Wiggles Galaxy grey 231
wiggles
Has thanked: 82 times
Been thanked: 89 times
Re: Wiggles Galaxy grey 231
Post by wiggles » Thu Oct 12, 2017 7:33 pm
Right so as you may have seen from my other thread had a bit of a 'mare but front Tein street basis coilovers are now on (rears will be done when I get a chance)
Will adjust them when I find my spanners, once they are all done it is having a full 4 wheel alignment. Nearly at 900 miles now so not far off a trip to rotary motion and then let the beeping commence :D
Also discovered a "feature" today that if you turn the rear heated screen on it makes the radio signal go terrible...
Has thanked: 399 times
Been thanked: 1558 times
Post by warpc0il » Thu Oct 12, 2017 9:22 pm
There's an RF filter box in the back to stop that interference.
Sounds like yours isn't working (they can die) so a call to BigPete might be in order.
wiggles
Post by wiggles » Thu Oct 12, 2017 9:30 pm
Where is that located dave? hopefully its not part of the rear speakers as I just threw out a whole set today...
zippyonline
Has thanked: 48 times
Been thanked: 84 times
Post by zippyonline » Fri Oct 13, 2017 11:16 am
My BMW does that. For me it's because the earth strap breaks between the screen and the main body. There's a total of 4 of them, and they're £20/ea :shock:
wiggles
Post by wiggles » Sun Oct 15, 2017 10:43 pm
Just play cds when it is cold is my solution :lol:
Car has just ticked over 930 miles so going to get it booked in for 1000 mile service and then BEEEEEEEEEEEEEPS
Also I may have accidentally bought this...
wiggles
Post by wiggles » Fri Oct 20, 2017 11:37 pm
Finally ticked over 1000 miles today :D So off for a trip to rotary motion on thursday for oil change and hopefully sort the airbag light issue.
When it stops raining the rear coilovers will be fitted and they will all need adjusting as the front needs to go a bit lower so I assume the back will as well... then time for a 4 wheel alignment to make sure im not wrecking my tyres, which are awesome btw been really really wet last few days (even for Wales!) and the grip is still amazing had a nice blast home through the country lanes in the dark tonight!
Then once all that is sorted the decat and exhaust will be fitted as it is definitely too quiet then all I have to do is fit the RR coils and hopefully leave it alone for a while :shock:
Post by warpc0il » Sat Oct 21, 2017 12:09 pm
Then once all that is sorted the decat and exhaust will be fitted as it is definitely too quiet then all I have to do is fit the RR coils and hopefully leave it alone for a while get a chance to drive the wheels off it
Fixed that for you ;)
wiggles
Post by wiggles » Sun Oct 22, 2017 7:20 pm
I meant leaving it alone mechanically, driving wise it will get plenty of use ;)
The exhaust turned up today, i`m guessing I need a gasket for between the centre pipe and the backbox?
Aido 8
RX-8: 13B 6-port
Has thanked: 23 times
Been thanked: 11 times
Post by Aido 8 » Sun Oct 22, 2017 9:38 pm
I really think it's worthwhile to get a new fitting kit from your local exhaust shop for the sake of a few notes. You will have trouble free fitting 8) . One of My spring bolts snapped when taking of the stock exhaust so it was great peace of mind putting on the new gaskets etc in that the job would be done perfectly by yourself :thumright:
Hayward stage 2 Port,Full RB Exhaust, RB L-Flywheel,Michelin Pilot Super Sport,Bola B1, Aero Kit,Light weight Pulleys,More To Come :thumleft:
wiggles
Post by wiggles » Sun Oct 22, 2017 9:48 pm
I already bought a fitting kit with all the front gaskets for fitting the decat but at the time didn't have a catback, but got this for £100 so couldn't resist, so just need the back one.
wiggles
Post by wiggles » Sun Oct 29, 2017 7:22 pm
Got the exhaust fitted the other day got distracted and started messing with the rear shocks as well but not changed them yet, couldnt fit the decat as my socket in the right size was too long to fit in the space to undo the front nuts also I had 10 minutes left until I was picking the kids up from school when I had to do up the catback-cat bolts and apparently didnt do it enough as after a few days it has started to blow and sounds louder than a jet :lol: so will get the tools and sort that when I fit the cat
wiggles
Post by wiggles » Fri Nov 10, 2017 7:10 pm
Drove 100+ miles today to rotary motion and back for my first oil change. Treated her to a £5 wash first
Chris did some tests regarding the airbag light and it's definitely something in the bits in the rear passenger door where to seatbelt is rather than the seat (after unplugging etc) I couldn't leave it with them to have a look further as no way of getting home...
