say it just sounds different, more raspy. No performance gains though.
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
RRP Coils MSD leads
Has thanked: 266 times
Been thanked: 580 times
Post by Dr. FrankenRex » Fri Sep 22, 2017 2:05 pm
I've got one in the garage, not an overly light piece of kit, which would suggest there isn't much to be gained performance wise.
Looks nice, but that's about it...
Eddie_r32
Has thanked: 44 times
Been thanked: 157 times
Post by Eddie_r32 » Fri Sep 22, 2017 5:14 pm
I too have one in the garage, what is good about them is the baffles don't die when you have a decat due to pops and bangs, they pass noise regs on track and look good
2007 Galaxy grey 231.
