Fuel pumps and injectors
- Will66
- Been thanked: 60 times
Re: Fuel pumps and injectors
It looks like the same pump that MRP are selling (see the link in their thread above), if it is the same one then it should be a good bet. It's within pennies of the MRP price once you include the RX8OC discount.
Certified Tarmac Terrorist! Evading the colour police since March 2013
- duckula67
- Has thanked: 9 times
- Been thanked: 10 times
How do you get the existing pump out without a special tool?
Mods:Black wheels.Start button.AEM CAI.D585Coils.EBC ultimax discs.Yellowstuff pads.Racing fluid.Stainless brake&clutch lines,Stainless vents.Cobra Catback.Bonnet struts.Auxmod.Custom Gauge pod.Eibachs&Fast road setup.Shortshift.Sohn adapter.Comp clutch&Flywheel.N/plate offset.Red calipers.Leather Gaiter.LEDs in&out.Smoke LED rear lights.LED 3rd brake.
- WildMan10
- Has thanked: 16 times
From the service manuals I see that the RX8 has a saddle tank with the pump in one side and uses a siphon to get fuel from the other tank.
How does this work if a high flow pump is fitted? For example, does the siphon work with the higher flows, do the aftermarket pumps cater for this or is the fuel in the other side useless?
Ian
- Will66
Depends on if the syphon has been modified to cope with greater flow or not. Arnie_O had problems with his fuel pump and he modded the syphon according to a guide on RX8 club. I'd link to it but I am on my phone.
- WildMan10
Removing fuel pump capduckula67 wrote:How do you get the existing pump out without a special tool?
Ian
- Arnie_O
- Been thanked: 15 times
Your still going to need a fuel pump tool, plus a rattle gun helps.
There are two black plastic tabs that you need to brake off to allow you to undo the ring
Am sure I got a guide so ware
Royal Purple 2 Cycle Premix
- duckula67
ah, ok. basically plumbing tools then.
cheers
cheers
- duckula67
Just read the description of this:
http://www.ebay.co.uk/itm/WALBRO-255-FU ... 415f512bf4
"Note: The OE siphon assembly cannot take the elevated relief pressures as it stands. The pop-off valve on top of the syphon must be melted on with a hot piece of metal or something similar to keep it in place."
anyone done this, know what they are on about?
- Arnie_O
It's not plumbing tools, its a proper fuel pump sender removal tool.
And yes rear back in this thread for info
- duckula67
the US guide mentions a plumbers adjustable jaw wrench (channel locks)
