My R3
MarkG M3CP
RX-8: Kuro
Has thanked: 16 times
Been thanked: 11 times
Re: My R3
Post by MarkG M3CP » Mon Aug 19, 2019 2:19 pm
For me the mono sports wouldn’t achieve all goals without the EDFC. They are too hard for the road at anything below 8 and would be too soft for track above 8.
It’s easy enough to adjust them manually but the real bonus is being able to play around with the settings on the fly.
I tend to leave them on 16 (soft) a lot of the time flick into 8 when pressing on - then in adaptive mode too.
I think I need to increase the ride height a little too.
Current: '07 Kuro, M5 Competition
Gone: '06 VR 231, M3 Competition Package
Mpv2k3
Has thanked: 226 times
Been thanked: 464 times
Re: My R3
Post by Mpv2k3 » Fri Dec 27, 2019 10:19 pm
Since fitting the Tein Monosport I've managed to do a couple of trackdays at Oulton Park and Brandshatch and I'm very impressed with them on the car. :race:
I had them dialled 3 clicks from full hard.
Although the dampers are easy to adjust, it's just an inconvenience to have to keep adjusting them manually, so I will be looking at getting the Tein edfc for them sooner than later which was always the end plan. Hopefully before my double track day at the Nurburgring in April. [-o<
Just need to decide whether to go for the Edfc
Active with GPS or the Active Pro with GPS.
:-k
V8 Power
Has thanked: 238 times
Been thanked: 490 times
Re: My R3
Post by V8 Power » Fri Dec 27, 2019 11:34 pm
On my S1(stripped out) I have 4 clicks on track and 8 on road
I have been very impressed with the Tein’s
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
MSD leads
Harrizone
Founder Member
Founder Member
Has thanked: 41 times
Been thanked: 344 times
Re: My R3
Post by Harrizone » Sat Dec 28, 2019 9:33 am
To achieve my fastest around Coram at Snetterton (indicated 98mph) mine were set at 2 from hardest at the front and 4 at the rear. In the dry have always used these settings, at most tracks, and found adhesion and traction excellent when on Federals. Had the Teins on for many, many years before going to EDFC, because of the faff altering them manually, and once having driven home from Snetterton without first altering them. :banghead:
These users thanked the author Harrizone for the post:
Mpv2k3 (Sat Dec 28, 2019 6:32 pm)
Mpv2k3
Re: My R3
Post by Mpv2k3 » Sat Dec 28, 2019 6:33 pm
Cheers Ray
Mpv2k3
Re: My R3
Post by Mpv2k3 » Sat Feb 22, 2020 6:08 pm
Well, I finally purchased the Tein Edfc Active with GPS to compliment the Tein monosport coilovers already fitted and had it installed recently. I still need to play around with finding a suitable setting. :-k
These users thanked the author Mpv2k3 for the post (total 2):
ChrisHolmes (Sat Feb 22, 2020 6:14 pm) • GreySilver Beast (Sat Feb 22, 2020 7:53 pm)
V8 Power
Re: My R3
Post by V8 Power » Sat Feb 22, 2020 7:36 pm
Neat install Marc
Looks like fun
Carbon seats
Feed gearknob
Axial short shift
Whiteline ARB's
Stripped interior
MSD leads
Mpv2k3
Re: My R3
Post by Mpv2k3 » Sat Feb 22, 2020 7:57 pm
Thanks. By removing the ash tray allows enough space for the controller to fit and still allow the lid to close.
Has thanked: 5616 times
Been thanked: 2572 times
Re: My R3
Post by ChrisHolmes » Sat Feb 22, 2020 8:04 pm
Just for clarity people 4 can = 8 can = 16 because it is possible to set the number of “click” points at 8 16 or 32
EDIT: See Marks post below ooops!
Street Ported 231
MazdaSpeed skirts
Mpv2k3
Re: My R3
Post by Mpv2k3 » Wed Feb 26, 2020 5:43 pm
16, 32, 64
Re: My R3
Post by ChrisHolmes » Wed Feb 26, 2020 5:59 pm
16, 32, 64
Erk! Just read the manual again and your correct 16 32 64 durr!
Mpv2k3 (Wed Feb 26, 2020 6:12 pm)
Street Ported 231
MazdaSpeed skirts
Been thanked: 51 times
Re: My R3
Post by RX8R3Rod » Tue Mar 03, 2020 5:48 pm
Some great pictures, and that is a v neat install, isn’t it? 👍🏻 Hope you’re enjoying the EDFC 😁
These users thanked the author RX8R3Rod for the post:
Mpv2k3 (Tue Mar 03, 2020 6:40 pm)
Mpv2k3
Re: My R3
Post by Mpv2k3 » Tue Mar 03, 2020 6:40 pm
Thanks.
I've not driven my car much since the install but what I have done I've enjoyed it. I'm Still playing around with different settings, added some extra steps on the speed SL mode.
Having it on track at the Ring in April will be the real test. Thinking of just using the GL mode only with my manual setting. Don't think the SL mode will help unless I more less change all the settings at each speed level so its more firmer. :race:
Overall so far I'm impressed with it. :thumleft:
Re: My R3
Post by RX8R3Rod » Wed Mar 04, 2020 5:52 am
Really pleased to hear you’re enjoying it. 👍🏻
There are certainly lots of options for set-up, aren’t there?
