^^^TRACKDAYS 2019^^^
A record and archive of car activity and track days attended by Club members. Read-only.
Been thanked: 785 times
Re: ^^^TRACKDAYS 2019^^^
Post by PeteH » Thu Feb 28, 2019 1:51 pm
Malcolm, Nigel might be away for a bit. Can we sort it, or ask Chris H to look into it?
TestDrivesUnlimited (Mon Mar 04, 2019 10:32 pm)
Mpv2k3
Has thanked: 182 times
Been thanked: 385 times
Post by Mpv2k3 » Thu Feb 28, 2019 5:41 pm
After last year trackday, I am planning to attend Oulton park with MOT again.
Oulton Park Track Day - Friday 15th November 2019 - Full OPL - 72 car limit. - Early Booking Price
£125.00
casey
Has thanked: 1008 times
Been thanked: 1228 times
Post by casey » Fri Mar 01, 2019 11:04 am
Email sent to Javelin this morning, requesting renewal of the discount code. Will post up when I get a response. They are usually quite quick to reply :D
Club Secretary
Seibon Carbon Fibre Bonnet
casey
Post by casey » Mon Mar 04, 2019 1:26 pm
RickyG512 wrote:
Thu Feb 28, 2019 12:08 pm
Is it me or is the Javelin discount code not working?
Got this email reply today from Peter Jebson at Javelin:
"I’ve reset that for you guys. Any codes we setup tend to expire at the start of each year so we don’t end up with them just sat on the books indefinitely and can change them each year if needed."
Hopefully discount code now working OK :D
Club Secretary
bc-49
Has thanked: 58 times
Been thanked: 64 times
Post by bc-49 » Mon Mar 18, 2019 12:08 am
Anyone fancy Silverstone GP? Never done the full GP circuit before, and looking to tick it off the list. Would be cool to have a group of 8s there.
Friday 8th November - £199 with Javelin (Limited time offer, regular price £229)
Layout : GP (3.667 miles)
Format : Open Pit Lane
Noise : 102dba Drive By
Overtaking : Left Hand Side ONLY on Straights.
https://www.javelintrackdays.co.uk/trac ... ember_2019
2006 Galaxy Grey 231
Yokohama V105 | Eibach Pro-Kit Springs | Eibach 20mm Spacers | Mintex 1144 Pads | Racing Beat REV8 Catback | BHR Ignition | K&N Filter | Koyorad Alu Radiator | Mishimoto Thermostat | Greddy Sump | ER Braided Oil Lines | ER Oil Pressure Reg | ER Baffle Plate | Lockwood Front Grills
Has thanked: 262 times
Been thanked: 566 times
Post by Dr. FrankenRex » Mon Mar 18, 2019 4:25 pm
Has the code changed? I tried to use the one that's in the member's area (from 2014) and it's given the error about being invalid, expired etc.?
Has thanked: 10281 times
Been thanked: 2477 times
Post by GreySilver Beast » Mon Mar 18, 2019 6:10 pm
Code link on the First Post of this Topic Dan :thumleft: - Events Team
GSB III 03/08/13 - Present
Post by GreySilver Beast » Mon Mar 18, 2019 10:40 pm
Topic Link now added to this Track Day :thumleft:
CADWELL PARK (Louth), Saturday 14th December. Member Event. Full Open Pit-Lane day with the great Team at OpenTrack, price £99. Book your place BY CLICKING ON THIS LINK. Topic now running JUST CLICK HERE. 2 Booked already.
Post by Dr. FrankenRex » Tue Mar 19, 2019 11:10 am
That's the one I was using, and it's flagging the error...
casey
Post by casey » Tue Mar 19, 2019 4:58 pm
Dan, I tested it when Javelin said they'd reset it and it worked fine. Just to be sure, I've tried it again just now, and it still works fine (Chrome on PC).
You are copying and pasting the code (silly question I know, but I had someone tell me the code wasn't working, but they were typing a "zero" when it should have been a letter "O", which was obvious in the context!). Also, are you:
NOTES:
1. You MUST be logged in with a valid Javelin account before you try to apply the discount code!
As I say, it works perfectly for me....... :-k
Club Secretary
casey
Post by casey » Tue Mar 19, 2019 5:02 pm
Ah, are you using the "Use Coupon Code" box at the checkout?
If you use the "Use Gift Coupon" box it will generate the code you mentioned......
Club Secretary
Post by Dr. FrankenRex » Thu Mar 21, 2019 8:19 am
I'll give it another go today :thumleft:
Post by Dr. FrankenRex » Thu Mar 21, 2019 9:23 am
Worked it out lads! You cannot use the code for gift vouchers :thumleft:
Works for track days, but not for gift vouchers :) As such it might be worth removing that wording from the OC discount code page :thumright:
GreySilver Beast (Thu Mar 21, 2019 9:37 am)
Post by GreySilver Beast » Thu Mar 21, 2019 9:37 am
They must of changed it as I bought Gift Vouchers last year and used the Discount Code :thumright:
V8 Power
Has thanked: 156 times
Been thanked: 348 times
Post by V8 Power » Thu Mar 21, 2019 9:40 am
When you go to use your gift vouchers can you then apply the discount code?
