RR54 SC Track Project
- PaulAV
- Has thanked: 115 times
- Been thanked: 313 times
Re: RR54 Back to a red
Chris from what I've seen of body repair welding, it's common to link up a series of spots rather than try to weld in continuous lengths, usually a few spots are welded to tack the panel in place, then these are gradually joined together with further spots. This avoids localised heat build up. Hope this doesn't sound like I'm trying to teach you to weld as I'm no expert, it's just based on all the YouTube shows I've been watching where people weld thier cars
- These users thanked the author PaulAV for the post (total 2):
- Vj4sothername (Sun Sep 06, 2020 10:27 am) • ChrisHolmes (Sun Sep 06, 2020 10:42 am)
- Yorindesarin
- Been thanked: 375 times
Stitch welding does indeed seem the most prominent way to do body welds for the mentioned localised heat. It also makes your life a lot easier since you're only focusing on a small section at a time getting enough penetration etc.
The Red 8:
Racing beat Revi, Tein street basis z coilovers, RRP Mk2 Coils (and one Mk3), Stock catback, Cruise Control (Zoom Zoom).
- Pingping010101
- Has thanked: 162 times
- Been thanked: 75 times
RR54 Back to a red
An inexperienced welder is almost guaranteed to blow a hole in thin sheet if they try to weld in a continuous run as it’s so quick to overheat. This will be frustrating and lead to a messy job.
Equally, many inexperienced welders put a lot of filler material on top of the parent metal, with little penetration, so it looks like a fat worm on top of the steel. Spot welding will help avoid this and encourage better penetration as one can use more heat without blowing big holes for a cleaner, stronger repair.
Sent from my iPhone using Tapatalk Pro
- These users thanked the author Pingping010101 for the post (total 2):
- ChrisHolmes (Mon Sep 07, 2020 8:49 am) • New Duke (Mon Sep 07, 2020 3:36 pm)
- ChrisHolmes
- Has thanked: 5594 times
- Been thanked: 2562 times
It’s an iPhone image so may we’ll be upside down!
Decided to spin the engine out of T200 CAD over and squirt some oil into the chambers. I was most surprised when a load of water flew out of the plug holes! I hadn’t drained the block when I removed the engine but it wasn’t FL22 that came out.
The inlet manifold was still on the engine and all the ports were taped over plus had a nitrile glove stretched over them so how the water got in is beyond me. It seemed too much for condensation but I am at a loss as to where it came from.
Got other things to do on the car but will strip the engine tomorrow to stop any further rust damage, not amused really as tge engine has only done about 5k!
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- nightfire10
- Has thanked: 1186 times
- Been thanked: 550 times
I could take it off your hands and look after itChrisHolmes wrote:It’s an iPhone image so may we’ll be upside down!
To do install sohn tank bracket made but still need to get time to install,caliper painting
- ChrisHolmes
But then I wouldn’t have three engines, one in RR54 running, one watery one out of T200 and one more that could be made out of my accumulated parts as I have two refurbished housings and a set of bridge ported irons sitting under my bench.nightfire10 wrote: ↑Wed Oct 21, 2020 6:47 pmI could take it off your hands and look after itChrisHolmes wrote:It’s an iPhone image so may we’ll be upside down!
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- PaulAV
Has the third engine been bench tested Chris
- Ainmhidh
- Has thanked: 488 times
- Been thanked: 402 times
Surely 4, or is there a big hole in the Nemesis that I've forgotten?
- These users thanked the author Ainmhidh for the post (total 2):
- Vj4sothername (Wed Oct 21, 2020 8:32 pm) • GreySilver Beast (Wed Oct 21, 2020 8:40 pm)
- ChrisHolmes
Oh yes, forgot I had bought that!
- Ainmhidh (Wed Oct 21, 2020 9:00 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
For about two years!
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
Stripped the engine, this is the SC engine from T200 not from RR54, this morning and the water was in the primary inlet. Still cannot fathom how it got in there but fortunately no major rust damage to the rotors or the irons.
The irons are still serviceable but the housings have chatter lines and grooving plus there is some chrome flaking in one.
The Goopy apex seals are badly worn on the flanks, 0.006" down on the original thickness, and they consequently are very slack in the rotor grooves.
So its refurbished housings for the build when I get round to doing that and fortunately I have a spare set from last year.
