Supercharged RX-8 End of the road
- V8 Power
- Has thanked: 253 times
- Been thanked: 537 times
Re: Supercharged RX-8 Engine Renaissance
All is good
Will have to sort out a meet up to swap bits etc
- ChrisHolmes
- Has thanked: 9691 times
- Been thanked: 4896 times
The more times I refer to the manual and observe how the system works the more my understanding improves. Currently have it set to G - L and S - L which has two switchable modes Normal and Sport. G denote G force activated and S speed. L denotes a linear and smooth adjustment of damping and there is also A which adjusts in preset increments, not a smooth change.Goobie wrote: ↑Sat Feb 08, 2020 6:15 pmIt is a rather thick booklet isn't it? Also, its good now a couple of members have this now as this should save me time come fitting and setting up as I can pick you and Rod's brains should I have any issues.ChrisHolmes wrote: ↑Fri Jan 31, 2020 2:08 pmCar gets taxed tomorrow so i will be able to see, feel how the EDFC system makes the car drive.
My brain is cafuddled with reading the install, how it operates and set up format choices of some 46 pages!
I need to find a reasonably bumpy road and play with the system in manual mode to really feel the difference as the dampers are adjusted from 0 to 32.
- These users thanked the author ChrisHolmes for the post (total 3):
- mrspiller (Sat Feb 08, 2020 8:22 pm) • Goobie (Sat Feb 08, 2020 8:43 pm) • Mpv2k3 (Sat Feb 08, 2020 9:50 pm)
- Mpv2k3
- Colour: Diamond Grey
- Has thanked: 288 times
- Been thanked: 575 times
I'm sure I'll be picking your brain when my edfc is fitted in the next few weeks.
- ChrisHolmes
The manual covers it all and has pictures so you will be ok reading it!
- ChrisHolmes
Further thoughts on the bubbles are that whilst the underside of the bonnet was sealed and sprayed it is a double skinned structure therefore all the internal surfaces will be bare carbon and this potentially is the cause through moisture ingress.
- warpc0il
- Has thanked: 825 times
- Been thanked: 3535 times
- Contact:
That's what I've been thinking from the start.
Moisture trapped between these layers is going to seep into the weave, especially as it gets heated and cooled by both engine heat from below and sunshine (remember that?) from above.
If that is the cause of the problem then there's little you can do to stop it re-occurring.
Are the "bubbles" really hard?
Have you tried making a tiny pin-p**** or slit in one to see if they're solid, or have air or water inside?
- boosted
- Has thanked: 101 times
- Been thanked: 500 times
I believe the process is osmosis...air and water particles swapping....maybe self confessed BS mind...id leave well alone til hotter times and see if it reverse osmosises?
Thats what im doing with mine!
Mondeodog towcar.
Mondeodog towcar.
- mrspiller
- Has thanked: 280 times
- Been thanked: 763 times
I havnt read all of this , not sure if it’s been covered
Was the car garaged by previous owner ?
- boosted
Lol i already spent it in theory...
Rebuild and a borgwarner tubby overnight parts from Japan.
Mondeodog towcar.
Mondeodog towcar.
- qwakers
- Has thanked: 413 times
- Been thanked: 1731 times
- Contact:
- boosted
Completely the wrong forum too what a cock i am.
Mondeodog towcar.
Mondeodog towcar.
- ChrisHolmes
Yes garaged with a dehumidifier running.
- mrspiller
Is it left outside at yours Chris ?
- ChrisHolmes
Yes, currently
- mrspiller
So your probably right about moisture ingress in the carbon I guess , as it now lives outdoors rather than a cushty garage with no moisture ever really subjected to it .
Just a thought
Just a thought
- ChrisHolmes (Tue Feb 11, 2020 6:02 pm)
- ChrisHolmes
MOT passed today with no advisories 5000 miles since last MOT and only 356 the previous time!!!
- 30405 (Wed Feb 19, 2020 10:02 pm)
- GreySilver Beast
- Has thanked: 18434 times
- Been thanked: 4651 times
I take it the car is almost ready for the Annual Meet Chris
- ChrisHolmes
Yes, all set for my first RX8 AGM track drive in 3 years! followed of course by Cadwell on Monday. Poor car after all its resting over winter! Maybe the fresh air will clear its spots!!
- ChrisHolmes
Colours look fine but I may have found the cause of the slightly sluggish starting! I just hope that when the electrode departed it didn't get chopped by a side seal as it went into the exhaust or rattle round and round and marmalise the housing.
Time to warm up the car and do a comp test methinks.
- 30405 (Wed Mar 25, 2020 4:43 pm)
- V8 Power
Why do you think the plug would fail like that Chris?
- ChrisHolmes
Poor weld is all can think off.
- mrspiller
Chris
If you been thrashing that car it probably got too hot for the plugs
I was told to use ngk v power racing plugs
- qwakers
- Contact:
that is the third time in less than a year that ive seen a rx8 plug fail like that !
- casey
- Has thanked: 2148 times
- Been thanked: 2397 times
Wayne - do you know the NGK part number you were recommended to use?
I've experienced this (on 3 plugs now), and we've had several reports of this failure mechanism on the forum.
I was wondering whether it was possible to use the plug used the FD engine, which has a 4 post electrode design?
Anyone any thoughts/ideas?
- V8 Power
There was a thread where Carl Ryan mentioned using FD plugs on FI RX8’s (I think?) hopefully he will see this and confirm.
