Front rotor:
5.6
5.6
5.3
Rear rotor:
5.2
5.4
5.2
Some people may recognise this car from the club before, let me know if so and the story behind it (I've found some old forum posts)
It's fair to stay my spannering skills have significantly improved during my ownership so far
Oil (Castrol Magnatec semi synthetic 10W40)
Oil filter (Crosland Halfords special)
Air filter (K&N panel)
Transmission oil (Comma of the correct grade)
Diff oil (Motul of the correct grade)
Spark plugs (the usual NGK affair)
Cabin filter (Febi)
Brake fluid (DOT 4)
Genuine new to my PZ mats
Xenon number plate bulbs (Halfords)
Offside rear drop link (Febi)
Polished headlights (Aldi do everything)
Replacement footrest (mine was missing for whatever reason)
Power steering issue resolved (Forscan reset)
Xenon sidelight bulbs fitted (Halfords)
Front and rear brake pads (Mintex)
Nearside oil cooler lines replaced (OEM)
Hitachi ignition coils (possibly a controversial choice
Magnecor ignition leads (replaced NGK leads)
Rebuilt OSF brake caliper
Handbrake gaiter
Gear gaiter
Varta N72 EFB battery
AC regas
Shimmed SSV
Magnetti Marelli tailgate gas struts
Tailgate wiring repaired rather than taped
Drivers side carpet repaired
Leather seats DIY refurbed
Re-glued the boot seal
Not to forget all of the little jobs like the wheel arches being fitted properly, replacing broken trims, replacing the dead interior bulbs in the glovebox and ash tray and all the other cosmetic bits (a lot to mention, probably easier to ask
Finally the last picture taken - one from a local meet near Daventry last Saturday:
