RR54 SC Track Project
- ChrisHolmes
- Has thanked: 5594 times
- Been thanked: 2562 times
In the early hours of Sunday 1st March Nigel and I were exchanging texts with Ranjan in New York about his troubled car and the outcome was that he generously gave the car to me!
RR54 is standard aside from a rebuilt bridgeported engine with possible issues, full Safety devices cage, Racing Beat ARBs, Evolve seats, Mazdaspeed side skirts, PZ rear spoiler, short shifter and Royale steering wheel.
T200 is a totally different affair having been built over the years by Tony into the ultimate show car but with some quality performance mods topped by a Pettit supercharger. Since acquiring T200 I have fitted a rebuilt street ported and balanced engine with a SOHN, RRP ignition coils, White Line ARBs, TEIN EDFC system, bucket seats, 4 point harnesses as my intention was to track the car which I have done and it is great fun with the extra torque.
So what do I do with two RX8s is the dilema that I was faced with and now having decided what to do I am in the process of transferring the bucket seats, harnesses, TEIN suspension system, Racing Brake 4 pots and 2 piece discs from T200 over to RR54 which will be staying NA.
So eventually T200 will be up for sale as running car, I will not be removing the SC setup to sell it separately before anyone asks.
T200 is currently SORN and will remain so until the current crisis is over, both factors of course mean viewings and test drives are not possible. Rather than clutter up this project thread with questions please be patient until T200 is actually advertised in the For Sale section with it’s revised specification.
Total change of plans during April and now having discovered the supercharger has a whirring bearing I am going to have it overhauled and it will see service again in RR54 probably in 2021.
Future plans include in no particular order:
Build car port.........................................................................Completed end June 2020
Ex: T200 engine strip, check and rebuild, plus Goopy seals..................Over winter
Greddy alloy sump...................................................................On T200 engine
RRP alloy 6 groove SC pulleys. Hi and low power...............................Sourced June 2020
RB alloy flywheel, Stage 1 Exedy Clutch.........................................On T200 engine
RRP COFS kit with alloy tanks......................................................Tanks fitted
Flow check blue and red fuel injectors...........................................
Supercharger overhaul...............................................................Completed April 2020
Revised SC plumbing with uprated charge cooler system......................
External Cold air intake.............................................................Sourced Dec 2019
Hinsberger rear exhaust shrouds paint Gloss Black..............................Completed May 2020
Seibon vented carbon bonnet...Paint removed or painted gloss black.......Started June 2020
Krown Rust proofing..................................................................Completed July 2020
Remove and refit Mazdaspeed side skirts & clean off mounting adhesive...Removed & cleaned up July 2020, refitted Aug 2020
Bucket seats............................................................................Fitted March 2020
4 & 5 point Harnesses ................................................................Fitted March 2020
Metallic Silver & Red wheels.........................................................Fitted July 2020
Lockwood Grills........................................................................Sourced may 2020
Full alignment check and adjust. Post subframe and arms fitting
Donor Front subframe stripped, cleaned & painted red................................Completed June 2020
Donor Rear subframe stripped, cleaned & painted black...............................Completed Oct 2020
Donor Front & Rear suspension arms, strip, clean and paint / light polish...Completed June 2020
Clean and electroplated suspension bolts, nuts and washers...................Kit received Aug 2020
Poly bush the suspension arms.......................................................Completed September 2020
Swap the subframes for the painted polybushed ones............................November 2020
Full Alignment setup....................................................................November 2020
New Federal 595 RSR 245/35 x 18 tyres x 4........................................Sourced May 2020
Fit good wing to replace rusted one.................................................Completed Aug 2020
Fit tow bar................................................................................Completed July 2020
Buy Trailer for Trackday wheels etc;.................................................Collected 29th July
Repair PS rear sill........................................................................Completed Sep 2020
Fit smoked lens LED Brake lights......................................................Completed May 2020
Sort out some rust bubbling in the usual places....................................Ongoing!
- Ainmhidh (Sun Mar 29, 2020 4:27 pm) • GreySilver Beast (Mon Mar 30, 2020 2:52 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- GreySilver Beast
- Has thanked: 11849 times
- Been thanked: 2906 times
Back to a red
May I add we were both a bit sloshed at the time texting Ranjan back and forth
GSB III 03/08/13 - Present
- ChrisHolmes
Re: Back to a red
Just a bit LOL!GreySilver Beast wrote: ↑Mon Mar 30, 2020 2:56 pmMay I add we were both a bit sloshed at the time texting Ranjan back and forth![]()
- GreySilver Beast (Mon Mar 30, 2020 8:18 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
Re: Back to a red
Tomorrow will be a test of my ingenuity to remove the pistons from the 4 pots, a couple were stiffer than others so no doubt the cause of the uneven pad wear. Racing Brake have confirmed this is the likely cause of the uneven wear.
I don’t have compressed air but I do have a MIG gas bottle of Argon/CO2 so plan to make up a connection with a section of old brake pipe.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- warpc0il
- Has thanked: 489 times
- Been thanked: 1995 times
- Contact:
- PaulAV
- Has thanked: 115 times
- Been thanked: 313 times
Re: Back to a red
If your going to use bottled gas, keep your hands out of the way of the pistons, normal airlines work at around 80-120 psi and can apply a lot of force to the pistons, bottled gas can be significantly higher. But you probably already know this
- ChrisHolmes (Tue Mar 31, 2020 12:43 pm)
- ChrisHolmes
Re: Back to a red
Thanks, always worth giving someone the nod just in case. Braided lines arrived today so making up a feed line will be simpler. Various thickness pieces of timber planned as “stoppers” for progressive, hopefully, pushing out of the pistons.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Goobie
- Has thanked: 39 times
- Been thanked: 361 times
- Contact:
Re: Back to a red
Project thread with no pictures? Tut tut Chris.
