JDM Castle Combe 2019 - Saturday 1st June
Past events that the Club & Members have attended. Read-only.
Has thanked: 153 times
Been thanked: 532 times
Re: JDM Castle Combe 2019 - Saturday 1st June Bring a hat and sun cream it's going to be hot
Post by qwakers » Sun Jun 02, 2019 11:16 am
many thanks to all for another excellent day, im now wishing id bothered with sun cream, i have a burned head :)
all went well with my car until i destroyed the brakes and had to come off, i was being nice to the engine as it isnt mapped properly yet (ironically my new tactrix was waiting for me when i got home!) so i was trying to make up time by breaking later and later into corners. despite not using all the rev range i was keeping up with cars that should have been disappearing into the distance, so im quite pleased with that!. when its mapped this car is going to be FAST!.
Lemons car was a interesting problem to trouble shoot. he got towed off track and pushed back to the pits after the last session of the day, it was hot but not nuclear. first two things to be seen was the total lack of coolant in the expansion bottle and a trailing lead had come off a coil. first thoughts was it had got hot enough for a engine protect condition to cause it to cut out, especially as it APPEARED to have fuel pressure (strong smell from the exhaust and pressure in the lines when i popped a fuel connection to check, and the testers showed a spark, but when it had cooled down and the coolant topped back up, it still didn't even splutter when turned over. next thing stu took all the plugs out to show a total horror show! all the leading plugs had had the electrodes burned away and the trailings wherent much better, plus they where white! showing a serious lean condition. add to this stu had had a oil burp so his air filter and maf was soaked in oil, and we though we’d found the issue!.
so the plugs and maf came off my car and onto his, the air filter came out and we tried again, no dice.
next we tried a tow start thinking the loss of spark had caused a flooding issue, but also no dice,
lastly we started to look at the fuel system, out came the rear seat and we found that the fuel pump was not running. so we checked the fuel pump fues, and that was ok. i then tried looping out the fuel pump relay, no dice, then i tried bypassing the circuit relay and off it went, pump running and car started. ok, thats interesting, relay must be faulty, sez i, so we tried another relay, no dice. so i started pulling every fuse in the fuse box one at a time, and there we have it, a blown fuse, replaced it and it blew straight away.
so, in the end, lemon drove his car home (only a couple of miles) with a bit of wire bridging the curcuit relay, and i packed all my tools and test stuff up (all alone :) ) and set off home... to find the gates shut and locked! i ended up driving all the way though the paddock to the main gate, which they where just closing, and set off home, got home at 11pm, so that was a long day, but a good one!
These users thanked the author qwakers for the post (total 6):
ChrisHolmes (Sun Jun 02, 2019 11:30 am) • stewartm (Sun Jun 02, 2019 11:56 am) • Reloy (Sun Jun 02, 2019 12:35 pm) • casey (Sun Jun 02, 2019 1:47 pm) • Shagrington (Sun Jun 02, 2019 4:05 pm) • GreySilver Beast (Sun Jun 02, 2019 11:13 pm)
Has thanked: 4634 times
Been thanked: 1953 times
Post by ChrisHolmes » Sun Jun 02, 2019 11:32 am
Superb support from you for Stu James, the support members receive if they have a problem at events is epitomised by how you acted, thank you.
GreySilver Beast (Sun Jun 02, 2019 11:15 pm)
Bridge Ported 231
MazdaSpeed sills
Short shifter
Has thanked: 384 times
Been thanked: 1474 times
Post by warpc0il » Sun Jun 02, 2019 11:35 am
mrspiller wrote:
Sun Jun 02, 2019 11:14 am
warpc0il wrote:
Lemon wrote:
Sat Jun 01, 2019 8:35 pm
It looked like it had burned away tbh Jon
I've kept the plugs anyway
We did turn it over with the plugs removed and it all sounds very even.
What plugs were you running?
I *know* people say that "hot plugs" are fine for track work but Mazda themselves were very clear that they should only be used for cars that spend their time pootling around in traffic, especially the US/JDM autos that change at at too low revs.
What plugs would you say are ideally suited for a track only car ?
I run the NGK Iridium versions of the standard
Trailing - NGK RE9B-T
Leading - NGK RE8C-L
mrspiller (Sun Jun 02, 2019 11:37 am)
mrspiller
Has thanked: 129 times
Been thanked: 283 times
Post by mrspiller » Sun Jun 02, 2019 11:38 am
warpc0il wrote:
warpc0il wrote: What plugs were you running?
