Dave's black S1 231
- Has thanked: 66 times
- Been thanked: 103 times
Re: Dave's black S1 231
Car now has standard intake on, and standard wheels on, it makes me sad to see though so I dont know how long she will stay this way! :/
- GreySilver Beast
- Has thanked: 18434 times
- Been thanked: 4651 times
Dave's black S1 231
Have I missed something Dave
Trying to solve this power loss issue between 4.5k and 6.5k, thought staggered wheels might be cause - nope, changed to standard intake - nope. Now to dig deeper and try to see why
- GreySilver Beast
Dave's black S1 231
OK good luck Dave
- Davemitch (Fri Mar 06, 2020 11:39 pm)
Racing beat dual resonated decat now fitted, quietened her down a fair bit, obviously shes still quite loud though so will need to check noise level for track days
Well, removed exhaust, propshaft and that big beam (forgotten the name dean said ) and dropped fuel tank to check everything and why there was a leak, all supervised by dean of course
From the pic, the pump is the culprit that has been leaking and when dean inspected it wasn't fully down. This has now been fitted properly and tonight we have the task of checking the pipes and filling tank up to see if any leaks then refitting everything
- mi60o0
- Has thanked: 104 times
- Been thanked: 482 times
Look nice
LEXUS LS430 4.3 v8 family car
Done exhaust and work wheels
- mi60o0
Hks and racing beat is better than hks and toyo
I went from London to Yorkshire with hks single exit and toyo drone was unreal and my ears bleed
Update.
Fuel pump not seated correctly was my fuel leak! Thanks mazda but pressure tested, clips replaced with jubilee clips, and tank filled to the brim, drove it for an hour and not a leak in sight! 1 job ticked off - only another 5 million to go
Special thanks to dean for being a legend
- Pingping010101
- Has thanked: 161 times
- Been thanked: 75 times
Hi Dave,
Do you have any problems with the fascia kit you fitted? I have read bad reports on the Metra kit and yours is the only alternative I have heard of. I would be grateful for any feedback you can provide!
Absolutely none whatsoever, blowers all work like standard form and arent turning 1 million times like the metra kit. Highly recommend itPingping010101 wrote: ↑Wed May 06, 2020 8:58 amHi Dave,
- These users thanked the author Davemitch for the post:
- Pingping010101 (Wed May 06, 2020 10:53 am)
- warpc0il
- Has thanked: 826 times
- Been thanked: 3537 times
- Contact:
Kanatechs own website lists the shortcomings of this product, including
Which is pretty much the same as the later Metra version
https://kanatechs.com/products/tbxe/t003.html● This model is compatible with the Factory DVD car navigation system but the TV function is disabled. (TV function on the aftermarket car navigation system should operate.) Some functions such as the car navigation system operation sounds may be disabled.
● The clock and audio information in the information-center-display become disabled.
● Switching of the air conditioning control button becomes slow and soundless.
● When turning on the ignition, the information-center-display or the LED indicator on the heater control unit may flicker or be delayed.
● Automatic sound Level Control (ALC) becomes disabled.
● Dimming functions for the information-center-display or the heater control unit (LED) display that works when either head lights or parking lights are on are disabled.
● The heater control unit and the hazard lamp switch illuminate whenever ACC is on.
- Davemitch (Wed May 06, 2020 10:51 am) • Pingping010101 (Wed May 06, 2020 10:53 am)
Rotary revs d585s installed and new spark plugs fitted, still no improvement with flat spot and loss of power
- Markl17
- Has thanked: 120 times
- Been thanked: 405 times
Hi
I don’t know if you have tried this but my car had a flat spot between 4500 and 5500 rpm but would rev out no problem I tried all the usual suspects vac leaks ect.i finally tracked it down to the fuel pump regulator,I changed it and the car is back to normal.
Mark
Mark
I'll try this next - thanks!Markl17 wrote: ↑Mon Jun 08, 2020 6:23 amHi
Mark
- V8 Power
- Has thanked: 253 times
- Been thanked: 537 times
Could even be a blocked fuel pump filter restricting the flow?
I’ve seen some with massive amounts of gunge in them from a relatively low mileage.
All recommendations gratefully received, pulling whats left of my hair out at the minute trying to solve this! Injectors are another thing on my check list even though I keep reading they're bulletproof
- warpc0il
- Contact:
The injectors aren't bulletproof and can have issues.
What's becoming more common is corrosion on the electrical connections as the loom goes onto the injectors.
Both front arches replaced with rust free ones! get her looking prettier to motivate me to get back to fault finding this power loss
Few little jobs done recently, LED sidelights fitted, mazda oem footplate fitted, and gloss black door handle trims fitted oh and mot passed for another year
- ChrisHolmes (Wed Nov 04, 2020 10:00 am)
Finally got round to fitting the new spats and must say I'm happy with how they look not to everyone's taste I'm sure but certainly to mine
- GreySilver Beast (Thu Nov 26, 2020 11:03 pm)
