Supercharged RX-8 End of the road
Locked
Has thanked: 4832 times
Been thanked: 2038 times
Post by ChrisHolmes » Fri Mar 29, 2019 3:20 pm
V8 Power suggested I start a thread to chart my progress with the car so here is the first post.
These users thanked the author ChrisHolmes for the post (total 9):
MightyCondor (Fri Mar 29, 2019 3:44 pm) • Davemitch (Fri Mar 29, 2019 3:52 pm) • PhilR (Fri Mar 29, 2019 4:19 pm) • sKenDread (Fri Mar 29, 2019 4:20 pm) • TheManc (Fri Mar 29, 2019 5:17 pm) • qwakers (Fri Mar 29, 2019 6:06 pm) • V8 Power (Fri Mar 29, 2019 6:48 pm) • GreySilver Beast (Fri Mar 29, 2019 7:12 pm) • PaulAV (Tue May 28, 2019 8:21 pm)
Bridge Ported 231
MazdaSpeed skirts
Short shifter
njkmr
RX-8: Kuro
Colour: Kuro Black
Has thanked: 84 times
Been thanked: 141 times
Re: T200 CAD Supercharged RX-8 Renaissance
Post by njkmr » Fri Mar 29, 2019 5:07 pm
Sounding awesome already...!
Tell us more.
Post by ChrisHolmes » Fri Mar 29, 2019 5:33 pm
if you search T200 CAD on YouTube you will find some great videos and photos posted by Tony (Exiled Viking) who "created" the car. I am just the lucky person who bought and has now become the unlucky person who blew the engine. Hence the thread!
exiled--viking (Fri Mar 29, 2019 10:03 pm)
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Scartlead
Has thanked: 81 times
Been thanked: 99 times
Post by Scartlead » Fri Mar 29, 2019 6:31 pm
How to mod a car that has nothing left to mod :) looking forward to see what you’ll be up to next :thumright:
Aka Mark
Post by ChrisHolmes » Fri Mar 29, 2019 7:17 pm
I just made the first mod inside the engine LOL
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Has thanked: 399 times
Been thanked: 1570 times
Post by warpc0il » Fri Mar 29, 2019 7:42 pm
To be fair, Tony did warn that the hand grenade pin was a bit loose... ;)
Post by ChrisHolmes » Fri Mar 29, 2019 8:13 pm
Absolutely Dave, Tony was extremely open regarding the engine therfore I was totally aware that I could well be in for a rebuild and possibly supercharger refurb too in the near future
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Lemon
Has thanked: 29 times
Been thanked: 164 times
Post by Lemon » Sat Mar 30, 2019 8:44 am
what was the determined cause of failure? (other than the right foot...)
Thanks, Stu
Post by ChrisHolmes » Sat Mar 30, 2019 11:28 am
Not got the motor out and stripped yet
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Post by ChrisHolmes » Sat Mar 30, 2019 8:01 pm
Finally started to dig out the engine
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Clive
RX-8: Supercharged
Has thanked: 299 times
Been thanked: 434 times
Post by Clive » Sat Mar 30, 2019 8:07 pm
Photos Chris, lots of photos for reference
Post by ChrisHolmes » Sat Mar 30, 2019 8:17 pm
Oh yes, and labels where it's not obvious what goes where. Some coolant and breather pipe re-routing already in my mind.
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Post by ChrisHolmes » Fri Apr 05, 2019 10:29 pm
Just got the exhaust gearbox to unbolt then the engine can be pulled out, hopefully in the morning and stripped in the afternoon to see how well, or knackered it is!
Discovered that the pipe connecting to the HKS boost sensor was dangling free and the T it was supposed to be connected to was only on one of the pipes on the lower inlet manifold. More concerning was the swollen and possibly already disconnected vacuum pipe to the oil injector block. Unless I had inadvertently disturbed it, not sure.
Certainly the boost pipe was loose and no doubt has been a contributor to the lean running as it would only be recording atmospheric pressure.
Connecting the remote oil filter head adaptor is going to be a challenge as room is severely restricted behind the SC and the vacuum box occupies the only other pipe route option.
1 Have to have a before picture (Medium).JPG (183.35 KiB) Viewed 1376 times
2 First bits removed (Medium).JPG (125.95 KiB) Viewed 1376 times
3 More bits removed (Medium).JPG (185.81 KiB) Viewed 1376 times
4 Getting interesting (Medium).JPG (191.36 KiB) Viewed 1376 times
5 Even more interesting (Medium).JPG (206.04 KiB) Viewed 1376 times
6 Removed parts (Medium).JPG (146.14 KiB) Viewed 1376 times
7 Blue Black White reference (Medium).JPG (131.93 KiB) Viewed 1376 times
8 Removing this was fun (Medium).JPG (115.22 KiB) Viewed 1376 times
[attachment=1]
Bridge Ported 231
MazdaSpeed skirts
Short shifter
nightfire10
Has thanked: 837 times
Been thanked: 343 times
Post by nightfire10 » Fri Apr 05, 2019 10:31 pm
ChrisHolmes wrote:Just got the exhaust gearbox to unbolt then the engine can be pulled out, hopefully in the morning and stripped in the afternoon to see how well, or knackered it is!
[attachment=1]
Good luck with this Chris
Post by ChrisHolmes » Fri Apr 05, 2019 10:41 pm
Quite a few times today I thought " Why did I sell the red car" I knew every inch of that and how it was all wired and routed. This is a whole new ball game!
hogesar (Sun Apr 14, 2019 10:21 pm)
Bridge Ported 231
MazdaSpeed skirts
Short shifter
mi60o0
Has thanked: 90 times
Been thanked: 278 times
Post by mi60o0 » Sat Apr 06, 2019 6:57 am
Good luck Chris.
