LC05VRY - 2005 Strato Blue 231
- ChrisHolmes
- Has thanked: 5611 times
- Been thanked: 2570 times
Re: LC05VRY - 2005 Strato Blue 231
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Yorindesarin
- Been thanked: 377 times
I need to decide wether I want my number plate mounted somewhere similar to that or far lower down... Lower down is a bit more appealing to me but produces issues in secure mounting. :/
The Red 8:
Racing beat Revi, Tein street basis z coilovers, RRP Mk2 Coils (and one Mk3), Stock catback, Cruise Control (Zoom Zoom).
- Pingping010101
- Has thanked: 162 times
- Been thanked: 75 times
LC05 VRY is officially uneconomical to repair due to rust.
This may be why only one sill was replaced - Chris confirmed similar adhesive used on both sideskirts, despite one being removed to replace the sill and the other apparently being 'untouched'. It appears that the seller knew exactly what was going one, hence the sale.
I am now considering whether to break the car for parts completely, and restart with an alternative, hopefully good car or to swap the parts over to a broken one and try and start again. Although I'm not sure as to what the total value of the broken parts would be, it'll likely be cheaper to buy a good one than to swap the parts and rebuild the engine.
Any ideas on values for the following? (Parts wont be available until December)
Vertical door hinges
Full genuine mazdaspeed front bumper and side skirts (repair to one)
Mazdaspeed rear diffuser
Mazdaspeed oil cooler ducts
Carbon fibre bonnet
Carbon fibre bootlid
Carbon rear trunk lid
R3 sfyle e/rotary rear led lights
Rear adjustable brace in boot ( rear strut brace )
321Ti 3" manifold back system
Tubular exhaust manifold
Rotary revs uprated coil packs with magnecor leads - unsure of age so unknown quantity.
Rotary revs 100mm maf tube
Lightened pulley set
Lightened flywheel with exedy stage 2 clutch - used
Racing beat enclosed induction kit ( cai )
Various engine covers carbon dipped
Evolve interior
Kode short shift
Cmst 18x9 wheels with Pirelli pzero tyres - good tread. 3 are 2015 production year, one is brand new.
Blue stuff front pads
Dba discs front and rear
Ferrodo rear pads
Racing beat front roll bar
Racibg beat real roll bar
Racibg beat droplinks all round
Hsd monopro coilovers
Engine (allegedly covered 4219 miles since last rebuild with goopy apex seals, new side seals etc and full
master seal kit, with 9alegedly) housings refaced , new water pump , new oil metering pump etc , mild ( street ) port on housings - compression readings can be seen above. In the 5's but no hot or cold start issues. Put out 320miles to a full tank, twice, on a motorway journey during one of the 15 times I drove it.
new handbrake cables
Doors etc are all in reasonable condition. Drivers side doors used to be red.
Any feed back on parts value would be appreciated.
Carbon fibre bonnet
Evolve interior
Kode short shift
Ferrodo rear pads
- ChrisHolmes
You have a PM
- Pingping010101 (Tue Oct 06, 2020 11:03 am)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Vj4sothername
- Has thanked: 1478 times
- Been thanked: 343 times
Swap everything over. Selling and re-buying will be silly money. You can then use that cash for a respray as those colours look ace.
I'm sure Chris is looking for something to do so he can get out of decorating. I'll happly pitch in some time to swap bits over.
- These users thanked the author Vj4sothername for the post (total 3):
- GreySilver Beast (Tue Oct 06, 2020 12:11 pm) • ChrisHolmes (Tue Oct 06, 2020 12:12 pm) • Pingping010101 (Tue Oct 06, 2020 12:19 pm)
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
- ChrisHolmes
Thanks John but I am currently barred from going anything strenuous pending the results of an angiogram in 6 to 8 weeks time!
- These users thanked the author ChrisHolmes for the post (total 2):
- Pingping010101 (Tue Oct 06, 2020 12:19 pm) • Vj4sothername (Tue Oct 06, 2020 12:33 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Pingping010101
There is a value crossover point in there somewhere, but I will have to value the used parts before I can work out where that is.
I really like that Nemesis in the For Sale section but I am not buying another one until I can go and view it beforehand!
- These users thanked the author Pingping010101 for the post:
- Vj4sothername (Tue Oct 06, 2020 12:35 pm)
- Vj4sothername
You direct and I'll do the lifting! That said, it might still be classed as strenous with my ability to take direction.ChrisHolmes wrote:Thanks John but I am currently barred from going anything strenuous pending the results of an angiogram in 6 to 8 weeks time!