Thanks Image
Lemon
Has thanked: 29 times
Been thanked: 163 times
Post by Lemon » Sun Jun 02, 2019 11:43 am
Lemons car was a interesting problem to trouble shoot. he got towed off track and pushed back to the pits after the last session of the day, it was hot but not nuclear. first two things to be seen was the total lack of coolant in the expansion bottle and a trailing lead had come off a coil. first thoughts was it had got hot enough for a engine protect condition to cause it to cut out, especially as it APPEARED to have fuel pressure (strong smell from the exhaust and pressure in the lines when i popped a fuel connection to check, and the testers showed a spark, but when it had cooled down and the coolant topped back up, it still didn't even splutter when turned over. next thing stu took all the plugs out to show a total horror show! all the leading plugs had had the electrodes burned away and the trailings wherent much better, plus they where white! showing a serious lean condition. add to this stu had had a oil burp so his oil filter and maf was soaked in oil, and we though we’d found the issue!.
could only limp the car home though, i presume it was only running the low pressure fuel pump circuit.
Thanks, Stu
boosted
Has thanked: 74 times
Been thanked: 384 times
Post by boosted » Sun Jun 02, 2019 11:46 am
Well done qwakers for getting it going.
231 streetported Rx8 renny powered Westfield kit race car.
92 Rx7 fd3s stock twins..est.320bhp. Track car.
sKenDread
Has thanked: 192 times
Been thanked: 140 times
Post by sKenDread » Sun Jun 02, 2019 11:59 am
A huge thank you to the organisers for making a great first time event for Sarah and I. Finally got to meet some faces and yep I'm still crap with names but you all are a very lovely crew.
Sarah's got the drift bug now. God help me. And now she wants to buy an 8 too!
We both decided to go home after the event. Sun burnt and worn. She was going on all 2.5 hrs about how she's going to make my car pink. So it looks like we're getting a 3rd car on the driveway... Poor neighbors
I cannot say thank you all enough
08 231 West Midlands.
RR D585 Coils, RRP COFS, miniMelon Map, Powerflow Twin Exhaust, 245 40r18 Uniroyal Rainsport3. Original engine 75k mi
These users thanked the author sKenDread for the post (total 2):
ChrisHolmes (Sun Jun 02, 2019 12:24 pm) • GreySilver Beast (Sun Jun 02, 2019 11:16 pm)
Kia-ora!
RRP Performance Ignition Coil System MKII | miniMelon Map | RRP COFS | Powerflow Twin Exhaust
Original engine 80k
AdamGaltress
Has thanked: 188 times
Been thanked: 460 times
Post by AdamGaltress » Sun Jun 02, 2019 12:02 pm
If anyone can't wait until next year to go back we are returning to Castle Combe later this year for Forge Action Day - The whole event is organised and run by the same team that have done JDM combe :thumleft:
Clicky link for anyone interested
viewtopic.php?f=101&t=78806
These users thanked the author AdamGaltress for the post (total 2):
Bigblueknight3k (Sun Jun 02, 2019 12:23 pm) • GreySilver Beast (Sun Jun 02, 2019 11:18 pm)
AdamGaltress
Events Team & Comms Team
JDM RX-7 FD - Project Thread
Bridgeport Copper Red MazdaSpeed Evolve - Project Thread
- Parted out
sKenDread
Post by sKenDread » Sun Jun 02, 2019 12:14 pm
Edit: wrong one!!! Meant to be Forge! Can you please add Sarah and I too
For Stand and club track please
These users thanked the author sKenDread for the post:
Kia-ora!
Original engine 80k
Post by qwakers » Sun Jun 02, 2019 3:16 pm
i think thats already been explained, quite a lot of the ancillaries and ecu where unpowered :oops:
i just treat others as id like to be treated. id hate to be left in the paddock with a dead car and everyone else justs leaves :mrgreen:
ive been in clubs that do that, and its awful. luckily, thats not the rx8 owners club :!:
These users thanked the author qwakers for the post (total 7):
goodeggbob (Sun Jun 02, 2019 3:28 pm) • Bigblueknight3k (Sun Jun 02, 2019 3:28 pm) • Shagrington (Sun Jun 02, 2019 4:07 pm) • boosted (Sun Jun 02, 2019 5:08 pm) • nightfire10 (Sun Jun 02, 2019 5:26 pm) • ChrisHolmes (Sun Jun 02, 2019 8:12 pm) • GreySilver Beast (Sun Jun 02, 2019 11:19 pm)
brix79
Has thanked: 97 times
Been thanked: 332 times
Post by brix79 » Sun Jun 02, 2019 5:11 pm
Bigblueknight3k wrote:
Sat Jun 01, 2019 6:37 pm
A very big thank you to the rx8 club owener for giving me the chance to go on track and your track ticket...
