RX-8 Trophy, new racing class for 2019
A record and archive of car activity and track days attended by Club members. Read-only.
Stripey71
Re: RX8 Trophy, new racing class for 2019
Post by Stripey71 » Thu Sep 27, 2018 4:56 pm
Hi any North East owners - NE1 on here thinking of joining this new CSCC rx8 trophy series. Having watched Ben and Petes escapades in japspeed I’m looking for someone reasonably local to buddy up with on a car for this new trophy as I’m wanting to share racing and costs.
If you are interested PM me please for a chat.
Has thanked: 386 times
Been thanked: 1484 times
Post by warpc0il » Thu Sep 27, 2018 5:02 pm
@Stripey71 it would help if you updated your profile with your location
ucp.php?i=ucp_profile&mode=profile_info
Stripey71 (Thu Sep 27, 2018 5:51 pm)
benedwards64
Been thanked: 34 times
Post by benedwards64 » Thu Sep 27, 2018 5:51 pm
Sorry - couple more questions as i think of them....
How many rounds are expected, and how many races per round?
Are all races with a pit-stop (and potential driver change)?
Any idea on entry costs?
Also, any idea on cost for the cages?
Sorry for all the questions - we were on the verge of buying a hatchback of some sort for endurance racing, but the idea of dual racing an RX8 is mighty tempting...
Stripey71
Post by Stripey71 » Thu Sep 27, 2018 5:52 pm
warpc0il wrote:@Stripey71 it would help if you updated your profile with your location
Im in the north east ...:) near Newcastle upon Tyne
Fishy Dave
Post by Fishy Dave » Thu Sep 27, 2018 8:45 pm
Evening,
There are 8 rounds (dates to be announced before November), one race per round, with 30 minutes qualifying and the 40 minute pit stop race on the same day to save time and money pressures, the race is likely to cost £385ish (split the costs if two of you). If you are keen on more tracktime you can also enter the RX8 in the CSCC Racetruck Open series at the same event; these are also a 40 minute pit stop race, with a mix of cars racing from all different ages (1950s to present day). The Open race is discounted as a 2nd race, around £225ish. 2019 prices to be announced by the Silverstone launch in November (by then our 2018 races have finished and we know how the financials for the season have finished up). Spa is a 30 minute qualifying and 2 x 40 minute races, usually priced around £650, so it's actually cheaper per race once you are out there.
The cage is £1332, fully fitted with VAT in black powder coat (colours available for a bit more), from Laser Caged Engineering in Somerset. They will set the cage kit cheaper if you have a preferred local cage fitter (welding the feet in is required, the cage then bolts down to these feet).
Hope that helps, regards, Dave
Has thanked: 4647 times
Been thanked: 1958 times
Post by ChrisHolmes » Thu Sep 27, 2018 9:07 pm
What a breath of fresh air for the RX-8 world. It will certainly produce some close racing where the drivers skills and not the power under the right foot will be the key to success.
Fishy Dave (Thu Sep 27, 2018 9:08 pm)
Bridge Ported 231
MazdaSpeed sills
Short shifter
benedwards64
Post by benedwards64 » Thu Sep 27, 2018 9:58 pm
Evening,
Thanks Dave, that's really helpful. It's mighty tempting!
Juey
RX-8: Import
Colour: Black Cherry
Has thanked: 20 times
Been thanked: 98 times
Post by Juey » Mon Oct 01, 2018 10:09 am
....and may see the price of a 2nd hand standard exhaust system rise!
Black Cherry Mica
I can explain it to you, but I can't understand it for you.
Post by ChrisHolmes » Mon Oct 01, 2018 11:20 am
I doubt there will be any impact on used car or parts prices as the number of vehicles involved will not be great.
Bridge Ported 231
MazdaSpeed sills
Short shifter
Liam22
Has thanked: 22 times
Been thanked: 54 times
Post by Liam22 » Mon Oct 01, 2018 11:22 am
Get a really rusty one... It'll be lighter!
Post by warpc0il » Mon Oct 01, 2018 11:39 am
I think that was Alfa Romeos plan in the '80s, at least if my AlfaSud was anything to go by - "Maintain the power:weight ratio by having more bits of the body rust away as the engine gets tired" [-X
Unfortunately, some RX8s seem to be following the same principle, when you look at the sills :shock:
bigpete8
Has thanked: 90 times
Post by bigpete8 » Mon Oct 01, 2018 11:56 am
I know very much from experience this is not the case....
When I used to work on MGs in my uni days any sill work would invariable leave the car several pounds lighter as the rot weighed significantly more than new metal!!
Clive
RX-8: Supercharged
Has thanked: 274 times
Been thanked: 369 times
Post by Clive » Mon Oct 01, 2018 1:01 pm
Not sure if it was Dave, but I was approached by someone at Donnington who was in involved with this project and had a quick chat.
For parity the each car needs to be sat on the same dyno with the room fuse pulled as this drops the ECU into the better map then sealed with wire and marked lead weights/ engine / ECU and OBD port.
