Peak calculated load values required
Phil Bate
Has thanked: 36 times
Been thanked: 169 times
Post by Phil Bate » Fri Jan 10, 2014 1:46 pm
If anyone has any logs handy please could you post the maximum engine load (in %) you see under WOT? If you have it, the MAF reading with IAT would be handy but not essential.
I also need to know if this is with a standard or ported engine, and am only interested in standard intakes and ECUs that have not been remapped.
Thanks in advance
Phil
Phil Bate
Re: Peak engine load values required
Post by Phil Bate » Sat Jan 11, 2014 6:20 pm
Bump! C'mon, someone must have some WOT logs! I would like to see if any standard engines are hitting the 100% calculated load ceiling
i-CONICA
Post by i-CONICA » Sat Jan 11, 2014 6:24 pm
I could have a go next time I'm out (later probably) but my engine is probably below recommended compression so I do to know if that matters to you..
Phil Bate
Post by Phil Bate » Sat Jan 11, 2014 6:29 pm
Any will do, I'm just after the peak calculated load value during a WOT run, plus maf and iat if available but only a nicety really. Obviously do not break the law or drive unsafely and don't go out of your way to do it. There must be some track day warriors that have some logs knocking about :)
Nerdstrike
Been thanked: 31 times
Post by Nerdstrike » Sat Jan 11, 2014 6:46 pm
I was playing about today, and Torque offers up two separate load values, relative/absolute. Which are you after? (accepting that I've already given you everything I've got).
Phil Bate
Post by Phil Bate » Sat Jan 11, 2014 6:55 pm
Didn't realise it was called something else in Torque - whichever one is parameter id 0x04 (possibly relative?) I neglected to say calculated load in the first post, I'll amend the title
i-CONICA
Re: Peak calculated load values required
Post by i-CONICA » Sat Jan 11, 2014 9:52 pm
Phil, got it. Several instances of wide open throttle (displayed in the log too) and the calculated and actual load values.
It's in igf format though, and I can only email it from my phone so I'll need your email address.
Phil Bate
Post by Phil Bate » Sat Jan 11, 2014 10:14 pm
Pm-d :)
i-CONICA
Post by i-CONICA » Mon Jan 13, 2014 11:22 am
Did you get my video?
Phil Bate
Post by Phil Bate » Mon Jan 13, 2014 12:38 pm
Yes thanks mate haven't watched it just yet as I'm away with work at the moment. I have got WiFi here now so will have a look this afternoon
Phil Bate
Post by Phil Bate » Mon Jan 13, 2014 2:41 pm
Well I had hoped I'd get more response than that, however after much more research and thanks to Nerdstrike and i-CONICA I have pretty much sussed this out. Cheers guys
Will66
Colour: Metropolitan Grey
Has thanked: 8 times
Been thanked: 47 times
Post by Will66 » Mon Jan 13, 2014 3:30 pm
I was trying to find some of my old logs from my EFIdude logger but I could find none. Once I am underway with my project I will get plenty of data.
