Hi me again,
The kids are in bed so I can finally talk about this properly. So in the rush to get ready for this day, I didn't even get a chance to look at a track guide for this track. Luckily the other driver with me, Will, knew the track well and taught it to me quickly. For the sighting lap and the first time out, alot of the corners looked pretty similar and I struggled to tell them apart. What I initially thought first was the change in elevation and camber was interesting, and something that wasn't so obvious in vids of the track. Especially the Craner curves and then up by Starkey's bridge and Schwantz Curve, was a nice down up and felt a little like Eau Rouge at Spa to me. Will went out and then I went out again and it all started to make more sense.
At first it was a struggle with my rainsport 5's and the rear kept kicking out under power. I started thinking that it was maybe my car or the alignment was off at the rear, and maybe a trip to Fergus was on in order. However I did have the pressures at 33-34, and after talking to Nick Palmer who had the same tyres I dropped them down to 30 and it seemed better, however the track was drying so maybe that was it? Alan then also suggested dropping even further to 28. I actually forgot to do that but at 30psi, the tyres felt much better. Also I reckon maybe the tyres were not scrubbed in enough at the rear, because even when we went out later in the rain, they felt nice and grippy on the rears so probably a combo of wrong pressures and scrubbing in. Braking was fine with my pagid pads and discs. I wasn't sure how they would perform and if they would melt under the load but they performed admirably. Stopped perfectly every time, and no fade, but that could be cos it was cool and we didn't get the speed we would in the dry.
Corner wise I didn't think I did the first one that well as I felt slow on exit, but Will reckon I had a good line through Redgate, and then really good through the Craner curves, especially the 2nd part and many people were late apexing that one, whereas you can do a nice early turn in for that one and carry speed. Then up through old hairpin and Starkey's Bridge and and Schwantz Curve was easy ( although i did have a few oh crap moments through Starkey's Bridge as if I had the line slightly wrong there was a bit where the car swung out. Mcleans was ok, but it's very tempting to go through too quick through there and then slide over the kerb on exit.
Coppice was my biggest struggle. Being blind it was hard to judge the braking point and then I tried lots of lines, inside outside etc, but could not get the rear down and had to feather the throttle through coppice, and I really wanted to get the power down for the next straight. I think when I was following you Alan (MightyCondor) you were doing this corner really well. Fogarty esses were fine, just take maximum kerb on exit on the right and try to clip the tyre barrier on the left. I did struggle with braking point though, and despite having thinking time down the straight I still struggled to get my speed just right for the esses at times.
Melbourne hairpin was fine, but just struggled getting power down on exit, and same with the next left hander. No real struggle with braking as I was probably braking a bit early. Nice track and I only really have Bedford to compare it to, but it being technical and flowing in many places it was nice to be able to keep with alot of cars, unlike Bedford where people would get away on the long straight. I really liked the flowy down up part through Craners etc and the views were lovely just after Hollywood.
My biggest struggle, as I thought it would be, was getting the braking and gear changes right. Sometimes I'd brake too early and sometimes too late. With gear changes I would try and do them too fast before I'd scrubbed off speed with the brakes, or sometimes hold the clutch down mid corner, as I didn't feel the car was slow enough to get into the lower gear and then I would lift mid corner which is awful technique. Bad habits from road driving. I need to work on keeping the brake on, downshifts before turning into the corner, and then keeping some brake on and gently releasing to transition into the corner. Will was saying I was releasing brake a bit when heel and toeing so car was lurching back and forth a bit, and then I was jumping off the pedal before turning in. I got it right a few times, and in Melbourne hairpin getting the smooth transition into the apex meant it was easier to get the power down and come off the corner smoothly. There was much traction control lights on exit, on alot of corners, though never really lost it, the Rex always gave a good indication of how much it was slipping on the butt dyno. I didn't really have the ABS kick in too much. I reckon the key to more speed will be getting better corner entry speed in some of the corners, and linking it all up at speed. Taking a bit more kerb in areas as well, but I just got worried about going into the grass with the wetness yesterday.
In terms of other drivers most were good. The Jag was hilarious, and also the GT86 ( the black one ) also spun it on the sighting lap. He was a bit of a tool and got in the way on our first stint but was so slow so easy to overtake, and luckily didn't see him much after. Other then that I often got out of the way for most of the drivers but some were aggressive. The two red RS Meganes were pretty aggressive ( they can't have been standard ), and then a grey VW golf also tried to overtake in the corner, but most were good. I remember there was a dark blue or black clio that indicated to let me by and then almost took me out, and then there was a grey Porsche Cayman which kept getting in my way. He'd get in my way in the corners and then accelerate away on the straights after I'd lost all my momentum. Even when I let him get ahead as other cars came by or just to get some room then I'd be back on him on no time. Clueless. Will had pleasure in flashing a blue Renault Megane R26R with some livery out of the way, en route to the Mclaren. No one blocked which was good. Lastly I enjoyed watching a grey bmw m3 with the plate NI55 OFF, drift it on about every single corner.
So, all in all, as I said before I really enjoyed it and actually think if COVID is ever over and all the facilities were open it would really be a great day out. The benches and cafe etc were all really nice and I can imagine all of us having a nice lunch together on a sunny day and having a good chat. I am keen to get back and would love to see how the track is in the dry, and with some grippier rubber. Will was impressed with the car and said it was amazing how communicative the car was and how quick it went through the corners. He said you only realise how fast you are going through if you look at the speedo, as the car is so smooth it doesn't feel like you are on the edge at all. The car also easily communicated clearly that it was starting to slide so you could correct. He's keen to drive it again with grippier rubber on a dry day as well.
Ok, my first track day in a long time, so apologies for jabbering on, and I'll be quiet now....
njmkr - Did we meet on the day ? I don't remember if we did, but apologies if we did and I forgot ? Even bigger apologies if I didn't come and say hi and you were just there. Maybe I didn't realise you were with us as you were driving a MX-5 ... but I should have realised.