- Attachments
- Rear Iron (Medium).JPG (127.5 KiB) Viewed 165 times
- Rear Housing flaked chrome (Medium).JPG (119.8 KiB) Viewed 165 times
- Rear Housing 4 (Medium).JPG (140.21 KiB) Viewed 165 times
- Rear Housing 3 (Medium).JPG (138.78 KiB) Viewed 165 times
- Rear Housing 2 (Medium).JPG (146.16 KiB) Viewed 165 times
- Rear Housing 1 (Medium).JPG (140.92 KiB) Viewed 165 times
- Front Iron (Medium).JPG (138.52 KiB) Viewed 165 times
- Front Housing 4 (Medium).JPG (143.14 KiB) Viewed 165 times
- Front Housing 3 (Medium).JPG (126.68 KiB) Viewed 165 times
- Front Housing 2 (Medium).JPG (137.77 KiB) Viewed 165 times
- Front Housing 1 (Medium).JPG (146.86 KiB) Viewed 165 times
- Centre Iron Rear (Medium).JPG (149.03 KiB) Viewed 165 times
- Centre Iron Front (Medium).JPG (136.98 KiB) Viewed 165 times
- These users thanked the author ChrisHolmes for the post (total 3):
- nightfire10 (Thu Oct 22, 2020 4:23 pm) • Vj4sothername (Thu Oct 22, 2020 7:15 pm) • Pippypip (Fri Oct 23, 2020 10:15 am)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- warpc0il
- Has thanked: 489 times
- Been thanked: 1995 times
- Contact:
I recall that Tony said that engine needed a strip and rebuild, so that's all to be expected.
Goopy seals do tend to be much harder on all the surfaces that they contact and there's a fail amount of evidence for that. Do you know how many miles it had been?
The water in the inlet is strange but there must be a logic explanation...
- ChrisHolmes
The engine that was in the car when I bought it died after two months and this one that I just stripped is the replacement that I built and it has done c6000 miles and 3 track days.warpc0il wrote: ↑Fri Oct 23, 2020 6:30 pmI recall that Tony said that engine needed a strip and rebuild, so that's all to be expected.
The water in the inlet is strange but there must be a logic explanation...![]()
Its the wear on the sides of the seals that I think is excessive for the mileage. I have not checked the height yet but will do when I get round to cleaning and measuring stuff for the rebuild over the winter
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
Working on prepping the car pending Luke coming next wednesday to swap out the subframes but keep sidetracking myself doing other little jobs.
Painted the exhaust shrouds gloss black to match the Mazdaspeed skirts.
The front repeaters had taken on aquarium status. I think I will try my orange ones in there but reckon they will clash with the red.
- Vj4sothername (Fri Oct 23, 2020 8:16 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- warpc0il
- Contact:
ChrisHolmes wrote: ↑Fri Oct 23, 2020 6:56 pmThe engine that was in the car when I bought it died after two months and this one that I just stripped is the replacement that I built and it has done c6000 miles and 3 track days.
That does look like a lot of wear for 6k miles
- ChrisHolmes
Yep, been doing a load of web research on apex seal wear, particularly Goopies and conclude it’s down to a combination of too much heat in the rotors and insufficient lubrication. I did cook the motor twice which cannot have helped. Next SC build will get modified rotor housings and upgraded radiator.warpc0il wrote: ↑Fri Oct 23, 2020 9:20 pmChrisHolmes wrote: ↑Fri Oct 23, 2020 6:56 pmThe engine that was in the car when I bought it died after two months and this one that I just stripped is the replacement that I built and it has done c6000 miles and 3 track days.
Its the wear on the sides of the seals that I think is excessive for the mileage. I have not checked the height yet but will do when I get round to cleaning and measuring stuff for the rebuild over the winterI'm losing track of this musical chairs with engines
That does look like a lot of wear for 6k miles![]()
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Yorindesarin
Still going to use Goopie seals in the next rebuild Chris?
The Red 8:
- ChrisHolmes
Yes as insurance in case of detonation in the SC engine.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- mrspiller
- Has thanked: 179 times
- Been thanked: 480 times
That’s a first for meChrisHolmes wrote:Working on prepping the car pending Luke coming next wednesday to swap out the subframes but keep sidetracking myself doing other little jobs.
Never seen water in front repeater before
- ChrisHolmes
This is the ex Ranjan devil car so I expect it to do odd things.mrspiller wrote: ↑Sat Oct 24, 2020 9:22 amThat’s a first for meChrisHolmes wrote:Working on prepping the car pending Luke coming next wednesday to swap out the subframes but keep sidetracking myself doing other little jobs.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Yorindesarin
Both of my front side markers had a little bit of water in them/have had (hence why I had to clean them out) not quite to that extreme though!
The Red 8:
- ChrisHolmes
Fortunately I have a few spares including some orange ones.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- PaulAV
Not sure if HME seals might be better for you, the guys have been making them for rotaries for decades and I believe they were really well respected amongst the performance rotary scene. Skindred knows of them from when he lived in NZ
- ChrisHolmes
HME as in Hurley Motor Engineering?
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- PaulAV
Yes mate.
- ChrisHolmes (Sat Oct 24, 2020 5:28 pm)