As I pointed out, so many of these cars have been ported the car could be bought with the new owner not even knowing he had a ported engine.
Looking at the rules the only thing I would strongly is a set of Eibach springs and as an official Eibach dealer I could talk to Eibach to see if I could get a discount for each racer. I do this with the MX-5 Super Cup Series which we sponsor.
Reason for the Eibach Springs, yes the car will handle better, but if you have ever seen an RX-8 with the interior stripped you could walk under the wheel arches because with all that weight out the car goes up in the air.
Some will remember the RX-8 that turned up for a track day at Oulton Park with just the drivers seat and we ribbed him all day about his tractor looking RX-8, so we wouldn't want these new to the track RX-8's turning up not looking like race cars would we ;)
These users thanked the author Clive for the post:
ChrisHolmes (Mon Oct 01, 2018 1:55 pm)
GraemeC
Been thanked: 20 times
Post by GraemeC » Tue Oct 02, 2018 3:23 pm
I'll be following this with interest, although the missus might kill me if I were to purchase a 2nd RX8 for racing!
Fishy Dave - are you the same Fishy Dave who used to post on the Fiat Coupe forum? (surely must be!)
Stripey71
Post by Stripey71 » Tue Oct 02, 2018 5:13 pm
GraemeC wrote:I'll be following this with interest, although the missus might kill me if I were to purchase a 2nd RX8 for racing!
Me too - I have 3RX8s already including a racing one but its over spec for this opportunity. I am looking for somebody to bloody with for the series as you can have two drivers. Happy to share 50% of all costs and efforts!
andy97
Forum Guest
Forum Guest
Post by andy97 » Wed Oct 03, 2018 11:20 am
But you could still race your existing race RX8 in the CSCCs "New Millenium" Series and be on the grid at the same time, but you would just be in one of the mixed classes and not the RX8 Trophy Class.
Liam22
Post by Liam22 » Wed Oct 03, 2018 11:55 am
Yup, but you'd be in the 3 litre class. A modest BMW E46 330i would be 50bhp up on you.
I did a single New Millennium race back in 2015. Good mix of cars but you'd need a well tuned RX8 to be competitive.
I was lucky it was a wet race :)
Conan
Has thanked: 56 times
Been thanked: 699 times
Post by Conan » Wed Oct 03, 2018 12:11 pm
It would probably help in finding a partner if you put your location in your profile ;)
Do you have a trailer and tow vehicle ?
Stripey71 (Mon Nov 19, 2018 9:11 am)
andy97
Forum Guest
Forum Guest
Post by andy97 » Fri Nov 02, 2018 4:18 pm
These users thanked the author andy97 for the post:
bc-49 (Sat Nov 03, 2018 5:38 pm)
Has thanked: 9567 times
Been thanked: 2300 times
Post by GreySilver Beast » Fri Nov 02, 2018 4:36 pm
Moved here as more people will see this Thread :thumleft: , than in RX-8 Discussions Section :!:
ChrisHolmes (Fri Nov 02, 2018 5:55 pm)
R.A.C.E Car Club
GSB III 03/08/13 - Present
Nerdstrike
Been thanked: 31 times
Post by Nerdstrike » Mon Nov 05, 2018 9:43 am
Rusting adds weight. Until the stuff falls off anyway.
Stripey71
Re: RX-8 Trophy, new racing class for 2019
Post by Stripey71 » Mon Nov 19, 2018 9:12 am
Liam22 wrote:Yup, but you'd be in the 3 litre class. A modest BMW E46 330i would be 50bhp up on you.
That’s why I’ve been looking at 7:50 C7 5750 see been to Rome tomorrow series as my car quite competitive here. It’s full Bridgeport and very light with lots of spec
I’m in Newcastle
Stripey71
Post by Stripey71 » Mon Nov 19, 2018 9:14 am
What wheels are recommended for japspeed / time attack - I have a R3 and want to buy some lightweight wheels? 17” or 18” for R3 for racing - what types ?
Been thanked: 785 times
Post by PeteH » Mon Nov 19, 2018 4:36 pm
If you want wheels for serious racing then focussing on "light" isn't necessarily the best. Racing wheels take a lot of abuse, and you really don't want your wheels failing at 120mph.....
I use Team Dynamics 18". They are very strong, and light enough. Also consider that lap time isn't just about making stuff light. There are loads of slow cars that don't weigh much. If your wheels leave you with a poor tyre choice and small brakes then you will go slower.
Ps. If you entered your car in Time Attack then you'd be in Club class, because your car is Bridgeported. Unfortunately any RX-8 would be outclassed in Club, because that class is full of turbos.
Stripey71 (Mon Nov 19, 2018 8:11 pm)
Liam22
Post by Liam22 » Mon Nov 19, 2018 5:01 pm
Same with 750MC regs. Bridgeport will put you in Class B which is 240bhp/ton @flywheel. That's a lot to ask of a N/A Renesis
Return to “Car Activity and Track days Archive”