So do you prefer more of a raw n/a rx8 as a track car over the f/I? Or is it a case of the simplicity?
I get asked a lot about my old type r and to of why I drive that most out of all my cars, my reply is always the same, its so simple compared to cars of "today" in ref to being loaded with so much electrical technology etc that just one simple sensor or lose wire can leave it stuck at the side of the road and poss cost thousands.
- ChrisHolmes
Re: Back to a red
Had some camera issues which are hopefully resolved and some photos should be arriving soon.
You hit the nail on the head with the simplicity comment and whilst the torque is nice to have the car overall is not really what I have realised I want in on RX8. After transfering the brakes and suspension etc; over T200 will go up for sale complete with the SC set up from inlet to exhaust tips.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Essex2Visuvesi
- Been thanked: 310 times
- ChrisHolmes
Re: Back to a red
Yes the interior stays in the car, tried to sell it but had no takers.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
Re: Back to a red
Videos of my caliper piston removal jig in action. No sound unfortunately so you will need to imagine the POP in the last video.
- Vj4sothername (Sun Apr 05, 2020 4:47 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- Vj4sothername
- Has thanked: 1467 times
- Been thanked: 341 times
Re: Back to a red
That top left was really stuck in there!
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
- ChrisHolmes
Re: Back to a red
Refurbed Calipers fitted and swapped over the 2 piece Racing Brake Discs, Racing Beat drop links and TEINs from T200 which now has the suspension from RR54 plus newly painted orange front calipers and RR54s blue stuff and yellow stuff EBC pads.
Cannot complete the front brakes until the correct seals and pad retainer arrives from USA.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
Re: Back to a red
The cause of the sticking was I am certain down to the aluminium corrosion behind the dust seals force the seal against the piston. I couldn't see anything else that could be causing the restriction.
- Vj4sothername (Wed Apr 08, 2020 11:05 pm)
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
Re: Back to a red
Piston seals and retainer arrived yesterday so assembled the calipers and fitted them today. Brake bleeding was going well with a nice even movement of the pedal with reasonable resistance until I did one extra push and discovered i had drained the master cylinder and pumped a load of air in! Packed everything up and went indoors.
TBC
TBC
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- warpc0il
- Contact:
Re: Back to a red
I hate it when that happens
- ChrisHolmes (Wed Apr 08, 2020 10:22 pm)
- qwakers
- Has thanked: 211 times
- Been thanked: 807 times
Re: Back to a red
get a syringe and fill with brake fluid, open the nipple of the caliper you where last working on and attach syringe, push fluid into circuit until level is visible in res.
youll save yourself hours of bleeding doing that.
- ChrisHolmes
Re: Back to a red
Now that’s the sort of post I love, thanks James. A bit of reverse psychology?
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- qwakers
Re: Back to a red
exactly that. reverse bleeding has saved my ass more times than i can count,
youll still need to re bleed the master first though (if it has a nipple.)
- ChrisHolmes
Re: Back to a red
Fortunately it’s the early design with the bleed nipple.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
Re: Back to a red
Fitted the new caliper seals and the pistons slide so freely. All fitted now along with new pistons and seals in the rear calipers, braided lines front and rear. New Mintex 1144 pads in the front replacing the wedges I took out!
Bled the brakes today with assistance from Kathy and Steve.
Removed the manky sound proofing from the engine bay and fitted the RRP COFS tanks that I bought from Scartlead. The headlamp washers dont work so need to do some investigation, plus the low level light is on. Had to extend the wiring for the H/lamp washer motor and make up 10mm "stud" for right hand plate mounting screw, otherwise simples.
Engine mounts tomorrow.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- V8 Power
- Has thanked: 234 times
- Been thanked: 487 times
Re: Back to a red
Did you get to the bottom of the engine problem?
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
MSD leads
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
- ChrisHolmes
Re: Back to a red
Not yet is all I can say Graham. It doesn’t smoke any more so I need the lockdown to finish and get out and drive it, as do we all I suppose. Larger catch can fitted!
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
- ChrisHolmes
Re: Back to a red
Eke trucks are not my strong point but today I threw caution to the wind and have swapped the Taiwan? LED rear lights from T200 over to RR54 and only the small red corner lights work! The front indicators flash at normal speed but there is nothing at the rear.
As the original boot loom had a trailer socket relay spliced into it I removed all the wires relating to that and the associated relays. Whilst doing this I had both boot looms side by side and work through each connection and cable labelling them as I went.
I have one black with red line wire that runs to the stop tail and reversing light which I think is an earth but I don’t know. Also the right side of the loom has three wires which don’t match with the three spare ins on the left side. I traced where they went on each side and connected them together as stop tail and reversing, I think.
Result, no lights at all except for the small red side lights on the corners!!
Fast forward 2 1/2 hours and I now have lights, I reverted to plain old bulbs for the reverse and indicator lights, changed how the indicators were wired and bingo it all works.
Very very relieved to say the least.
Street Ported 231
MazdaSpeed skirts
Street Ported 231
MazdaSpeed skirts