So will do my own investigations then take it back if I need to. Apparently the passenger seat was taken out when it was just a spare car in the workshop to put in the race car when Anthony Weeks was giving passenger rides at Forge event so possible it's just a dodgy connection somewhere as working fine before that.
mrspiller
Has thanked: 138 times
Been thanked: 326 times
Post by mrspiller » Fri Nov 10, 2017 7:14 pm
wiggles wrote:Drove 100+ miles today to rotary motion and back for my first oil change. Treated her to a £5 wash first
All good then , that’s weird , I don’t recall seeing Anthony ‘s car in forge this year ? Maybe it was the year before . It won’t be the first time I been wrong mind ....
wiggles
Post by wiggles » Fri Nov 10, 2017 7:19 pm
Not sure when think they had the car 2 years before I bought it. First job is check all the connectors behind the rear door card otherwise time to try a new seatbelt and hope it's not any wires before that causing the problem...
You wouldn't have a spare passenger seatbelt hanging around from one of your fleet would you Wayne?
mrspiller
Post by mrspiller » Fri Nov 10, 2017 7:23 pm
wiggles wrote:Not sure when think they had the car 2 years before I bought it. First job is check all the connectors behind the rear door card otherwise time to try a new seatbelt and hope it's not any wires before that causing the problem...
Yes I would , your welcome to have it , sounds a bit ominous does that . If the seat is removed I can’t see that would affect how it would be loose connection elsewhere
wiggles
Post by wiggles » Fri Nov 10, 2017 7:28 pm
Awesome, I'll see how it goes with checking the other stuff first.
Yeah that's what makes no sense, he hooked up the machine with and without the buckle/seat plugs in and those codes were there but went away when plugged in so not those connections.
Chris has said I can leave it there and they will swap some bits around to figure it out but just easier to try and sort myself than having to get home and back to pick it up from Chippenham if I can.
wiggles
Post by wiggles » Mon Nov 13, 2017 3:28 pm
Got a bit bored with grey wheels...
wiggles
Post by wiggles » Tue Nov 14, 2017 6:03 pm
Also had another "accidental" ebay purchase, seibon carbon wing for £130
Post by warpc0il » Tue Nov 14, 2017 9:12 pm
Nice...
wiggles
Post by wiggles » Tue Nov 14, 2017 10:55 pm
Nice...
yeah not bad considering the new price https://www.demon-tweeks.co.uk/Product. ... lsrc=aw.ds :shock:
Doesnt come with mounts though
Post by warpc0il » Tue Nov 14, 2017 11:04 pm
That link didn't work for me but this did
https://www.demon-tweeks.co.uk/Product. ... &p=1403368
Talk nicely to Seibon and they might sell you the mounts
http://seiboncarbon.com/large-gt-wing-rear-spoiler/
wiggles
Post by wiggles » Tue Nov 14, 2017 11:12 pm
weird both links work the same for me.
Ive found the mounts for sale (well look the same type) just need to work out what size to get IIRC the thread were Pete did the CFD needs to be about 20cm up from the boot to be in decent enough airflow to work
Been thanked: 785 times
Post by PeteH » Wed Nov 15, 2017 12:46 pm
Your wing is designed to be fairly close to the boot lid, so that it can take advantage of the different air flow at the centre and the sides. If you high mount it the air flow won't suit the variable wing shape, and you'll probably end up with loads of drag and no down force (maybe even rear lift!). I'd give it something like a 5 to 10cm gap to the boot lid and see how you go.
wiggles
Post by wiggles » Wed Nov 15, 2017 12:53 pm
Cheers Pete, I'll be honest and say it for looks more than anything but I might I might as well make it work!
zippyonline
Post by zippyonline » Wed Nov 15, 2017 12:56 pm
Active braking implementation please :D