Club owner is a bit of a stretch, but I'm glad you enjoyed your session. :thumright:
Delighted to see that the event went so well for everyone, and also such good experiences from those attending their first Club event.
A big thanks to the Events Team! =D>
Apologies for not being there myself, it's the first JDM I've missed since my first one back in 2014? when it was Japfest. I was on a mission to see the CL game at the Spurs stadium. That does not happen every year!
These users thanked the author brix79 for the post (total 3):
Bigblueknight3k (Sun Jun 02, 2019 5:47 pm) • ChrisHolmes (Sun Jun 02, 2019 8:14 pm) • GreySilver Beast (Sun Jun 02, 2019 11:19 pm)
Chairman & Forum Admin Team
2017 // 2010 Aurora Blue R3
AMH
Has thanked: 30 times
Been thanked: 116 times
Post by AMH » Sun Jun 02, 2019 5:25 pm
Neil’s finally sorted through his 1,000+ photos, here’s the result (with a few from me as well):
https://photos.app.goo.gl/FdUc2Q6Hv3Mu5jiPA
If anyone wants any full resolution versions let me know. :)
These users thanked the author AMH for the post (total 6):
Reloy (Sun Jun 02, 2019 5:32 pm) • warpc0il (Sun Jun 02, 2019 5:34 pm) • jondkent (Sun Jun 02, 2019 6:05 pm) • Shagrington (Sun Jun 02, 2019 7:59 pm) • ChrisHolmes (Sun Jun 02, 2019 8:15 pm) • GreySilver Beast (Sun Jun 02, 2019 11:20 pm)
1st March 2005 - 31st Dec 2009: Strato 192 with Mega Bling Alloys - TWOC :( :thumbsdown:
Delivered 12th March 2010: Aurora Blue R3 \:D/ :thumbsup:
Post by warpc0il » Sun Jun 02, 2019 5:37 pm
Yesterday I couldn't even spell "vicarious" and now I'm browsing that album :D
boosted
Post by boosted » Sun Jun 02, 2019 5:43 pm
Thanks from me!! Great piccys and vids!!
nightfire10
Has thanked: 765 times
Been thanked: 309 times
Post by nightfire10 » Sun Jun 02, 2019 7:25 pm
Big thanks to Sharington for the bonnet badge !
Shagrington (Sun Jun 02, 2019 8:00 pm)
SeeJay
Has thanked: 168 times
Been thanked: 360 times
Post by SeeJay » Sun Jun 02, 2019 8:20 pm
I was on a mission to see the CL game at the Spurs stadium...
So John,you chose to watch 22 blokes in shorts kick a bag of air around a field,instead of luxuriating in the presence of gorgeous Japanese show cars :?: .. :lol:
brix79
Post by brix79 » Sun Jun 02, 2019 9:24 pm
I know, given the wonder of hindsight, it may not have been the best idea. But it could have been glorious. :lol:
Has thanked: 9559 times
Been thanked: 2298 times
Post by GreySilver Beast » Sun Jun 02, 2019 11:43 pm
Well that was another good Event that everyone seem to enjoy as it's the social side that is the best out of it and the cars are secondary to the event =D> =D> =D> =D>
A big thanks must go to
ChrisHolmes who once again pulled off an fantastic day for you all to enjoy =D>
Hope you all enjoyed being bossed around by Nigel when it came to parking your cars in the Morning on the Stand and hope you were all very pleased with your present from him :thumright: :kinky:
We had a wonderful mixture of cars on the Stand this year including the following Non-Rotaries :lol:
2x Mazda MX-5 MK3
2x Toyota GT86's
1x Mazda MX-5 MK1
1x Honda Civic Type R
1x Mazda CX-7 + Trailer
1x Volvo V70
1x Vauxhall Vivaro Van + Trailer
1x Daf Lorry
All that remains to be said hope you all enjoyed the day and look forward to seeing you all at another Event this year :thumleft:
The Team packing up after everyone gone home :twisted:
These users thanked the author GreySilver Beast for the post (total 2):
bc-49 (Mon Jun 03, 2019 8:06 am) • ChrisHolmes (Mon Jun 03, 2019 10:05 am)
R.A.C.E Car Club
GSB III 03/08/13 - Present
bc-49
Has thanked: 58 times
Been thanked: 61 times
Post by bc-49 » Mon Jun 03, 2019 8:12 am
Thanks Chris, Nigel and everyone involved for making this another great event! Amazing weather as seems to be typical for this event the last few years.
