JDM Castle Combe 2019 - Saturday 1st June
Past events that the Club & Members have attended. Read-only.
thegoose50
Re: JDM Castle Combe 2019 - Saturday 1st June Bring a hat and sun cream it's going to be hot
Post by thegoose50 » Sat Jun 01, 2019 6:59 pm
boosted wrote:
Sat Jun 01, 2019 6:06 pm
Big thanks for organising this, always great day and great company.2019 jdm brill Got burnt face...lol
Stu ok? Image
Stu ok....I left during last drift as had to get back did something happen?
These users thanked the author thegoose50 for the post:
ChrisHolmes (Sun Jun 02, 2019 11:25 am)
nightfire10
Has thanked: 768 times
Been thanked: 311 times
Post by nightfire10 » Sat Jun 01, 2019 7:24 pm
Whats the average lap time's for combe in an 8 ?
Lemon
Has thanked: 29 times
Been thanked: 163 times
Post by Lemon » Sat Jun 01, 2019 7:28 pm
Thanks to those who suck with me on troubleshooting car problems.
The car cut out on my last session and whilst it would crank (and sounded like it had good compression) it wouldn't start. The car had also blown quite a bit of coolant oit and the exhaust tips were white showing that it had been running very lean.
On closer inspection the plugs were shot, with one of the leading ones completely missing it's electrode and the other nearly all gone.
The car appears to not be priming the fuel system, after rooting through the fuses and relays the car is blowing the EGI COMP1 fusethis appears to control the circuit relay which in turn controls the fuel pump.
I cannot thank quackers enough for allowing my to steal parts from his car in order to crawl home.
A quick Google has pointed to a faulty rear O2 sensor being the probable cause for the fuse to be blowing...
These users thanked the author Lemon for the post:
GreySilver Beast (Sun Jun 02, 2019 11:00 pm)
Thanks, Stu
Lemon
Post by Lemon » Sat Jun 01, 2019 7:29 pm
I will say though that when it went I'd just managed a 1:27.71...
Thanks, Stu
Conan
Has thanked: 56 times
Been thanked: 699 times
Post by Conan » Sat Jun 01, 2019 7:46 pm
Tell me the time you did and I will tell you it is better than average 😉
It depends on driver and mods, tyres, pads etc
Obviously PZ suspension is the fastest mod 🍷😄
I did do rough guide with different set up once.
These users thanked the author Conan for the post (total 2):
nightfire10 (Sat Jun 01, 2019 8:55 pm) • GreySilver Beast (Sun Jun 02, 2019 11:01 pm)
nightfire10
Post by nightfire10 » Sat Jun 01, 2019 7:51 pm
Tell me the time you did and I will tell you it is better than average Image
Obviously PZ suspension is the fastest mod ImageImage
1.32.36 any good
Ported
Teins
Crap wet tires
Has thanked: 4645 times
Been thanked: 1955 times
Post by ChrisHolmes » Sat Jun 01, 2019 8:18 pm
I have spare sensors if you want to try one.
Bridge Ported 231
MazdaSpeed sills
Short shifter
Lemon
Post by Lemon » Sat Jun 01, 2019 8:32 pm
i'll probably need that.
no point trying anything today as i can't get under the car where it is currently parked.
i really need to invest in a trolly jack.
Thanks, Stu
boosted
Has thanked: 74 times
Been thanked: 385 times
Post by boosted » Sat Jun 01, 2019 8:34 pm
Im out atmo..ill review drawings and list things to check in morning..
The missing electrode is a concern though..as has it damage side or apex seal.
And reasons for bumps.
Ill update in morning.
231 streetported Rx8 renny powered Westfield kit race car.
92 Rx7 fd3s stock twins..est.320bhp. Track car.
Lemon
Post by Lemon » Sat Jun 01, 2019 8:35 pm
boosted wrote:Im out atmo..ill review drawings and list things to check in morning..
It looked like it had burned away tbh Jon
I've kept the plugs anyway
We did turn it over with the plugs removed and it all sounds very even.
