DIY tuning/remapping with mazdaEdit and Openport
Has thanked: 456 times
Been thanked: 1829 times
Re: DIY tuning/remapping with mazdaEdit and Openport
Post by warpc0il » Tue Jan 22, 2019 8:43 pm
This would also be a good time to mention that not all "mini-maps" are the same and therefore, just because a car has been "mini-mapped" for D585's by one vendor, doesn't mean it is set the same as another vendor would have done - it's not just a simple "switch".
Time is also a factor, in that many vendors have learnt over the years and what they would do now could be significantly different to what they were doing nine years ago.
exiled--viking (Tue Jan 22, 2019 9:07 pm)
Phil Bate
Has thanked: 36 times
Been thanked: 169 times
Post by Phil Bate » Wed Jan 23, 2019 12:45 am
Indeed. Where available, using the specifications from the coil manufacturer is key however it's quite trivial to run the coil and watch the current draw under charging to establish the ideal dwell figure if not available. I always check that it gets a chance to fully discharge too - there's no point loading the coils up only for them to be interrupted half way through a spark for the next charge event.
Duty cycle is a bit of a shot in the dark if you don't have it so you have to make a call taking into account the design of the coil, how beefy it is and what heat management it has in comparison to similar units with known values. But that said, I think all our trusted aftermarket coil suppliers have detailed technical specs for their coils these days and supply tables to suit.
It has moved on a bit from when we were all using that same GM table for every LS2 clone :D
13Black wrote:
Tue Jan 22, 2019 6:53 pm
if you ever get round to lighting your scope up again
This does need to happen - as soon as I get my new multi-channel scope I'll be calling for samples :D
Paul_13
Has thanked: 86 times
Been thanked: 162 times
Post by Paul_13 » Sat Nov 09, 2019 5:52 pm
Has any one got the Pro version?
Interested to know what other features are available over the Personal version
Post by warpc0il » Sat Nov 09, 2019 6:05 pm
I thought the Pro just allowed you to use on multiple cars, rather than only the one.
Ryan Rotary Performance
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Has thanked: 183 times
Been thanked: 646 times
Post by Ryan Rotary Performance » Sat Nov 09, 2019 6:06 pm
The only difference is (as far as I know) is that its not locked to one VIN.
Paul_13
Post by Paul_13 » Sat Nov 09, 2019 6:42 pm
Fair enough. I read on an American forum that there was extra features - which I obviously took with a pinch of salt
Has thanked: 23 times
Been thanked: 142 times
Post by 350matt » Sat May 09, 2020 10:13 pm
So then Gents
I'm about to delve into tuning my Rexi and have a couple of questions
1) do I need to buy the tactrix OBD doofer directly form tactrix in San Francisco ? As it seems to be sold by a number of people such as
as the way things are I doubt that much will be coming from USA fro the foreseeable
2) As I gather the system is all MAF based so I'm assuming its similar to other Denso systems I've used in the past, where get the MAF scaling right 1st and then adjust the target lambda map and increase the load sites to ensure no clipping ?
bigpete8
Has thanked: 130 times
Been thanked: 121 times
Post by bigpete8 » Tue May 12, 2020 1:30 pm
That one is from Wuhan so not much better.....
Post by 350matt » Tue May 12, 2020 1:49 pm
possibly not
just wondering how careful do I have to be with where I source the electronics as chances are Tactrix probably buy them from China anyhow....
Sponsor Trader
Sponsor Trader
RX-8: Supercharged
Post by Ryan Rotary Performance » Tue May 12, 2020 7:16 pm
I'd go for Tactrix, the Chinese ones are ok for mini maps and "work" for tuning but you really need to be in 4th to get the resolution you need where as tactrix is fine in any gear.
Impossible to VE tune with the Chinese clone too
Post by 350matt » Tue May 12, 2020 10:15 pm
thanks for that Carl
so worth the extra then
and I'll need to VE tune for the supercharger install
V8 Power
Has thanked: 192 times
Been thanked: 414 times
Post by V8 Power » Wed May 13, 2020 6:10 am
What is VE tune?
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
RRP Coils MSD leads
Post by 350matt » Wed May 13, 2020 8:04 am
V8 Power (Wed May 13, 2020 8:33 am)
Post by 350matt » Sat May 30, 2020 6:47 pm
OK tactrix is here
mazda edit all registered
let the tuning commence!
so to begin with I've turned off the secondary air DTC's so I can remove the air pump and save a bit of weight
I've also lowered the fan temp switch points
and leaned off the rich areas of the fuel maps ( 12.4 AFR vs the 11.3 that was there)
I'm now presuming I'll need to take some logs and re-shape the MAF curve so it actually follows the new target lambda
slightly dissapointed there is no injection timing table
and dare I advance it at all? I think I may borrow a knock box from work to see what sorts of noises it makes on the stock timing and go from there I guess
Has thanked: 198 times
Been thanked: 696 times
Post by qwakers » Sat May 30, 2020 7:11 pm
timing advance on rotaries is very high risk and gives very little to no benefit.
Post by warpc0il » Sat May 30, 2020 8:18 pm
:whathesaid:
Paul_13
Post by Paul_13 » Sat May 30, 2020 8:22 pm
High risk, but if you compare the USDM Ignition map to UKDM there is a difference. Slightly advanced in some areas
Post by warpc0il » Sat May 30, 2020 8:27 pm
That would be strange as the US pump fuel is, in general, a lower octane than the UK. (higher numbers but a different scale)
There must be other factors at work here, so I wouldn't go just tweaking the advance to experiment.
Think of the rotary knock sensor like the low oil warning light, by the time it activates the engine is already damaged.
This is totally different to piston engines that may be quite happy to dynamically advance until knock is sensed, then just back off a bit.
Post by 350matt » Sat May 30, 2020 10:24 pm
is there any information out there on knock thresholds , pressure rise over time ?
any combustion info at all?
Post by 350matt » Sat May 30, 2020 10:25 pm
interesting do you have the two maps you can post up?
Paul_13
Post by Paul_13 » Sat May 30, 2020 10:35 pm
They're on the laptop, I'll have to have a look tomorrow.
Post by 350matt » Sun May 31, 2020 1:25 pm
much obliged
Post by 350matt » Sun Jun 07, 2020 3:38 pm
OK so I've been playing with mazda edit for the last few days, quite an handy tool isn't it?
so far I've truned off the DTC for the air pump so that can be removed , leaned off the fuel maps at the top and richened them up mid range and then rescaled the MAF curve to minimise the LTFT so the output lambda follows the target
car is certanly feeling perkier
about to try a little extra spark top -end..... only 2° so 32 at 9K instead of 30
one question how do you get the dyno power curve feature to work with the ME logger ? as I think I have all the settings in correctly but have yet to record a believable curve?
about to try the auto logging feature with the SD card to save running the laptop all the time
Paul_13
Post by Paul_13 » Sun Jun 07, 2020 3:45 pm
much obliged
I Did have a look and I think I must of been looking at the r3 ignition tables
Post by 350matt » Sun Jun 07, 2020 4:01 pm
so what were the R3 tables ? as its essentially the same engine
