RR54 SC Track Project 297hp & 221lbft @ Flywheel
Has thanked: 6690 times
Been thanked: 3357 times
Re: RR54 SC Track Project 297hp & 221lbft @ Flywheel
AEM responded to my request for support by sending the resistance values for each terminal off the coils and all my coils tested in line with the values advised.
I couldn’t find a resistance value to check the ESS but it reads the same as two other ESS that I have.
I noticed that the trigger wheel was bent but it must have always been like that so is not the cause of the non startling but will be replaced anyway.
Hopefully I will get the engine out and stripped tomorrow and find out why I yet again have a stuck side seal on the rear rotor!
With all the belts off the E shaft turns smoothly without the binding that was evident when it was turned at Castle Combe!
AB Bucket seats & 5 point harnesses
Rebuilt 6 port
Pettit SC
Racing Beat alloy flywheel, oil lines & ARBs , REV 8 Full SS Exh
Stg1 Exedy Clutch
AEM Smart Coils & MSD leads
Remote oil filter
Tein MonoSports & EDFC
Fully polybushed
Racing Brake 4 Pot Calipers
MazdaSpeed skirts & Rear Spoiler
Lockwood SS Grills
Has thanked: 614 times
Been thanked: 2628 times
Any disturbance of the ESS and/or its trigger wheel, would require a 20-stomp reset with the oem PCM.
What equivalent is there with your setup?
That’s a good question Dave, I don’t know!
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Has thanked: 1712 times
Been thanked: 821 times
Post by nightfire10 »
Better not be paper towel
Sent from my SM-G991B using Tapatalk
mrspiller (Wed Oct 13, 2021 9:28 pm)
Has thanked: 33 times
Been thanked: 289 times
Post by 350matt »
ChrisHolmes wrote:
Wed Oct 13, 2021 7:06 pm
thats a oddity of the Mazda ECU
its not normal practice
you set the tooth setup in the ECU and then leave it alone on every other ECU I've encountered
I'd suspect som ekind of ECU issue or lack of ESS signal getting to the ECU from what you've described
ChrisHolmes (Thu Oct 14, 2021 3:08 pm)
Having a break. Just the engine mounts to undo and remove out of the way now and then it’s attach the lifting sling and out with the engine.
Oh, before that I need to assemble the engine crane!
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Here's an engine for you Chris ImageImage
You are at the car museum in Cumberland, a great little place to discover!
nightfire10 (Thu Oct 14, 2021 9:55 pm)
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Engine is out, sump off and no signs of any bearing material.
Eshaft had end float so that’s ruled out for causing the tightness.
Off to the Allsorts meet now so it will be tomorrow afternoon before I get the motor opened up to see what’s what in there!
Exhaust ports are a good colour so when it was running the mixture was ok.
Honkytonk (Thu Oct 14, 2021 10:12 pm)
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Velocity_Dan93
Has thanked: 40 times
Been thanked: 123 times
Post by Velocity_Dan93 »
Looks like and easy fix hopefully, just drop and new seal it and bang it back in :lol:
All of the rotors, none of the compression
ChrisHolmes wrote:You are at the car museum in Cumberland, a great little place to discover!
Windermere
After 3 1/2 hours the e shaft front bolt, flywheel nut and counterweight finally surrendered, as did my spigot bearing thanks to the puller screw!
So whilst things are much worse than I expected inside the engine the list of parts required for the rebuild is quite short. The front and rear plain bearings are totally fine, one rear side seal was not totally free to move so must have some debris in the groove but shows no sign of damage.
Water Seal Set x 1
Apex seals x 6
Rotor Housings x 2 ( Already have a good pair)
Spigot Bearing x 1
So the damage is shown in the photos and is listed below;
Front rotor triangular impact damage on one face
All apex seals have chipped sealing faces
One apex seal has the pointed end missing
Two end pieces missing
Housing deeply scored
Rear rotor slight impact damage
Housing scored
Initially I thought the apex seal tips may have snagged on the bridge port edge but as the housings are not cut out to match irons eyebrow I cannot see that being the cause so aside from detonation I cannot think of any other cause of the damage.