Thanks, Stu
boosted
Post by boosted » Sat Jun 01, 2019 8:37 pm
Pheww...there supposed to be for 30k....
boosted
Post by boosted » Sat Jun 01, 2019 8:39 pm
I pretty sure engcont1 feeds coils and if bad spark has taken a coil out...could be source of problem...
Lemon
Post by Lemon » Sat Jun 01, 2019 8:41 pm
we checked the coils, i had a lead that had come off from one of the coils but re connected they all showed spark with a set of spark testers that James had in his lorry.
cars just not getting any fuel from the pump to the engine.
Thanks, Stu
Post by ChrisHolmes » Sat Jun 01, 2019 9:08 pm
If you need any sensors or fuses tomorrow, or a low profile trolley jack give me a call
Bridge Ported 231
MazdaSpeed sills
Short shifter
mrspiller
Has thanked: 130 times
Been thanked: 285 times
Post by mrspiller » Sat Jun 01, 2019 9:20 pm
Lemon wrote:Thanks to those who suck with me on troubleshooting car problems.
Be. carful stu , isn’t that how Liam’s car blew its arse out ?
Post by ChrisHolmes » Sat Jun 01, 2019 9:21 pm
Hopefully a photo, two in some cases, of every car that was there today. Many, many thanks to everyone who came today and I hope you enjoyed the day as much as I did. Great to meet you new folks and apologies for not knowing the names of some people I have met before, Ok with faces but names are another thing for me!
If you want a high res version of any photo then PM me with a copy of the photo and your email address. Special thanks to Ann for being a sport posing on her bonnet for Leroy presenting an irresistible photo opportunity! I nearly got a snap of Clive checking his nuts too!
Please don't quote this post as it will repeat all the photos
P1110080 (Small).JPG (74.08 KiB) Viewed 526 times
P1110079 (Small).JPG (76.08 KiB) Viewed 526 times
P1110078 (Small).JPG (73 KiB) Viewed 526 times
P1110077 (Small).JPG (75.38 KiB) Viewed 526 times
P1110076 (Small).JPG (84.82 KiB) Viewed 526 times
P1110075 (Small).JPG (82.93 KiB) Viewed 526 times
P1110074 (Small).JPG (74.08 KiB) Viewed 526 times
P1110073 (Small).JPG (80.77 KiB) Viewed 526 times
P1110072 (Small).JPG (87.37 KiB) Viewed 526 times
P1110071 (Small).JPG (84.6 KiB) Viewed 526 times
P1110070 (Small).JPG (74.67 KiB) Viewed 526 times
P1110069 (Small).JPG (74.8 KiB) Viewed 526 times
P1110068 (Small).JPG (60.6 KiB) Viewed 526 times
P1110067 (Small).JPG (70.66 KiB) Viewed 526 times
P1110066 (Small).JPG (79.43 KiB) Viewed 526 times
P1110065 (Small).JPG (80.22 KiB) Viewed 526 times
P1110064 (Small).JPG (61.42 KiB) Viewed 526 times
P1110063 (Small).JPG (74.81 KiB) Viewed 526 times
P1110062 (Small).JPG (103.09 KiB) Viewed 526 times
P1110061 (Small).JPG (100.77 KiB) Viewed 526 times
P1110060 (Small).JPG (68.61 KiB) Viewed 526 times
P1110059 (Small).JPG (79.17 KiB) Viewed 526 times
P1110058 (Small).JPG (79.64 KiB) Viewed 526 times
P1110057 (Small).JPG (75.26 KiB) Viewed 526 times
P1110056 (Small).JPG (68.12 KiB) Viewed 526 times
P1110055 (Small).JPG (84.3 KiB) Viewed 526 times
P1110054 (Small).JPG (71.41 KiB) Viewed 526 times
P1110053 (Small).JPG (82.79 KiB) Viewed 526 times
