‘TRACKDAY', Bedford Autodrome GT (Bedfordshire) - ***Monday 24th June*** £199
Explore the limits of the car and driver, and enjoy the car the way it was meant to be driven. Open pitlane track days, car control days, and driver training. The car is the star!
(Let us know any days you are attending. Please contact the Events Coordinator or someone from the Events Team).
MightyCondor
Has thanked: 432 times
Been thanked: 796 times
Re: ‘TRACKDAY', Bedford Autodrome GT (Bedfordshire) - ***Monday 24th June*** £199
Post by MightyCondor »
Kernow Rotary Specialist wrote:That's 100% ess issues. I belive you've already changed it once? In that case it may be a wiring issue or a faulty ecu. The wiring issue seems more likely. I'd start with drag testing the ess connector pins to check pin tension. If that's acceptable I would meter from ecu to ess plug on each wire to check resistance, then shake test the loom to see if you have a partially broken wire. If the wiring tests show a problem you could run a jumper wire to the ecu and see if that clears your code. If it does, you can run more permanent jumper wires, or replace the engine loom.
I've changed the sensor twice, although it seemed secure previously before its attempt to fall off yesterday. I had resigned myself to changing the ECU or loom to clear the code but it hadn't been that pressing an issue while the car was otherwise running fine.
Do you think my new symptoms on the dash are all byproducts of it?
Hopefully the sensor stays put or it'll be helecoiling required....
Sent from my Pixel 8 using Tapatalk
Colour: Nordic Green
Has thanked: 441 times
Been thanked: 1792 times
Post by qwakers »
Yes, if the ess signal is dropping out it will drop the rev counter to 0
Don't jump to replacing the loom just yet. Google connector drag testing. The symptoms match a loose connector. If that isn't it, running a pair of jumper wires to the ecu to test is easy, if a little involved, and the ecu pinout is readily avaliable.
MightyCondor (Tue Jun 25, 2024 1:06 pm)
MightyCondor
Thanks James. I was already planning an ECU swap at some point just for the sake of also having to replace my keyless module and get remote locking working again, while also taking advantage of returning to stock coil dwell settings so I can fit some RRP coils. I'll have a go at testing it your way first. I do have a spare loom already in anticipation.
Hopefully I can get the car home from Milton Keynes tonight without a breakdown.
I guess I'll have to have the PZ on standby to do the annual meet weekend....
MightyCondor
My videos are up on my project thread: viewtopic.php?p=1434216#p1434216
These users thanked the author MightyCondor for the post:
brad_wil (Sun Jun 30, 2024 9:23 am)
brad_wil
Has thanked: 287 times
Been thanked: 88 times
Post by brad_wil »
Finally pulled my finger out and uploaded my videos from the day
Sent from my SM-X700 using Tapatalk
These users thanked the author brad_wil for the post (total 2):
MightyCondor (Tue Jul 02, 2024 8:09 pm) • casey (Thu Jul 11, 2024 8:47 am)
Fab66
Has thanked: 92 times
Been thanked: 50 times
Post by Fab66 »
MightyCondor wrote:My videos are up on my project thread: viewtopic.php?p=1434216#p1434216
Enjoyed watching that! Looked a lot of fun..
These users thanked the author Fab66 for the post (total 2):
MightyCondor (Sun Jun 30, 2024 7:34 pm) • brad_wil (Sun Jun 30, 2024 7:36 pm)
GrantRL
Forum Guest
Forum Guest
RX-8: Prospective Buyer
Post by GrantRL »
brad_wil wrote:
Sun Jun 30, 2024 5:43 pm
https://youtu.be/sNlAF1JqOug?si=Uo46_47K6eNV6COF
https://youtu.be/gwElahP_fy4?si=66dly-CXC7nGpZYy
https://youtu.be/Ioj5YrP2j7c?si=D-gqDcUpgGSN4PhF
https://youtu.be/ZHZBDwFqW30?si=zQvq-Le3I7bzWioP
That sure was a fun day! Nice vids
Return to “Car Activity and Track days”