P1130829 Front Rotor Housing (Medium).JPG (109.36 KiB) Viewed 100 times
P1130825 Front Rotor Apex Seal Broken Tip (Medium).JPG (146.24 KiB) Viewed 100 times
P1130824 Front Rotor Apex Seal (Medium).JPG (139.94 KiB) Viewed 100 times
P1130821 Front Rotor Apex Seal (Medium).JPG (140.74 KiB) Viewed 100 times
P1130819 Front Rotor Apex Seal (Medium).JPG (142.95 KiB) Viewed 100 times
P1130818 Front Rotor Face 3 (Medium).JPG (132.94 KiB) Viewed 100 times
P1130817 Front Rotor Face 2 (Medium).JPG (131.63 KiB) Viewed 100 times
P1130816 Front Rotor Face 1 (Medium).JPG (150.16 KiB) Viewed 100 times
P1130814 Front Rotor Damage (Medium).JPG (129.81 KiB) Viewed 100 times
P1130813 Rear Housing Good section (Medium).JPG (105.91 KiB) Viewed 100 times
P1130812 Rear Rotor Housing Scored (Medium).JPG (84.4 KiB) Viewed 100 times
P1130811 Rear Rotor Housing Scored (Medium).JPG (90.7 KiB) Viewed 100 times
P1130810 Rear Rotor Face 3 (Medium).JPG (114.43 KiB) Viewed 100 times
P1130809 Rear Rotor Face 2 (Medium).JPG (114.77 KiB) Viewed 100 times
P1130808 Rear Rotor Face 1 (Medium).JPG (92.33 KiB) Viewed 100 times
P1130807a Apex seal Broken tip (Medium).JPG (123.8 KiB) Viewed 100 times
P1130807 Rear Rotor Apex Seal (Medium).JPG (84.6 KiB) Viewed 100 times
P1130806 Rear Rotor Apex Seal (Medium).JPG (129.42 KiB) Viewed 100 times
P1130805 Rear Rotor Apex Seal (Medium).JPG (101.87 KiB) Viewed 100 times
P1130804 Rear Rotor Damage (Medium).JPG (99.96 KiB) Viewed 100 times
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Vj4sothername
Has thanked: 2224 times
Been thanked: 513 times
Post by Vj4sothername »
We need a dislike button.....
You had an air filter on right? That's some serious damage.
These users thanked the author Vj4sothername for the post:
ChrisHolmes (Fri Oct 15, 2021 9:06 pm)
S1 - 231 - brilliant black
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
Vj4sothername wrote:
Fri Oct 15, 2021 8:01 pm
Caused by the bits of apex seals not staying where they should!
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Vj4sothername
Will you stick with 7 seals or back to 8s?
Feb 08 built,
PZ back box,
PZ suspension,
Scratches,
Replacement engine,
Smiles
The deeper 7 seals, but will be going for Goopies this time and no porting.
Velocity_Dan93 (Sat Oct 16, 2021 9:06 pm)
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Paul_13
Has thanked: 114 times
Been thanked: 243 times
Post by Paul_13 »
Ouch
These users thanked the author Paul_13 for the post:
Post by 350matt »
Any Idea of howmuch spark you're running at full load Chris? also how restrictive is the exhaust system?
Media Team
Media Team
Has thanked: 361 times
Been thanked: 757 times
Post by Honkytonk »
Ooof, RIP that front rotor. Sorry to see the damage is that bad Chris. Best of luck with the rebuild!
Paul_13
Post by Paul_13 »
Do you premix? And is your OMP working properly?
Just trying to figure out why that's failed
By how much spark I presume you mean ignition advance, I will need to look at the map and it’s on the laptop in the garage.
The exhaust is the Racing Beat REV8 full exhaust billed as 3” but the ends of the dual resonated section are both 2 1/2” I presume to allow for fitment onto OE manifolds and cat back pipes.
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Honkytonk wrote:
Fri Oct 15, 2021 10:22 pm
The rotor damage looks bad but is superficial and hasn’t closed up the apex seal groove. It will live on.
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Paul_13 wrote:
Fri Oct 15, 2021 10:24 pm
No friction striations anywhere which isn’t surprising as I premix 300ml at every fill up which is usually from 1/4 tank and the OMP rate has been increased.
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
Paul_13
Post by Paul_13 »
Who rebuilt the engine? (please don't punch me if this offends!)
Paul_13 wrote:
Fri Oct 15, 2021 10:40 pm
I built the engine, but don’t let that hold you back suggesting any possible cause!
Rebuilt 6 port
Pettit SC
Stg1 Exedy Clutch
Remote oil filter
Fully polybushed
Lockwood SS Grills