P1110052 (Small).JPG (81.99 KiB) Viewed 526 times
P1110051 (Small).JPG (73.98 KiB) Viewed 526 times
P1110050 (Small).JPG (102.16 KiB) Viewed 526 times
P1110049 (Small).JPG (88.12 KiB) Viewed 526 times
P1110048 (Small).JPG (70.51 KiB) Viewed 526 times
P1110047 (Small).JPG (81.13 KiB) Viewed 526 times
P1110046 (Small).JPG (79.72 KiB) Viewed 526 times
P1110045 (Small).JPG (81.15 KiB) Viewed 526 times
P1110044 (Small).JPG (71.03 KiB) Viewed 526 times
P1110043 (Small).JPG (88.61 KiB) Viewed 526 times
P1110042 (Small).JPG (84.1 KiB) Viewed 526 times
P1110041 (Small).JPG (87.19 KiB) Viewed 526 times
P1110040 (Small).JPG (86.57 KiB) Viewed 526 times
P1110039 (Small).JPG (79.8 KiB) Viewed 526 times
P1110038 (Small).JPG (77.49 KiB) Viewed 526 times
P1110037 (Small).JPG (71.77 KiB) Viewed 526 times
P1110036 (Small).JPG (81.81 KiB) Viewed 526 times
P1110035 (Small).JPG (78.3 KiB) Viewed 526 times
P1110034 (Small).JPG (67.01 KiB) Viewed 526 times
P1110033 (Small).JPG (83.21 KiB) Viewed 526 times
P1110032 (Small).JPG (89.74 KiB) Viewed 526 times
P1110031 (Small).JPG (83.59 KiB) Viewed 526 times
P1110030 (Small).JPG (79.92 KiB) Viewed 526 times
P1110029 (Small).JPG (86.04 KiB) Viewed 526 times
P1110028 (Small).JPG (72.23 KiB) Viewed 526 times
P1110027 (Small).JPG (59.69 KiB) Viewed 526 times
P1110026 (Small).JPG (74.79 KiB) Viewed 526 times
P1110025 (Small).JPG (70.7 KiB) Viewed 526 times
P1110024 (Small).JPG (92.95 KiB) Viewed 526 times
P1110023 (Small).JPG (84.72 KiB) Viewed 526 times
P1110022 (Small).JPG (75.75 KiB) Viewed 526 times
P1110021 (Small).JPG (74.72 KiB) Viewed 526 times
P1110020 (Small).JPG (57.17 KiB) Viewed 526 times
P1110019 (Small).JPG (71.52 KiB) Viewed 526 times
P1110018 (Small).JPG (89.68 KiB) Viewed 526 times
P1110017 (Small).JPG (89.37 KiB) Viewed 526 times
These users thanked the author ChrisHolmes for the post (total 6):
Bigblueknight3k (Sat Jun 01, 2019 9:57 pm) • Shagrington (Sat Jun 01, 2019 10:26 pm) • Reloy (Sat Jun 01, 2019 11:04 pm) • CLOVERLEAF159 (Sun Jun 02, 2019 4:04 am) • AMH (Sun Jun 02, 2019 5:19 pm) • GreySilver Beast (Sun Jun 02, 2019 11:02 pm)
Bridge Ported 231
MazdaSpeed sills
Short shifter
Metelyk
Has thanked: 49 times
Been thanked: 167 times
Post by Metelyk » Sat Jun 01, 2019 9:24 pm
Great day out!
Thanks to all the organisers and helpers. And, thanks Nigel for my prime stand position Image
What a fantastic Car Club!!
Some piccies from the day............
These users thanked the author Metelyk for the post (total 4):
ChrisHolmes (Sat Jun 01, 2019 9:25 pm) • Reloy (Sat Jun 01, 2019 11:05 pm) • CLOVERLEAF159 (Sun Jun 02, 2019 4:05 am) • GreySilver Beast (Sun Jun 02, 2019 11:06 pm)
Neilparry
Has thanked: 28 times
Been thanked: 233 times
Post by Neilparry » Sat Jun 01, 2019 10:25 pm
Cheers folks
Another well organised meeting.
Enjoyed the club track session my quickest lap was 132.21
Standard car with low compression
Tien lowering springs
Fully loaded with passenger and roll cage lol
And very good AR1’s
Thanks to Chris Holmes for taking Graham’s harness bare off me and thanks for the half worn set of pads. Much appreciated.