A great day all round, see some of you this Sunday for Tunerfest!
These users thanked the author bc-49 for the post (total 2):
GreySilver Beast (Mon Jun 03, 2019 9:32 am) • ChrisHolmes (Mon Jun 03, 2019 10:04 am)
2006 Galaxy Grey 231
Yokohama V105 | Eibach Pro-Kit Springs | Eibach 20mm Spacers | Mintex 1144 Pads | Racing Beat REV8 Catback | BHR Ignition | K&N Filter | Koyorad Alu Radiator | Mishimoto Thermostat | Greddy Sump | ER Braided Oil Lines | ER Oil Pressure Reg | ER Baffle Plate | Lockwood Front Grills
casey
Has thanked: 971 times
Been thanked: 1157 times
Post by casey » Mon Jun 03, 2019 10:24 am
My thanks to Chris and everyone else involved in organising and helping out during the day. Special thanks to Karen and Rachel for my tasty bacon roll! The scones and cake were delicious too 😊
Although I spoke to quite a number of people, in looking through the list I missed a few, so apologies to those I didn't speak to! The day just flew by, but most enjoyably.
I'm not yet back home, but will sort through the pictures I took later and post up a few, if they are worthy (having seen the great pics already posted by Neil and others!).
Another great event at Castle Combe, made even more so by the perfect weather 8)
These users thanked the author casey for the post (total 2):
GreySilver Beast (Mon Jun 03, 2019 10:26 am) • ChrisHolmes (Mon Jun 03, 2019 10:28 am)
Club Secretary
Seibon Carbon Fibre Bonnet
casey
Post by casey » Mon Jun 03, 2019 8:31 pm
So, I'm back home now and have uploaded a shedload of pics, mainly from the 2.15 and 2.45 track sessions.
All pictures are as they came out of my camera. Some would improve with cropping and some tweaking ;)
https://photos.app.goo.gl/mskg1WzpWgpQP72Y6
All are high res, so feel free to download any you might want.
Some samples........
June JDM Combe I.jpg (410.13 KiB) Viewed 394 times
June JDM Combe H.jpg (382.61 KiB) Viewed 394 times
June JDM Combe G.jpg (379.28 KiB) Viewed 394 times
June JDM Combe F.jpg (377.14 KiB) Viewed 394 times
June JDM Combe E.jpg (353.37 KiB) Viewed 394 times
June JDM Combe D.jpg (422.9 KiB) Viewed 394 times
June JDM Combe C.jpg (386.2 KiB) Viewed 394 times
June JDM Combe B.jpg (337.43 KiB) Viewed 394 times
June JDM Combe A.jpg (422.88 KiB) Viewed 394 times
These users thanked the author casey for the post (total 7):
warpc0il (Mon Jun 03, 2019 8:36 pm) • GreySilver Beast (Mon Jun 03, 2019 8:44 pm) • Reloy (Mon Jun 03, 2019 9:02 pm) • jondkent (Mon Jun 03, 2019 9:40 pm) • TerryH (Mon Jun 03, 2019 10:19 pm) • ChrisHolmes (Mon Jun 03, 2019 10:31 pm) • Ian.Mothersole (Thu Jun 06, 2019 6:55 pm)
Club Secretary
Smedley
Has thanked: 91 times
Been thanked: 80 times
Post by Smedley » Tue Jun 04, 2019 1:57 pm
Great day again with the club. All runs like clockwork which shows how good the organisation is. Thanks to the events team, appreciated. Really enjoyed the track session too. Roll on 2020.
These users thanked the author Smedley for the post:
GreySilver Beast (Tue Jun 04, 2019 6:50 pm)
231 Brilliant Black
Cream leather
Full OEM aero kit
SS strakes
Tinted
Toyosport catback
23mm spacers
Carbon bonnet and mirror wraps
Tastefully stickered.....
Post by GreySilver Beast » Wed Jun 05, 2019 1:56 pm
JDM 2019 Sticker on the side of my car :thumleft: - Events Team
R.A.C.E Car Club
mi60o0
Has thanked: 88 times
Been thanked: 275 times
Post by mi60o0 » Wed Jun 05, 2019 2:34 pm
I stick mine when you give it to me
BatRex 192 stock
boosted
Post by boosted » Wed Jun 05, 2019 5:00 pm
Seem to be lacking on track vids this year..hoping to see some footage of mine in the bends. I was out once at 12.30 sess.
Return to “The Vault”
