Paul's RX-5
Paul_13
Has thanked: 74 times
Been thanked: 129 times
Re: Paul's RX-5
Post by Paul_13 » Sat Jun 27, 2020 10:05 pm
I ended up getting some draft seal strips from screw fix which will do the job.
Made good progress tonight and then got rained off :finger:
ECU box is now mounted. I've trimmed down the battery box and it JUST fits.
Started to apply the tape to the radiator and that's when the heavens opened.
Excuse the speed holes. Need to source a new lid
Lemon
Has thanked: 29 times
Been thanked: 164 times
Re: Paul's RX-5
Post by Lemon » Sat Jun 27, 2020 11:57 pm
Wait... An RX8 airbox fits in an NC?
Stop giving me ideas damnit!
Sent from my Nokia 6.1 using Tapatalk
Thanks, Stu
Has thanked: 399 times
Been thanked: 1572 times
Re: Paul's RX-5
Post by warpc0il » Sun Jun 28, 2020 12:07 am
Yes
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Mon Jun 29, 2020 6:27 pm
Ugh I still haven't text him
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Tue Jun 30, 2020 12:09 am
Battery mounted
Nearly there
These users thanked the author Paul_13 for the post:
Vj4sothername (Tue Jun 30, 2020 1:15 pm)
Lemon
Re: Paul's RX-5
Post by Lemon » Tue Jun 30, 2020 1:10 pm
Loads of room, you could build a 4 bed house in that space!
Thanks, Stu
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Tue Jun 30, 2020 11:09 pm
Tighter than a nun's c u next tuesday.
No idea how I'm going to get that acordian pipe on. Need to shave a bit off the VFAD mouth, it clashes with the bumper. Should have it back on 4 wheels tomorrow evening.
Expansion bottle is mounted.
Vj4sothername (Wed Jul 01, 2020 3:33 am)
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Wed Jul 01, 2020 10:43 pm
Vj4sothername wrote:
Sun Jun 07, 2020 3:00 pm
Paul_13 wrote:Wish I didn't start this now.
Mx5 fuse box is going to be fun transferring all the bits over.
You can do it!
Although I see some swearing when you try and get the accordian pipe on.
You weren't wrong. [edited] me that was hard. Ended up having to remove all of the upper inlet manifold bolts apart from one, move the inlet back. Bolt up the throttle body and then push it into the acordian pipe.
Engine bay all back together now :)
Tomorrow's job is to finish off the front bumper
Vj4sothername (Wed Jul 01, 2020 10:54 pm)
Vj4sothername
Has thanked: 794 times
Been thanked: 168 times
Re: Paul's RX-5
Post by Vj4sothername » Wed Jul 01, 2020 10:55 pm
Nice work. Fingers crossed this ends the issues you've been having.
S1 - 231 - brilliant black
Feb 08 built,
Fake Toyosport back box,
Dents,
Scratches,
Replacement engine,
Smiles
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Wed Jul 01, 2020 10:57 pm
If it doesn't fix the problem, but ends up being quieter, I'll be happy
Re: Paul's RX-5
Post by warpc0il » Wed Jul 01, 2020 11:05 pm
I wonder if you could have taken a couple of creases out of that accordion pipe, with a sharp knife, and super-glued it back together, leaving it able to still wriggle.
The airbox is fixed to the front crash structure but the intake manifold needs to move with the engine on its mounts....
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Wed Jul 01, 2020 11:26 pm
I appreciate that, I've been looking for an aftermarket intake boot, but they're either mega money, or come part of a kit
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Thu Jul 02, 2020 10:40 pm
All back together
These users thanked the author Paul_13 for the post (total 6):
Vj4sothername (Thu Jul 02, 2020 10:46 pm) • V8 Power (Fri Jul 03, 2020 8:03 am) • nightfire10 (Fri Jul 03, 2020 8:35 am) • ChrisHolmes (Fri Jul 03, 2020 11:48 am) • New Duke (Sat Jul 04, 2020 12:23 am) • v-rex (Sat Jul 04, 2020 10:27 am)
Has thanked: 141 times
Been thanked: 325 times
Re: Paul's RX-5
Post by V8 Power » Fri Jul 03, 2020 8:03 am
Excellent job.
You would never know from the outside what lurks beneath.
Direct cold air feed
RRP Coils MSD leads
Has thanked: 20 times
Been thanked: 107 times
Re: Paul's RX-5
Post by 350matt » Fri Jul 03, 2020 12:18 pm
V8 Power (Fri Jul 03, 2020 12:22 pm)
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Fri Jul 03, 2020 3:32 pm
Good shout. Need to figure out how to connect the breather hoses to it
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Fri Jul 03, 2020 3:35 pm
Sorted
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Fri Jul 03, 2020 11:32 pm
Didn't manage to go for a test drive tonight as I got drunk and had a zoom quiz with car mates.
For peace of mind I plugged in the obd reader and scanned for any codes with forscan and conducted a few tests. Everything checks out OK, so happier about the test drive tomorrow
Vj4sothername (Sat Jul 04, 2020 8:28 am)
Has thanked: 656 times
Been thanked: 557 times
Re: Paul's RX-5
Post by New Duke » Sat Jul 04, 2020 12:30 am
I got my used one from bigpete. Was a bargain at £20 for the air box, tray and accordion pipe. He had a few of them.
Engine bay looks excellent BTW :thumleft:
Re: Paul's RX-5
Post by 350matt » Sat Jul 04, 2020 9:47 am
nice work
let us know how it goes
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Sat Jul 04, 2020 11:56 am
Drives well. It's quieter.
Only problem is the PAS isn't kicking in. Fault code present
Re: Paul's RX-5
Post by warpc0il » Sat Jul 04, 2020 2:21 pm
Did you work the ps lock-to-lock a couple of times before driving off?
It needs this to perform the self-test after reconnecting the battery.
If it's not that then it's back to basics, as you've had so much apart.
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Sat Jul 04, 2020 4:59 pm
Pretty sure it's the earth lead connector, the white one nearish to the battery. When connected it was reading high resistance on an ohm test. Took the plug apart and cleaned it and the resistance dropped to zero :) yet to drive it to
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Sat Jul 04, 2020 5:38 pm
Problem solved :). Weird how it worked before hand
These users thanked the author Paul_13 for the post (total 3):
Vj4sothername (Sat Jul 04, 2020 6:06 pm) • warpc0il (Sat Jul 04, 2020 6:43 pm) • Ainmhidh (Sat Jul 04, 2020 7:51 pm)
Paul_13
Re: Paul's RX-5
Post by Paul_13 » Sat Jul 04, 2020 11:09 pm
The power delivery has definitely changed,
It's quieter.
But bloody hell does it heat up when stood idling.