Also the scones were spot on
These users thanked the author Neilparry for the post (total 2):
ChrisHolmes (Sat Jun 01, 2019 11:04 pm) • GreySilver Beast (Sun Jun 02, 2019 11:08 pm)
:wash:
Has thanked: 796 times
Been thanked: 808 times
Post by Shagrington » Sat Jun 01, 2019 10:32 pm
It was a hot day. 8) Big thanks to everybody who had anything to do with anything (organising it, setting up the stand, leading convoys, cooking bacon, providing eatable things, providing good company etc .... I hope you all know who you are, I do mean you). =D> =D> =D>
These users thanked the author Shagrington for the post (total 2):
ChrisHolmes (Sat Jun 01, 2019 11:07 pm) • GreySilver Beast (Sun Jun 02, 2019 11:08 pm)
Studle
Been thanked: 107 times
Post by Studle » Sat Jun 01, 2019 10:48 pm
It was a great day as usual and weather performed well again. Thank you to everyone involved in making this a memorable event. Food was delicious, great people and great club to be a part of. Thank you Nigel for the car decal, had a perfect place on the windscreen for it. Lovely photos of the cars!! My parents thoroughly enjoyed it and the track sessions. A big thank you to Ian for taking my Dad out as a passenger and showing him how it’s done!! See you all soon :D
These users thanked the author Studle for the post (total 2):
ChrisHolmes (Sat Jun 01, 2019 11:07 pm) • GreySilver Beast (Sun Jun 02, 2019 11:09 pm)
Done:
Engine rebuild and street ported ,R969 coils
Toyo catback, Lightened flywheel, Short shifter
Tein lowering springs, K&N air filter. Front black diamond grooved discs, racing hawk pads. Braided brake lines. 20mm spacers, Mishimoto oil cooler hoses, Strakes.
To do:
Blue Led interior lighting, Nexus 7. More track days.
Has thanked: 385 times
Been thanked: 1480 times
Post by warpc0il » Sat Jun 01, 2019 11:15 pm
What plugs were you running?
I *know* people say that "hot plugs" are fine for track work but Mazda themselves were very clear that they should only be used for cars that spend their time pootling around in traffic, especially the US/JDM autos that change at at too low revs.
firium
Been thanked: 19 times
Post by firium » Sun Jun 02, 2019 9:11 am
I'd like to add to the chorus of thank yous for the organisation, not to mention for the food and drink! I had a good walk around the event, and there were few clubs with areas as well appointed and as friendly as this one's. All in, my food spend was £2 for an ice cream which given I didn't bring anything with me is miraculous. Next time however I shall arrive armed with cookies for sure!
By small way of recompense, below are a selection of my photos from the day. Cheers all :)
These users thanked the author firium for the post (total 3):
Reloy (Sun Jun 02, 2019 9:17 am) • ChrisHolmes (Sun Jun 02, 2019 11:24 am) • GreySilver Beast (Sun Jun 02, 2019 11:10 pm)
mi60o0
Has thanked: 88 times
Been thanked: 275 times
Post by mi60o0 » Sun Jun 02, 2019 10:35 am
Lovely photos from all of you but Chris have the best photos due my purpelishes is there when I get home I shall put the new wheel nuts I get from the show black with purple they look lush
These users thanked the author mi60o0 for the post (total 2):
ChrisHolmes (Sun Jun 02, 2019 11:24 am) • GreySilver Beast (Sun Jun 02, 2019 11:12 pm)
BatRex 192 stock
goodeggbob
RX-8: Kuro
Colour: Kuro Black
Has thanked: 442 times
Been thanked: 613 times
Post by goodeggbob » Sun Jun 02, 2019 11:05 am
many thanks to all who organised this, it was a pleasure to be involved and to meet new faces and old ones again. i seem to have made my way into a few photos, which goes to show that i must talk more crap than i thought i did.sorry.
These users thanked the author goodeggbob for the post (total 2):
ChrisHolmes (Sun Jun 02, 2019 11:28 am) • GreySilver Beast (Sun Jun 02, 2019 11:12 pm)
mrspiller
Post by mrspiller » Sun Jun 02, 2019 11:14 am
What plugs would you say are ideally suited for a track only car ?
Return to “The Vault”