Need to come say hello and pick up that oil cooler. Hope everything's okay
- These users thanked the author Vj4sothername for the post:
- ChrisHolmes (Tue Oct 06, 2020 2:12 pm)
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
- Forum Trader
- Has thanked: 496 times
- Been thanked: 257 times
PM’d
Bigpete
Comp testing, parts for sale and fitting service, Servicing
Non runners bought for cash.
Contact: 07932678556
http://paypal.me/bostonrotary
https://www.facebook.com/BostonRotary
- Pingping010101
An offer for LC05 as it sits right now has been accepted, pending collection etc.
I best decide what I want to do now.
- ChrisHolmes
So the hunt begins for another RX8!
- Pingping010101 (Wed Oct 07, 2020 9:02 am)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Pingping010101
That Nemesis is really floating my boat right now but I will be waiting until I’m in the UK before I buy anything else. I need to see it first!
Sent from my iPhone using Tapatalk Pro
- ChrisHolmes (Wed Oct 07, 2020 9:57 am)
- V8 Power
- Has thanked: 235 times
- Been thanked: 490 times
I'm sure the right one will come along
Fresh canvas and all that
- These users thanked the author V8 Power for the post:
- Pingping010101 (Wed Oct 07, 2020 9:18 am)
Direct cold air feed
MSD leads
MSD leads
- Honkytonk
- Communications Team
- Has thanked: 297 times
- Been thanked: 652 times
I fully commiserate with you pingping, I was in the same boat with mine. If I could get hold of whoever decided rust proofing wasn't necessary on European models of the car...
One will come along. There are enough people who care about it and are taking the steps to protect them that soon enough there'll ONLY be good ones left.
- Pingping010101 (Wed Oct 07, 2020 10:46 am)
Have a gander at my Diamond in the Rough (Now with extra Orange!) in
The P-Shed Project Thread
And my OEM-only Luton Adonis, the awful(ly fantastic!) Mighty Vectra
- GreySilver Beast
- Has thanked: 11856 times
- Been thanked: 2912 times
Glad to hear you got a buyer in the end
GSB III 03/08/13 - Present
New ****** on 1st September 2021
- warpc0il
- Has thanked: 492 times
- Been thanked: 2013 times
- Contact:
- Pingping010101
So thats the end of this thread. LC05VRY has gone to BigPete.
Thanks for making that a pain-free process.
We have decided to just buy a new car rather than chase another RX8, so we've bought a new 2020 Suzuki Jimny that I can take shooting and wifey isnt scared to drive.
If you don't mind, I would very much like to hang about and lurk on posts as you're a good bunch!
PingPing.
PingPing.
- These users thanked the author Pingping010101 for the post (total 3):
- GreySilver Beast (Tue Oct 13, 2020 2:55 pm) • bigpete8 (Tue Oct 13, 2020 3:50 pm) • casey (Tue Oct 13, 2020 9:33 pm)
- ChrisHolmes
I am sorry this latest foray into RX8 ownership was painful I am sure another RX8 will join your family one day and until then of course you are welcome to stay around here and share in our highs and lows.
When you are over in the UK then don’t forget to check on local meets, shows and track days for rotary “fixes“
- Pingping010101 (Tue Oct 13, 2020 2:51 pm) • GreySilver Beast (Tue Oct 13, 2020 2:55 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Yorindesarin
Damn sad to hear that Thomas! Definitely stick around.. I hear the jimny has a great liberty walk kit.
- These users thanked the author Yorindesarin for the post:
The Red 8:
- GreySilver Beast
Sorry to hear this Thomas
, but at least as the replacement is Japanese
we can squeeze you onto our Club Stands
- Pingping010101 (Tue Oct 13, 2020 3:15 pm)
- Pingping010101
I won’t need much room!
(Not my car, but an image pinched off eBay. Same colour though!)
- GreySilver Beast (Tue Oct 13, 2020 3:18 pm)
- Ranjan
- Has thanked: 70 times
- Been thanked: 854 times
Thomas,
This is such sad news and I thought I had a bad time with my last RX8; you had it worse.
Take care and keep safe.
If you fancy driving a MX5 on track give me a shout.
Ranjan.
Ranjan.
- ChrisHolmes
Next time you are home on leave swing by here en route to home and you can borrow the Nemesis whilst you're back to scratch your rotary itch.
- Pingping010101 (Wed Oct 14, 2020 8:13 am)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- v-rex
- Has thanked: 519 times
- Been thanked: 193 times
Sorry to hear this, especially after the effort you put into the car, but glad you are sticking around.
Hope you still visit here if it turns out the peeps on the Jimny forums are more fun than us !
P.S. I like that colour. Never seen a Jimny in that colour before but it really works!