BatRex 192 stock
Has thanked: 20 times
Been thanked: 107 times
Post by 350matt » Sat Apr 06, 2019 10:05 am
what are planning for the engine?
straight rebuild? street port?
Post by ChrisHolmes » Sat Apr 06, 2019 4:50 pm
One or the other certainly, depends what I find port wise when I get inside the engine, not literally if course!
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Scartlead
Post by Scartlead » Sat Apr 06, 2019 4:52 pm
Chris, you so need to sell that peskey supercharger, it apparently doesnt add ANY power :lol:
Aka Mark
Post by warpc0il » Sat Apr 06, 2019 5:05 pm
That supercharger was developed for a Lightning Yellow rex and will only perform at it's best when back in that environment. :D
Tango Orange is close but maybe not close enough :roll:
Post by ChrisHolmes » Sat Apr 06, 2019 10:08 pm
@ Mark and Dave, you wouldn't know any who wants to buy it would you by any chance??
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Post by ChrisHolmes » Sat Apr 06, 2019 10:13 pm
OK, the last couple of days have been quite productive, or rather destructive. I will let the photos tell the story but in short I have one potentially useable housing and an e shaft due to my over exuberant use of my right foot with a tired engine.
Any expensive event as the irons are all nicely street ported too!!!
27 Same good housing hopefuly (Medium).JPG (131.52 KiB) Viewed 1259 times
26 Good housing hopefuly (Medium).JPG (79.27 KiB) Viewed 1259 times
25 Scrap iron, literally (Medium).JPG (105.08 KiB) Viewed 1259 times
24 Scrap iron, literally (Medium).JPG (138.85 KiB) Viewed 1259 times
23 Scrap iron, literally (Medium).JPG (97.87 KiB) Viewed 1259 times
22 Scrap iron, literally (Medium).JPG (121.77 KiB) Viewed 1259 times
21 Scrap iron, literally (Medium).JPG (121.64 KiB) Viewed 1259 times
20 Scrap front housing (Medium).JPG (113.69 KiB) Viewed 1259 times
19 Black silicone sealant around exhaust port (Medium).JPG (132.36 KiB) Viewed 1259 times
18 Black silicone sealant around exhaust port (Medium).JPG (119.55 KiB) Viewed 1259 times
17 Black silicone sealant around exhaust port (Medium).JPG (163.86 KiB) Viewed 1259 times
16a Squidged out water seal (Medium).JPG (91.23 KiB) Viewed 1259 times
16 Squidged out water seal (Medium).JPG (118.34 KiB) Viewed 1259 times
15 Silcone sealant in oil filler tube (Medium).JPG (128.47 KiB) Viewed 1259 times
14 Special tool made (Medium).JPG (106.52 KiB) Viewed 1259 times
13 Interesting choice of bolt (Medium).JPG (101.54 KiB) Viewed 1259 times
12 Leaking oil injectors (Medium).JPG (109.05 KiB) Viewed 1259 times
11 Burnt oil on manifold from leaking Oil injectors (Medium).JPG (121.58 KiB) Viewed 1259 times
10 Ready to clear wiring etc. (Medium).JPG (178.66 KiB) Viewed 1259 times
9 Engine is out (Medium).JPG (207.9 KiB) Viewed 1259 times
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Post by ChrisHolmes » Sat Apr 06, 2019 10:14 pm
and now some more horror photos
32 Rear rotor jammed side seal (Medium).JPG (99.17 KiB) Viewed 1259 times
31 Rear rotor shattered apex seal (Medium).JPG (77.01 KiB) Viewed 1259 times
31 Rear rotor shattered apex seal (2) (Medium).JPG (77.01 KiB) Viewed 1259 times
30 Front rotor jammed apex seal (Medium).JPG (77.66 KiB) Viewed 1259 times
30 Front rotor jammed apex seal (4) (Medium).JPG (83.55 KiB) Viewed 1259 times
30 Front rotor jammed apex seal (3) (Medium).JPG (83.55 KiB) Viewed 1259 times
30 Front rotor jammed apex seal (2) (Medium).JPG (77.66 KiB) Viewed 1259 times
29 Front rotor jammed corner seal (Medium).JPG (82.84 KiB) Viewed 1259 times
29 Front rotor jammed corner seal (3) (Medium).JPG (93.16 KiB) Viewed 1259 times
29 Front rotor jammed corner seal (2) (Medium).JPG (102.01 KiB) Viewed 1259 times
28 Scrap front rotor (Medium).JPG (114.51 KiB) Viewed 1259 times
28 Scrap front rotor (4) (Medium).JPG (114.5 KiB) Viewed 1259 times
28 Scrap front rotor (3) (Medium).JPG (114.5 KiB) Viewed 1259 times
28 Scrap front rotor (2) (Medium).JPG (114.51 KiB) Viewed 1259 times
Bridge Ported 231
MazdaSpeed skirts
Short shifter
Scartlead
Post by Scartlead » Sat Apr 06, 2019 10:18 pm
me me me me me :D
Aka Mark
Scartlead
Post by Scartlead » Sat Apr 06, 2019 10:20 pm
Looking forward to this rebuild Chris, but of a mess on the irons, but upwards and onwards :thumright:
These users thanked the author Scartlead for the post:
ChrisHolmes (Sat Apr 06, 2019 11:01 pm)
Aka Mark
Locked
