Wiggles Galaxy grey 231
- wiggles
- Has thanked: 77 times
- Been thanked: 86 times
Re: Wiggles Galaxy grey 231
- wiggles
Bought myself a birthday Christmas present...
[attachment=0]received_1537938029684607.jpeg[/attachment]
Got some new spark plugs to fit too see if it helps with my cold start issue.... Also time to get new wheels fitted and also really need to sort paintwork soon
- ChrisHolmes
- Has thanked: 9694 times
- Been thanked: 4899 times
Nice
- warpc0il
- Has thanked: 826 times
- Been thanked: 3537 times
- Contact:
I like black tools, until I'm working outside late in the evening, just as it's getting dark...
- wiggles
Main reasoning* behind the black version is I know what's out of this kit as all my other tools (except impact sockets...) Are silver so I can tell what goes where more easily and tell if my mates are trying to steel my tools when I invertible lend them out. My impact gun gets used more by other people than me...
*And black is cooler
- wiggles
So still need to change spark plugs, also looking for a new MAF/IAT sensor to try that. Cars starts 100% fine when hot but struggles sometimes if slightly less hot 40-60 minutes cool down and still struggles a bit from cold.
- wiggles
Changed the sparks today making full use of my new tools
Cold start exactly the same as before new(to me) MAF shouldbe here soon so that's the next thing.
Really struggling to understand what the issue is, cold starts are difficult, after a drive if I turn the engine off and try and start it again immediately it fires up instantly couldn't be better, but in some circumstances like earlier where I had been stationary for a while at the local car washing establishment I then went across the road for petrol and after filling up it was slow to start again, but then I drove down the road to Sainsbury's parked and then tried it again and started instantly after stopping there.
I guess if the IAT sensor is knackered the Being stationary/car left with hot engine for a while is making the under bonet temps higher and possibly throwing it off more than if it's just been running?
- zippyonline
- RX-8: Evolve
- Has thanked: 63 times
- Been thanked: 84 times
May have already covered it - but what's the starter motor like? That's been known for causing slow start issues on cold.
- 13Black
- Been thanked: 811 times
- Contact:
With the plugs out it'd be a good time to do a poor man's comp test to check for even chuffs, if a proper comp tester isn't available.
- bigpete8
- Has thanked: 275 times
- Been thanked: 270 times
You'd think with all these new compression testers out there we could arrange a relatively cheap hire scheme.... (hint for anyone listening that fancies hiring one out)
- wiggles
On my own and near a busy road so wouldn't have heard anything apart from lorries unfortunately... The fact that it starts best when hot as it possibly could be make me hope compression isn't the issue. Still has warranty until August on the engine worst case anyway
- mi60o0
- Has thanked: 104 times
- Been thanked: 482 times
I will recommend you to do compression test on it and if it need rebuild don’t wait until end of warranty
LEXUS LS430 4.3 v8 family car
Done exhaust and work wheels
- 13Black
- Contact:
I don't -think- the car uses IAT when starting (happy to be told otherwise) and will start/idle with the MAF disconnected altogether - from memory it just has a set injector pulse width or something. Might not be worth taking too much resources exploring. A datalog of various conditions etc should say if it's misreading as I have plenty of data to compare it against.
- wiggles
Easy enough to swap to rule it out but that doesn't sound promising.
The fact it starts perfectly from a bump start still makes.me think it's some kind of problem with voltage/earthing while cranking... Always starts and runs fine just s case of how long it takes to start
- 13Black
- Contact:
I'd be surprised (but therefore mistaken) if it's cranking at 340rpm with a bad connection - rarely get healthy R3s crank quite that fast. But, it's another quick/cheap thing to check, so no harm in doing so!
- mi60o0
Did you clean the crank sensor when I get my car was starting slow I unplug and clean it and clean the magnet start instant now
- wiggles
I haven't done that actually... Will try that as well.
My obd reader started playing up shortly after that reading so I don't trust it's accuracy tbf.
- mi60o0
If you remove the airbox you have plenty of acces to reach and clean
- mrspiller
- Has thanked: 280 times
- Been thanked: 763 times
If your stuck pop up on Sunday , I’m pretty sure I got all the bits you’ll need to swap
- wiggles
Will definitely try that sensor next, thanks
Thanks Wayne I'll be away this weekend (not in my car) but will see how things go and having a few parts to swap for elimination could be useful.
Electricity is not my strong point so correct me if this might blow up my car... But for elimination purposes could I get another ground wire from battery to somewhere on the chassis just to try and make sure that isn't an issue?
- warpc0il
- Contact:
That's a good diagnostic check; run a jump lead from the battery negative to the lifting eye on the engine block, and see if it makes any difference.
- wiggles
Got around to getting the tyres swapped to the new wheels today the rock definitely won against this one
- Scartlead
- Has thanked: 83 times
- Been thanked: 126 times
- mi60o0
Any better with the cold and hot start ?
- wiggles
Hasn't changed the start but was a lot cleaner than my MAF so seems a bit smoother through the revs, thanks