Carbon seats
Sabelt 6 point harnesses
Direct cold air feed
Tein Monosport coilovers
Carbon Adjustable wing
Feed gearknob
Axial short shift
Autec lightweight alloys
Whiteline ARB's
Stripped interior
RRP Coils MSD leads
Post by GreySilver Beast » Thu Mar 21, 2019 9:42 am
I will take a look later :thumleft: - Events Team
casey
Post by casey » Thu Mar 21, 2019 1:16 pm
Ah! Mystery solved. I've removed the wording from the discount post.
The original wording for the discount was from 2014, before Javelin did a major website revamp in 2017, and introduced their points scheme too, so likely things have changed.
As has been said, it maybe you can use the code against the voucher, but I don't know for sure.
GreySilver Beast (Thu Mar 21, 2019 1:58 pm)
Club Secretary
Post by GreySilver Beast » Thu Mar 21, 2019 11:16 pm
Just tested on my Account and you can no longer use the Discount Code to buy gift vouchers :(
Post by GreySilver Beast » Sat Mar 30, 2019 10:24 pm
JDM CASTLE COMBE (Wilts), Saturday 1st June. Events Team Supported. This is "JDM", an event at the popular Castle Combe Circuit - website link with further details. The club will have a stand at the event and have a track session too - THIS TOPIC. 15 Booked already.
So far only 15 places have been bought out of the 28 allocated spaces that we have within our Exclusive Track Session, so get your names down HERE :thumleft: , purchase your place within the Club Shop =D>
(NOTE you need to be a paid up member to attend this event on our stand)
Post by GreySilver Beast » Thu Apr 04, 2019 11:13 pm
Just added :thumleft: - Events Team
CADWELL PARK (Louth), Sunday 25th August. Member Event. Full Open Pit-Lane day with the great Team at Javelin, price £199. Book your place BY CLICKING ON THIS LINK. Topic now running JUST CLICK HERE. 1 Booked already.
Post by GreySilver Beast » Thu Apr 11, 2019 12:18 pm
JDM CASTLE COMBE (Wilts), Saturday 1st June. Events Team Supported. This is "JDM", an event at the popular Castle Combe Circuit - website link with further details. The club will have a stand at the event and have a track session too - THIS TOPIC. 21 Booked already.
So far only 21 places have been bought out of the 28 allocated spaces that we have within our Exclusive Track Session, so get your names down HERE :thumleft: , purchase your place within the Club Shop =D>
Post by GreySilver Beast » Thu Apr 11, 2019 7:21 pm
Going to book Knockhill 6th September soon, but just waiting to hear if the Paul Walker Tribute SLS is also offering Hot Hatch Track Sessions on 8th September as well like last year, before I book the Track Day :twisted:
I keep going back as I love driving the Knockhill Circuit =D> =D> =D> =D>
^^^TRACKDAYS 2019 & 2020^^^
Post by GreySilver Beast » Sun Apr 28, 2019 8:36 pm
Added to the first page for 2020 :thumleft: - Events Team
Nürburgring Nordschleife 2020 (Germany), April TBA. Member Event. Full Open Pit-Lane day with Circuit Days, Early Bird price £?. Book your place BY CLICKING ON THIS LINK. 0 Booked on this Trip with GBCC.
CARLIMITS 2020 (20 Car Day) (Essex), Date TBA. Member Event. , price £?. Topic now running JUST CLICK HERE. 2 Reserved Places Booked with GBCC.
Post by GreySilver Beast » Tue Apr 30, 2019 10:55 pm
More details have been added to help you work out cost etc..... =D>
A word of Warning the April 2019 Track Day SOLD OUT in 2 days :shock:
Nürburgring Nordschleife 2020 (Germany), April TBA. Member Event. Full Open Pit-Lane day with Circuit Days, Early Bird price TBA. Book your place BY CLICKING ON THIS LINK. Book your place on the Le Shuttle, some of us staying at Lindner Nürburgring Ferienpark, you will also need Track Insurance for the Armico Crash Barriers. 0 Booked on this Trip with GBCC.
Post by GreySilver Beast » Tue May 14, 2019 12:46 am
Another Track Day added courtesy of Ranjan's suggestion =D> - Events Team
MALLORY PARK (Leicester), Saturday 9th November. Member Event. Full Open Pit-Lane day with the great Team at Javelin, price £119. Book your place BY CLICKING ON THIS LINK. 1 Booked already.
Locked
Return to “Car Activity and Track days Archive”
