Big thanks to RR
http://www.rotaryrevs.com
ChrisHPZ
Has thanked: 1 time
Big thanks to RR
Post by ChrisHPZ » Sat Sep 08, 2018 3:50 pm
Just got my PZ back today after a full gold rebuild and street port. Big thanks to Josh for sorting her out and going through everything with me today..
Just need to granny drive it now for the next 750-1000 miles until I can give it the full beans 👍
Great service from the lads at RR.
2007 PZ in Brilliant Black - XCarLink Bluetooth adapter, LED “Angel Eye” side lights.
Full Gold Rotary Revs engine rebuild with street port :thumleft:
Dazza44
Has thanked: 158 times
Been thanked: 111 times
Re: Big thanks to RR
Post by Dazza44 » Sat Sep 08, 2018 3:58 pm
happy days ahead then dont RR recommend 1.5k to run in now.
Sent from my SM-G920F using Tapatalk
njkmr
Has thanked: 45 times
Been thanked: 59 times
Post by njkmr » Sat Sep 08, 2018 4:39 pm
Its gonna be a long haul without a beep beep...!
Think you need a run to Cornawall and back to Inverness to get them miles over with.
Are you getting it on the dyno to see what it puts out once its run in?
ChrisHPZ
Has thanked: 1 time
Post by ChrisHPZ » Sat Sep 08, 2018 5:04 pm
Documentation says 750 miles but Josh said 1k today and have it back to them for an oil change etc.. then am good to give it a damm good thrashing :)
Tempted to dyno it once I’ve changed to the RR D585 coil kit in a few months plus had a new clutch fitted as part of the build so want to make sure everything beds in fine before I do.
njkmr
Post by njkmr » Sat Sep 08, 2018 8:33 pm
Yeh would be good to see what you got from the rebuild.
Keep us posted if you do.
Ta
Has thanked: 2570 times
Been thanked: 908 times
Post by ChrisHolmes » Sat Sep 08, 2018 10:24 pm
Good idea but use the A roads not motorways as constant load and speed are the enemies of a newly built engine.
Toyo SS Catback
SS Strakes
Custom Sat Nav 3 Gauge install
Meister Zeta R Coilovers
Whiteline ARBs F&R
Slotted & Dimpled Discs F&R
Mintex 1144 Pads F&R
Full OE Aero Kit
Revolution Alloy Front Strut Brace
Lockwood SS Grills
Passenger Footrest
Lambo doors
Original engine 86000 smiles (169.7 rwhp) and then it died!
Own build Steet ported engine fitted Feb 2018 and running sweet as nut
ChrisHPZ
Has thanked: 1 time
Post by ChrisHPZ » Thu Sep 13, 2018 7:42 pm
150 miles down... man this is going to take an age.. so tempting to go above 5k but trying to be a good boy :)
May need to drop it back as the clutch is squeaking on idle, if I push in the peddle it stops. You can also hear it when driving but no issue with it in gear.. bedding in maybe?
Has thanked: 13 times
Been thanked: 62 times
Post by 350matt » Fri Sep 14, 2018 9:56 pm
I found that when I replaced my clutch release bearing when my lump was out it still squeaked....
however about 2K miles later it shut up and and stayed shut up , well so far anyway
Pensive
Has thanked: 28 times
Post by Pensive » Sat Sep 15, 2018 9:00 pm
ChrisHPZ wrote:150 miles down... man this is going to take an age.. so tempting to go above 5k but trying to be a good boy :)
Mine did that after an engine swap. It’s never stopped. Annoys the hell out of me....
Sent from my iPad using Tapatalk
ChrisHPZ
Has thanked: 1 time
Post by ChrisHPZ » Sat Oct 20, 2018 10:51 am
730 miles down... almost there now.. had Josh @ RR take a listen the other day to the clutch squeak. Seems it may need a new bearing but it will be fine for now.
Can’t wait to get the beeps back in my life and try out this street port 😀
Return to “Rotary Revs”