Have you by any chance compared the continuous adjustment mode with the ‘step’ adjustment mode yet? (From memory and without reference to the instruction book I think that’s the L and A modes? ... what I’ve (I’m sure incorrectly) called the continuous adjustment mode is the one described in the instruction book by a smooth curve between settings, rather than small steps)
I’ve not yet had a chance to try this, and wondered if you perhaps had?
Mpv2k3 (Wed Mar 04, 2020 6:10 am)
Mpv2k3
Re: My R3
Post by Mpv2k3 » Wed Mar 04, 2020 6:09 am
Yep, theres loads of options you can have. The smooth curve as you describe is the L mode. (GL and SL)
At the moment I currently use G_L and S_L set up. For the G_L setting I use memory 2 (G2) and for the S_L setting I use the memory 1 (S1). This is just for road driving and gives a softer ride I find at the moment.
Re: My R3
Post by RX8R3Rod » Fri Mar 06, 2020 5:39 am
Many thanks for the insight. 😊 I haven’t tried the L mode yet, so will have to give that a go 👍🏻
Mpv2k3
Re: My R3
Post by Mpv2k3 » Fri Mar 06, 2020 6:10 am
I just feel like the L mode makes it a smoother transition between each set step as it's making finer adjustments constantly between the steps and not having to adjust multiple steps in one go. Also you don't hear the motors working so much, not that they are too noisy anyway.
Mpv2k3
Re: My R3
Post by Mpv2k3 » Tue Apr 21, 2020 2:20 pm
Not much updates.
My car had trouble getting into gear now and then. Had the clutch slave cylinder replaced which seemed to have been the issue as mine wasn't moving much....
Has thanked: 267 times
Been thanked: 586 times
Re: My R3
Post by Dr. FrankenRex » Tue Apr 28, 2020 11:07 am
Why is this on here and not in a dedicated build thread...? :lol:
GreySilver Beast (Tue Apr 28, 2020 11:32 am)
Has thanked: 11856 times
Been thanked: 2912 times
My R3
Post by GreySilver Beast » Tue Apr 28, 2020 11:34 am
Mod Bit -
@Marc - I can move this Topic if you like :?: :thumright:
GSB III 03/08/13 - Present
Mpv2k3
Re: My R3
Post by Mpv2k3 » Tue Apr 28, 2020 12:18 pm
Feel free to move it over
These users thanked the author Mpv2k3 for the post:
GreySilver Beast (Tue Apr 28, 2020 1:55 pm)
My R3
Post by GreySilver Beast » Tue Apr 28, 2020 1:57 pm
Mod Bit - Moved here as Requested :thumleft:
Mpv2k3
Re: My R3
Post by Mpv2k3 » Thu Aug 20, 2020 11:13 pm
Mpv2k3
Re: My R3
Post by Mpv2k3 » Fri Aug 21, 2020 12:26 am
Just a small update as I haven't used the car much this year with lockdown and planned trackday trips cancelled :(
I recently took a visit with the car up to see Neil at Custom Detailing for some TLC and had my spare set of R3 wheels fitted that had been sitting in the garage for over a year since I acquired them as my wheels where in quite a state.
Unfortunately I found out that two of the wheels were buckled and would need sorting at some point:cry:
Here are some pictures of the small detail. Apart from some age related marks and scuffed splitter the car is doing okay. :thumleft:
These users thanked the author Mpv2k3 for the post (total 5):
GreySilver Beast (Fri Aug 21, 2020 1:07 am) • nightfire10 (Fri Aug 21, 2020 6:42 am) • v-rex (Fri Aug 21, 2020 6:51 am) • ChrisHolmes (Fri Aug 21, 2020 7:58 am) • MARKTHOMASBRAND (Fri Aug 21, 2020 10:29 pm)
Mpv2k3
Re: My R3
Post by Mpv2k3 » Fri Aug 21, 2020 1:07 am
After discovering that i had two buckelled wheels i decided that it would be more cost effective to get my original R3 wheels refurbished and powder coated as they where in a state.
I was planning to get the closest to the original colour as possible but, whilst chatting to the manager I mentioned that there was another colour I had considered......I was then handed pads containing different shades of colours which only made my decision even harder to make.
And to top it off, I was thinking of a satin/matte finish and all the samples were only in gloss so I couldn't imagine how they would look. :shock:
I was back and forth with choosing a close original colour or the new colour and in the end I took the gamble. I then had a few restless nights stressing over the choice I made and hoping that they would be okay [-o<
I collected the wheels today and i treated them to a new set of Rainsports3 while I was at it.
The wheels are different and maybe not everyone's cup of tea but, they have grown on me and look different depending on the lighting.
These users thanked the author Mpv2k3 for the post (total 7):
GreySilver Beast (Fri Aug 21, 2020 1:09 am) • nightfire10 (Fri Aug 21, 2020 6:43 am) • v-rex (Fri Aug 21, 2020 6:51 am) • ChrisHolmes (Fri Aug 21, 2020 7:58 am) • Ainmhidh (Fri Aug 21, 2020 12:57 pm) • MARKTHOMASBRAND (Fri Aug 21, 2020 10:30 pm) • Ranjan (Thu Sep 03, 2020 12:00 pm)
